BMW M5 F90 (2018+) General Forums Cosmetic Modifications    Damaged paint under OEM Spoiler.
      03-21-2019, 06:45 AM   #1
MCOMP
MCOMP's Avatar
199
Drives: 19' M5 Comp.
I am disappointed to find the paint damaged from Spoiler adhesive.
The betalink is advertised and designed to not damage paint but is not the case, The Pro spoiler location exposes the damaged paint and is noticeable from certain angles and lighting.
The BMW body shop could re paint trunk Lid but who would want that?! The Pro Spoiler looks amazing but I have to live with the waves in the clear coat now.
2019 MBB/Aragon M5C
M Performance: Exhaust Tips/Pro Spoiler/Rear Diffuser. H&R 11/11 Spacers ACG Carbon Kevlar Pads XPEL Front PPF Ceramic Pro Silver 20% Tints Instagram #m5comp
      03-21-2019, 09:50 AM   #2
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
It doesn't look too bad from the pic, but if you're OCD like me I'd just get it repainted. Wrapping the lid in a gloss black wrap would be a hard no for me.
      03-21-2019, 11:28 AM   #3
Simon H
Simon H's Avatar
876
Drives: M5 Competition
I didnt think the standard lip spoiler had Betalink, it was just doublesided 3m tape ?.
      03-21-2019, 11:35 AM   #4
trev230
trev230's Avatar
351
Drives: 2022 M5C
The standard spoiler definitely has beta link. I know because I took mine off and installed my new spoiler myself. I did not use the beta link on the new spoiler because of the concern damaging the paint and removing it down the road.
      03-21-2019, 12:09 PM   #5
Simon H
Simon H's Avatar
876
Did you get the Betalink off ok Trev ?
      03-21-2019, 01:08 PM   #6
trev230
trev230's Avatar
351
Drives: 2022 M5C
Yes but I was very reluctant to use any type of machine to do it. I soaked it good with a detail spray and rubbed it with my fingers and used a little bit of heat on it. It took me about 30 to 40 minutes of rubbing it with my fingers.
For the new spoiler (M pro) I cut strips of superstrong 3M body panel tape to fit the spoiler. Some areas I had to double it up. It’s stuck on there real good..you cannot get the spoiler off unless you were attempting to pry it off using some type of tool.
      03-21-2019, 01:43 PM   #7
Simon H
Simon H's Avatar
876
Thanks for the reply Trev,
Good info . Im going to have a go with mine, hopefully this weekend, if time allows. Ive got my arsenal of removal tools, from hairdryer to nylon line and sticky goo remover. Will have a look when its off to see how i want to attach the pro spoiler, be it Betalink, or 3m tape, as ive got both to hand.Hoping for a good outcome. I know i could take it to the dealers, but wheres the fun and satisfaction in that ?
      03-21-2019, 03:04 PM   #8
MCOMP
MCOMP's Avatar
199
That video is misleading, It is much harder to remove spoiler and residue than depicted.
2019 MBB/Aragon M5C
Simon H876.00
      03-21-2019, 03:05 PM   #9
MCOMP
MCOMP's Avatar
199
I'm with you, definitely a DIY.
2019 MBB/Aragon M5C
Simon H876.00
      03-21-2019, 05:50 PM   #10
Simon H
Simon H's Avatar
876
I did think this. Im grateful for INDs videos, but they somehow always seem to be, to good to be true ?.
      03-21-2019, 08:16 PM   #11
MCOMP
MCOMP's Avatar
199
The video seems edited to show complete ease of Spoiler removal, Hey! lets sell some Spoilers! LOL Helpful video however.
2019 MBB/Aragon M5C
      03-21-2019, 08:27 PM   #12
Spoolin Montego
Spoolin Montego's Avatar
604
Drives: 16 m3/20 x5m/23 m3
oem small spoiler should not be installed with beta link. I have removed mine from my comp and my buddies non comp and they were both 3m taped on. Came off quite easy. BMW loves that betalink stuff for the cf parts, I would never use it. GL getting it off ever.
Simon H876.00
      03-22-2019, 12:01 AM   #13
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
The Original trunk lip spoiler is held by double sided tape. But BMW apply the adhesion promoter so it stuck on it very good.
I have done a few on F90 and G30.
Taking them off are easy, cleaning it up is a bitch.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
Simon H876.00
      03-22-2019, 02:29 AM   #14
Simon H
Simon H's Avatar
876
r33, Thanks for the reply,
Could i ask if you have seen, or had any problems of the paint being marked underneath the OEM spoiler, the same as the OP ?.
r33_RGSport12967.50
      03-22-2019, 02:32 AM   #15
Simon H
Simon H's Avatar
876
Was the spoiler you removed on an F90 M5, and did you use the procedure as in the video to remove ?, thanks for your input.
      03-22-2019, 06:45 AM   #16
MCOMP
MCOMP's Avatar
199
I'm thinking now that Carbon Fiber Spoiler upgrades are installed at Port with Beta Link and that factory installed non Carbon spoilers might be installed with the tape. If a non Carbon flies off, no big deal but if a Carbon flies off well then....... Thats my logic.
I'm temped now to open up a case with BMW warranty because clearly my damage was caused by the installation glue used to mount my $730 one inch Carbon Fiber spoiler.
You can clearly see the paint damage where the spoiler was that is now exposed with Pro spoiler. Which was not caused by the removal but by the glue used.
2019 MBB/Aragon M5C
      03-22-2019, 06:53 AM   #17
Ever34
Drives: F90 M5
Holy crap. That looks way worse than the first picture. I assume it's just the clear coat? If it is, there is a chance it could be attenuated with some paint correction. Wet sand and polish.
If not I would push them for a repaint. A good shop can paint match with no issues.
Simon H876.00
      03-22-2019, 07:16 AM   #18
Simon H
Simon H's Avatar
876
You can clearly see the paint damage where the spoiler was that is now exposed with Pro spoiler. Which was not caused by the removal but by the glue used in my opinion.
Wow !!,
That looks terrible. Is the photo a true reflection of what you are seeing ?, surely it cant be that bad ?.
      03-22-2019, 07:30 AM   #19
MCOMP
MCOMP's Avatar
199
BMW body shop tried wet sand but to no avail. I'm just not comfortable with a repaint, I've never had a good experience with paint matching on my cars. But I might have no choice.
2019 MBB/Aragon M5C
      03-22-2019, 07:34 AM   #20
Ever34
Drives: F90 M5
Got it. I'd be nervous also if it was a door or fender but less so with the top of the trunk. . Hope you sort it out one way or another
      03-22-2019, 07:34 AM   #21
Simon H
Simon H's Avatar
876
This might be way out there for you, but, you could fit the OEM spoiler back on, to cover the paint, and fit the pro spoiler too, as they both fit on the car at the same time ?. You could then claim you have double downforce, and a unique set up ?. When i got my spoiler, my dealer and i unpacked it, and offered it up to a car in the showroom, and we said, we could leave the standard one in place, and fit the M Pro as well. Just a unique thought
      03-22-2019, 07:35 AM   #22
MCOMP
MCOMP's Avatar
199
It is hard to photograph.
2019 MBB/Aragon M5C
m5post
