Does limp mode occur in non modded 335i's?
07-26-2008, 01:19 PM | #1 |
Rep 231
So far Ive had 2 limp modes and I think that I caused both of them out of stupidity....forgetting that I was in DS and had hit a paddle so causing it not to shift automatically then bouncing off the rev limiter for a second before realizing that I need to shift. I did this today showing my cars 'extra' power to a friend.
My question is this, do any of you who have a stock tuning have limp modes pop up from time to time or is it just the tuned cars? Also, if I understand correctly, this is not a CEL its just a limp mode so no ODBII codes will be thrown and it wont be recorded in the ECU...is this correct or am I way off here? |
07-26-2008, 04:36 PM | #2 |
595
Rep 5,946
Wait, let me get this straight, a Limp will only occur when you hit the rev limiter?? I've got that twice WITHOUT hitting the rev limiter :-( taking her in week after next to the stealer...to see whats up
07-26-2008, 09:46 PM | #5 |
Rep 1,288
Drives: 135i
i get limps stock. I think every friggin 335 just limps whenever you drive your car like a BMW is supposed to be driven.
Performance: UUC Sways CDV Mod KW V3 Vorshlag plates Pagid Yellow VK OC Hotchkis Brace STETT IC/CAI Braille B2015 VK Catless DP BMS JB3 M-Tech
#1 Mod: AutoX/HPDE HPDE 3 Many Thanks: **********s UUC Motorwerks VK Motorwerks HP Autowerks SOLD |
07-26-2008, 10:50 PM | #6 |
Rep 1,432
+1,000,000.
2018 F80 LCI II ZCP ///M3 Mineral White M-DCT| Sakhir Orange Interior| |M Performance Exhaust| |
07-26-2008, 11:35 PM | #7 |
595
Rep 5,946
07-26-2008, 11:51 PM | #8 |
Rep 957
Drives: 2022 X3 M40i
I had a limp mode caused by a failed fuel injector (not the pump). So, yes it's possible for a stock car to go limp. As far as going limp driving the way it's intended, that has never been my case. I drive the car spiritedly, and often, without limps.
07-27-2008, 12:22 AM | #9 |
Rep 2,443
+1 limp when i was stock Wastegate issue and boost pressure loss for me. Everything has been fixed for awhile now though and running great
07-27-2008, 03:17 AM | #10 |
Rep 1,104
yea, my sister's e92 had two limp modes so far. just got it fixed.
the engine repair diag said the following "grooves worn in intake camshaft ledge. interr. fault memory. fc 2A82 and 3100. as per SIB 11 02 08. replaced intake camshaft ledge and ring because of wear"
2007 E90 335i JB
2010 E90 M3 JRB |
07-28-2008, 09:10 AM | #11 |
Rep 105
Everyone who's replied so far with stock limps seems to have had parts failures. FWIW, my untuned 335i has 6,000 very enthusiastic miles on it and has never limped or thrown a CEL.
Glad I'm not superstitious or I'd be nervous posting this... |
07-28-2008, 10:42 AM | #12 |
Rep 1,288
Drives: 135i
mine wasn't due to parts failure, it's due to hot oil/coolant temps....which are caused by driving a bimmer like a bimmer
07-28-2008, 10:34 PM | #15 |
21
Rep 384
I've had more limps stock then modded (3 - 0), two of those were for the same problem (fuel pump), last one was something to do with the tranny (Software Update fixed it)..
07-29-2008, 01:15 PM | #16 |
Rep 129
Drives: 2017 430i Cabrio
I have had one limp mode issue in my un-modded ride which was due to a turbo failure. The turbo was replaced and it runs fine now.
2017 430i xDrive Cabriolet Retired: 2007 335xi Sapphire/Terra Premium Retired: 2006 325i, Premium |
07-29-2008, 02:55 PM | #17 | |
Rep 668
07-29-2008, 04:26 PM | #18 |
Rep 1,104
stock...
2007 E90 335i JB
2010 E90 M3 JRB |
