Request: RE Octane SSK Install
03-24-2006, 05:17 PM | #1 |
Rep 158
I did a search and came up with nothing.
Given that Rogue does not have install instructions posted on their website I am curious if anyone who has an SSK installed took pictures during the process. I am considering ordering one of these but I would like to find out the difficulty of the install prior to doing so. Thanks. |
03-24-2006, 06:44 PM | #3 |
Rep 43
OK, so I removed both bootys. The Rogue instructions say to then disconnect the shifter from the shift link. Looking down from the top, I see no possible way to disconnect it due to many other things in the way. I am also doing this is the dark. I will look at it more tomorrow or Sunday
03-25-2006, 10:53 AM | #5 |
Rep 1,184
You need to do the install from under the car, prefereably on a lift, but can be done easily with ramps or jackstands (please be careful with either!)
Once you are under there, its pretty straightforward, although those clips can be a PITA. |
03-25-2006, 09:11 PM | #6 | |
Rep 3,011
"Teach the ignorant. Ignore the stupid."
03-26-2006, 12:53 AM | #7 |
Rep 43
You cant do it yourself because you cant jack up your car or drive it up some ramps? thats lame. You can get a jack at autozone for 30 bucks. Ramps are about the same price
03-28-2006, 10:17 PM | #9 | |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Moocow, try searching for info here first. Not that you mind doing what you did , but you would've seen that dropping the exhaust or similiar is required for the rogue ssk. Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
