VEI boost readings with AA AP & question
07-27-2008, 04:32 PM | #1 |
Rep 986
so installed digital VEI boost gauge.
when i start car...it reads 18 vacuum when i let of gas while cruising it reads 23 vacuum boost max reading on valet (stock) is 8 psi with AA Active Processor map 12 psi (3rd gear) i think i got as much as 13 psi on highway (will double check it) temp is 27 C first...are the numbers right i thought the AA AP was a 13.5 psi map i have the spearco IC, Helene filter and cat back btw. |
07-27-2008, 04:36 PM | #2 | |
Guest
Rep n/a
Drives:
07-27-2008, 05:09 PM | #4 |
136
Rep 1,954
Drives: 2020 X3M Competition
u are seeing some pressure drop due to the spearco fmic. it's clear that the active processor doesn't auto-tune for these situations like the latest generation of piggybacks available...
2020 F97 X3M Competition (current) - 2018 F80 M3 Competition - 2015 F82 M4 - 2012 E82 135i - 2010 E92 335i - 2007 E92 335i
07-27-2008, 08:02 PM | #6 |
49
Rep 347
I'm running AA exde too,I have msd stage 1 intake,ur catless dp's and agency power exhaust,I'm running 15 psi boost after 3k rpm.What map do you have on the exde?
07-27-2008, 08:14 PM | #8 |
Rep 970
On my VEI gauge... it reads -16 when I let off the gas. -8 @ a traffic light. At full boost.. I see a reading over 10.5. Is that right?????
When I cruise control.. it hovers +/- 1 or 2 |
07-27-2008, 08:39 PM | #9 |
Rep 986
the AA AP comes with a map similar to R07 for exede. it is suppose to be a peak 13.5/14 and sustained 13 psi.
i am seeing 12.5 peak and 12 sustained. max spike between shifts is 14. i agree it is likely due to pressure drop with FMIC. putting down 345 rwhp with 12 psi seems good to me. but i think it's time to take advantage of newer piggy backs with IAT control. |
07-27-2008, 08:40 PM | #10 |
Rep 986
07-27-2008, 09:03 PM | #11 | |
49
Rep 347
07-27-2008, 09:07 PM | #12 |
Rep 2,573
Drives: AW DCT M3
Everything looks ok except for when your @ a light... What RPM does your car idle at?
07-27-2008, 11:12 PM | #13 |
Rep 970
I'm not running any tune. I reset the gauge like the manual asked me to. It's stock ECU and everything.
My car idles around 700 rpm at the light. Do you guys think somethings wrong? |
07-28-2008, 08:42 AM | #14 |
274
Rep 6,510
07-28-2008, 10:33 AM | #15 |
Rep 986
07-28-2008, 10:52 AM | #16 | |
274
Rep 6,510
Here is a document I wrote that describes the best settings for the digital VEI gauge. click here |
07-28-2008, 01:01 PM | #17 | |
Rep 986
07-28-2008, 06:26 PM | #18 |
Rep 970
07-29-2008, 09:19 AM | #19 |
Rep 986
okay..i recalibrated it...got 13.4 peak boost. but it was cooler this morning.
i never knew how much i'd enjoy having a boost gauge! now rixeffects comes out with a better one! |
07-29-2008, 09:20 AM | #20 | |
274
Rep 6,510
Existing customers will get a LARGE discount. |
