03-28-2019, 12:33 PM | #1 |
Rep 71
Charge pipe- Action class lawsuit against BMW
Hello Fellows BMW owners.
Do you know if there is any action class lawsuit against BMW related to the charge pipe issue? It has been proven that it will withstand stock boost pressures initially. But after age and repetitive heat cycles, the plastic becomes brittle and is prone to failure right where it connects to the throttle body. I had to replace at approximately 17,000 miles, due to failure right where it connects to the throttle body. Do you know how many people have gone through this! Just praying for an Action class lawsuit against BMW. |
03-28-2019, 01:42 PM | #2 |
1717
Rep 1,899
And then what? a few years down the road you get a check for 50 cents in the mail and the lawyers pocket the rest?
Just spend 200-300 now and get an aftermarket charge pipe chalk it up as preventative maintenance. They're so cheap it's not even worth the hassle |
03-28-2019, 01:56 PM | #3 | |
Rep 71
Unfortunately, that was not the case with one of my buddies. When the charge pipe exploded the car suctioned a piece of debris and injure one cylinder. For the people that are not in to car’s this is something that they don’t look at all.
My issue is that my car was only 17K miles when it happened. If I change my charge pipe they will void my warranty. Quote:
03-28-2019, 02:04 PM | #4 |
Rep 20
Is the repair/replacement not covered under warranty? I understand your friend's situation, but if they replace yours with a new one, it would hopefully last until you are out of warranty and then you can go aftermarket.
03-28-2019, 04:27 PM | #5 | |
Rep 7,429
My opinion is just wait out the factory warranty till like the last month and then swap out to an aftermarket charge pipe. Like others have said a class action law suit would probably net you zero money since it has happened to so many people.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
03-29-2019, 09:04 PM | #7 | |
Rep 7,429
So if you get an engine failure maybe the dealer can pin it on your charge pipe leaking boost, interfering with the sensor idk. Like I said this is a big grey area subjected to alot of interpretation and arguing.
03-30-2019, 04:12 AM | #9 |
Rep 7,429
03-31-2019, 11:33 AM | #10 |
Rep 3,256
Adamantly against any sort of class action. It won’t actually change anything and as pointed out earlier, that 50 cent check that goes to you and the million dollars that goes to a lawyer isn’t my idea of solving the problem.
04-01-2019, 11:15 AM | #11 |
1287
Rep 1,675
Do you own bmw stock? Why would you be adamantly against it, if it forces the company to uograde their charge pipes on future builds thats a good thing no?
04-01-2019, 11:35 AM | #12 |
Rep 2,526
Given that its likely the majority of the N55 chargepipe failures occurred on either modified cars or track-driven cars, I doubt there is a large enough base to even consider a class action suit. And I'm sure the BMW lawyers will bring up this fact in court. If they can prove the majority of the plaintiffs were using the vehicles in extreme conditions (track), or have modifications, the class action lawyer will have no chance of winning. Theres just no money in it for anyone involved.
So you have a couple options here. Ride it on the stock chargepipe until it fails, and replace it under warranty. Or replace it now for a couple hundred bucks and call it a day. |
Poochie9104.50 |
04-01-2019, 10:10 PM | #13 | |
Rep 3,256
Frankly I think it’s ineffective. If anything, warranty claims will be what sways an upgrade. If the warranty claim costs outweigh a part upgrade, then they’ll likely upgrade a part. If it doesn’t, it indicates there isn’t enough support to start a class action anyways. If I had a problem with a charge pipe that keeps blowing off, I would honestly probably go small claims first. Far more likely to win a judgment that isn’t a complete waste of time. Most class action lawsuits really just results in a win for the lawyers. If this was something more safety oriented that results in injuries or perhaps an issue where BMW was committing fraud I would be more accepting of a class action. Also I’m not very familiar with the B58 motor, but it might have been already addressed. |
04-02-2019, 04:13 PM | #14 | |
Rep 5,728
Drives: 2019 M2 Competition
04-02-2019, 06:09 PM | #15 | |
Rep 7,429
IDK imo I really don't think a class action law suit for broken charge pipes will go well, it could be pinned on so many other things. Plus look at subaru's EJ257 it has ring land issues with the piston causing alot of motors to go, but subaru is really good at replacing them to keep complaints down just like what bmw is doing with the charge pipe. Yet no one iirc has taken subaru to court because they probably know that they can pin the issue down to oil change, harsh driving etc.
04-02-2019, 06:17 PM | #16 | ||
1120
Rep 1,644
04-02-2019, 07:12 PM | #17 | |
Rep 7,429
Financial loss out of warranty wouldn't count since stuff breaks out of warranty all the time. If that was the case everyone with an old car can sue because it broke down...
04-02-2019, 07:21 PM | #18 | |
Rep 5,728
09-28-2020, 01:54 PM | #20 |
Rep 1
First of all, dude the pipes must be included in the warranty. Second of all, in case you get to use any kind of boost, any kind of tune ups, the warranty runs out. In stock they run for at least 100k km. Which is not bad at all actually. And even if you decide that it is a problem from the factory, you must turn to a certain ''great'' court, not to the local judge, you know that? However i do not consider this a great reason to get to the court. As an example, i can tell you a case of a friend of mine. He filled a suit of libel California, against a BMW dealership manager. It was at the local court, the guy lost it and had to pay the manager a pretty insame sum of money. You just don't go against these kind of companies.
09-28-2020, 02:02 PM | #21 |
844
Rep 1,962
Noting how the intake pipes on previous naturally aspirated M3 used to dry rot, 100km is pretty impressive.
I'm guessing Labour is the main cost in swapping them as it looks a bit fiddly. |
09-29-2020, 05:46 PM | #22 | |
Rep 568
Do you know why the N54 charge pipe now has a 10 year / 120,000 mile warranty? It's because of the number of lawsuits BMW had to pay out for part failures. Same goes for the N54 fuel injectors (10 year / 120,000 miles), the N54 HPFP (10 year / 120,000 miles), and the N54 wastegates (8 years / 82,000 miles). We want this problem solved, it is going to take lawsuits. |
McGary911472.00 |
