Which breathing apparatus for my little piggy?
07-31-2008, 08:38 AM | #1 |
Rep 822
I have recently sold my SSTT and will be investing in a V3 or JB3 in the coming month.
With the SSTT I just ran with a BMC drop in filter. However, I know that I will need to do something else to get the most out of either the Procede or Juice Box piggies. I intend to either use a K&N dual cone setup or a Helene drop in with RPI scoops. Any thoughts out there about which would be the best solution. In order of importance, I am looking or the following from my setup: - Reliability - Stock apprearance or quick/easy to bring back to stock - Max power (biggest bang for my buck - or pound sterling to be more precise ) - Least expensive Thoughts please . . . . . |
07-31-2008, 08:48 AM | #2 |
36
Rep 1,658
I recently took the same root. Coming from SSTT for more then 15k and BMC panel filter to a V3 with Spectre Dual Cones. All I can say that the Dual Cones are well worth it with a powerful tune. The change is imidiate from the stock air box, as well as imroved throttle responce. And of course the SOUND! Do it, you won't regret.
07-31-2008, 09:06 AM | #4 |
Modder Raider
753
Rep 8,633
Drives: M3
Get the RPI scoops with the HP filter.
Don't suck in any hot air!
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
07-31-2008, 09:47 AM | #5 |
Rep 6,608
There you go. You got both opinions, now if you would like we could have the less cold air vs more hot air discussion.......
I install all tunes, intakes, o2 simms, and most cosmetic mods. PM me for a quote. |
07-31-2008, 10:40 AM | #6 | |
Modder Raider
753
Rep 8,633
Drives: M3
I do agree that the stock air box is extremely restrictive, but for me, it's working great. The pros of having the scoops with the Helene Perfromance filter: -You have the engine compartment looking stock for our lovely BMW technicians. (We love them sooo much ) -You are sucking in cold air from outside the car instead of hot air from the engine. -You don't have to worry about the filters slipping off the piping (like some have mentioned) -You don't have to clean the panel filter as much as the cone filters since the air and dirt isn't blowing directly on the panel filter.
07-31-2008, 10:45 AM | #7 |
Rep 8,091
On turbo cars sucking in hot air is not an issue because when the air is compressed by the turbos the air is heated
You want to get as much air as possible so I would say RPI scoops with some dual cones |
07-31-2008, 10:52 AM | #8 | |
Rep 6,608
07-31-2008, 11:09 AM | #9 | |
Modder Raider
753
Rep 8,633
Drives: M3
Colder air entering the vehicle provides better results-period! This is why a car dyno'd on a cooler day provides better results than a car on a hotter day. If the temp of air entering the car didn't matter then both days should yield the same results.
07-31-2008, 11:19 AM | #10 |
NA Convert
Rep 190
Temperature relates to density, density is what relates to more power. However, the hot air is cooled after induction by our intercooler, if you want colder air, get a air to water intercooler.
"Ex Vi Termini : With Strength Comes Limits" |
07-31-2008, 11:35 AM | #11 | |
she likes the flavor......
85
Rep 1,622
E92 Montego Blue silfa718 ..::STETT CAI|ADVAN RS|WAGNER FMIC|MS DP|VANGUARD|PROCEDE|FORGE DV|BMS OCC|KWV2|MICHELIN PSS|OOS::.. |
07-31-2008, 11:53 AM | #12 | |
Rep 494
Mr.5, not sure if this was asked already or posted in seperate thread....but I thought you were going to dyno with the HP filter + scoops? if you did, what did your testing conclude power wise? I am sure there was a good bit of difference with or without the scoops. also, do we still have a legit vendor for the scoops? sorry for the |
07-31-2008, 12:39 PM | #13 | |
Modder Raider
753
Rep 8,633
Drives: M3
I've sent him numerous PMs, and he hasn't come through for me. He was the one that initially contacted me, so I took him up on it. Eugen, what else do I need to do for you teo send the filter my way? I believe that I have already PM'd my address to you a couple times.
07-31-2008, 12:59 PM | #14 | |
63
Rep 1,642
07-31-2008, 02:35 PM | #15 |
Modder Raider
753
Rep 8,633
Drives: M3
lower intake temps help.
07-31-2008, 02:56 PM | #16 |
Rep 548
lower intake into the engine helps. I think the argument has always been that with a less restrictive intake (ie dual cones), the turbos don't heat the air up as much (since the incoming air will have a higher pressure due to less restrictions). The turbos don't have to work as hard, so even though they are sucking in higher temp air from the engine bay vs. outside air, by the time that air gets to the intercooler, it is the same or lower temp.
If the air that gets to the intercooler is hotter with dual cones than stock airbox, then I agree with you completely. |
07-31-2008, 03:17 PM | #17 | |
Rep 494
I like the idea of keeping the stock airbox intact, I also wash the engine bay so covering up filters and such is not an option for me....better flowing filter like HP + scoops sounds like the way to go IMO - less headaches all around. |
