Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions BimmerCode
      03-10-2019, 10:27 AM   #1
phillyd2
Drives: 2020 M340i XDrive
BimmerCode
I contacted them and received the following reply:
"I can not tell if and when the G20 will be supported"
      03-20-2019, 07:32 AM   #2
88tuning.id
88tuning.id's Avatar
Indonesia
39
Drives: E39 520i Msport
what do you want to do with your car though?
Bimmercode seems to be still in developing state for Gxx chasis car. so the only option available here to code Gxx was through E-sys.
Get a local coder or remote coder to do it for you.
T
Instagram: @tafikhulafaa & @88tuning.id
      05-03-2019, 10:46 PM   #3
Arnieg
Drives: 2019 BMW Series 3
Bimmercode G20
I contacted Bimmercode and was told that the BMW 5 Series, M5 G30 would work for the G20. Has anyone tried this yet ??
      05-04-2019, 06:59 AM   #4
phillyd2
They are now showing the G20 as supported but the list of options is not very long.
https://www.bimmercode.app/cars/g20/
      05-07-2019, 11:03 PM   #5
Arnieg
Bimmercode does show the G20 as a supported car, but it’s not shown
As a selection on the connected side. Any thoughts??
      05-08-2019, 06:03 AM   #6
phillyd2
Don't have the new car yet to check but you can ask them directly
info@bimmercode.app
      05-08-2019, 09:07 AM   #7
Arnieg
Here's Bimmercode answer.
Hi,
please use the "G30" option to connect for now. This will be fixed with the next app update soon.
Schöne Grüße / Kind regards
Stephan Gauch
BimmerLink · BimmerCode
Stephan Gauch · Siemensstraße 7 · 72116 Mössingen · Germany
Can't decide to wait for update or do G30 option.
      05-09-2019, 07:43 PM   #8
SW19
SW19's Avatar
2456
Drives: 2016 Alpine White M2
Hi,
Stephan Gauch
It’s the same right now for the X7.You have to select the G30 and then you are able to code the options you want.I coded my X7 earlier this week by selecting the G30 and it works.I coded the ASS to remember the last user setting,so if you turn it off it stays off the next time you start the car.I also coded off the seat belt chime for the front driver and passenger seats.
      05-10-2019, 06:12 AM   #9
ian2828
United Kingdom
Drives: G20 M340i on order
Hi,
Stephan Gauch
I successfully coded the Auto Start Stop memory function on for my 330i by selecting the G30 option, as recommended by the developer while we're waiting for the G20 option in the Bimmercode app. I used the OBDLink MX+ and an iPad.
I did follow the instructions on the Bimmercode website to the letter, making absolutely sure there were no other bluetooth connections active and disabling wifi.
There does, however, seem to be a bug in the app. The developer asked for feedback and requested I click on 'support request' in the app so he could take a look at the logs. Since doing the coding, this now causes the app to crash so maybe it's advisable to wait for an updated version? The actual coding appears to have worked perfectly though.
      05-11-2019, 09:19 AM   #10
Arnieg
I too successfully coded the Auto Start Stop memory function on for my 330i by selecting the G30 option. I used the OBDLink MX+ and an iPhone 8. All went well and it was very easy. I noticed that the ASS light stays on for about 10 minutes after car is turned off. Total car shutdown seems to occur in stages over 10 minutes or so.
      07-13-2019, 10:02 PM   #11
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
ASCM, ASD, and DME are the same. Rest of the ECU's are different between G20 and G30 (Pre-LCI).
      07-22-2019, 01:59 PM   #12
2020g20
Drives: 2020 330i
Almaretto Does this piece of info apply to Esys coding only? Or are you saying if we use Bimmercode to connect to our G20 in the "G30" connection mode, the ASD programming will work? I know that connecting BC in proper G20 mode, ASD is not a supported option yet. Just trying to figure out if it can be done with the "G30" trick, or if Esys is necessary.
Thanks.
vicfalc09211.00
      07-22-2019, 11:26 PM   #13
Almaretto
Almaretto's Avatar
2374
Thanks.
Never used Bimmercode before. But, if you can code the modules mentioned on a G30 with app, then you can with a G20.
      08-12-2019, 05:40 AM   #14
Wiertelak
Drives: BMW 330 G20
Hi,
Any news if you can already code with bimmercode ?
Or maybe if there is any other app for coding for g20 available and which cooperates with VGate ?
      08-12-2019, 08:38 AM   #15
phillyd2
Any update on the "bug"?
      08-12-2019, 08:54 PM   #16
SigurWes
Drives: 2019 330i
All I want is enhanced Bluetooth (sms) enabled. It's a shame that BMW advertises it as a feature that's not actually on the car.
      08-27-2019, 08:36 PM   #17
serg1282
72
Drives: through
Just bumping this to let everyone know that more options are now available for the G20 from Bimmercode: https://bimmercode.app/cars/g20/
Poochie9104.50
      08-28-2019, 12:31 AM   #18
BigWagonFan
Drives: G21 330i xDrive
Did you try that?
I'm wary after learning how Carly was tricking their users listing options that were not possible to code: https://g20.bimmerpost.com/forums/sh....php?t=1641111
I hope BimmerCode can add Active Sound coding soon.
      08-29-2019, 09:49 AM   #19
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3452
Drives: 2020 M340i
2020 BMW M340i  [0.00]
Nice!
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com
Top M Client Advisor in New England.
      09-02-2019, 08:51 PM   #20
Who's on first
Who's on first's Avatar
Drives: A-10C
Just reach out to Almaretto
He can easily and safely do all you need, as well as suggesting items you may not know about.
Almaretto2374.00
      09-16-2019, 08:51 PM   #21
JayPichardo
BMW Client Advisor
3452
Drives: 2020 M340i
I tried coding my M340i and none of this stuff showed up
      09-16-2019, 09:23 PM   #22
Deltusurf
Member
Drives: Arctic White 650i, 2020 M340i
2013 BMW 650i  [0.00]
These were the options available when I connected to BimmerCode. Hope this helps.
g20
