04-17-2019, 07:33 PM | #1 |
Rep 13
new wheels
hey guy's i'm new on the forum
my name is Benny and i drive a f10 520D lci model from 2016 i would like to buy new wheels... i realy love the JR 28. these only come in 8.5Jx20 and 10Jx20 i have read sooooooooooooooooooooo many forums alreay that i can't be sure any more, hence my next question if i buy the JR 28 what would be the perfect flush offset ? i realy like when the wheels are even with the fenders(like not sticking out but also not going inwards) i think it is called aggressive stance ? or flush set up ? (correct me when i'm wrong) so if i buy 8.5Jx20 for the front and 10Jx20 for the rear what would be the best offset for me ? i also realy like strech tires (notting extreem, but realy realy subtle) for that i would put 225/35R20 on the 8.5 and 255/30R20 on the 10J would that give me a little strech ? my car is lowerd on KW V1 also prio is no rubbing(rather 1 or 2 mm inwards and 100% no rubbing then 1mm more out and it rubs on the fenders) atm the shop recommends me 8.5J Et 30 10J ET 30 should these be changed or not ? |
04-18-2019, 09:38 AM | #2 | |
Rep 64
Im running 21 in Rohanna RFX7 thats 9 inches wide in the front with an offset of +20 with 245/35/21 tires. Im not super slammed to the ground but i am on coilovers thats at about the 18 setting for rebound and compression; it isnt a terrible ride but it for sure is stiff. (i prefer it that way) I dont experience any rub at all. so for the front your fine. the back is 10.5 wide with a +30 offset wrapped in 285/30/21 tires. I tried to go with a super low stance like people who run a tucked setup but its a nogo with my offset. It rode really nice but on hard changes in the road it scraped. So i had to raise it about a half an inch. If it was +35 instead of +30 i could of gotten away with it being that low beacouse at +30 it scraped literally on the VERY EDGE of the tire. with that being said. The fitment is VERY flush with the tire tucked slightly ANY offset higher than +30 i have can tuck without rubbing with some camber. (not ridiculous camber like instagram boys, but a nice classy negative camber) to use my setup compared to yours your 10 +30 equals to 10.5 +36 which will clear with some camber. +40 will clear no issues without slight camber but may look a teeny tiny bit tucked. yout 8.5 +30 equals 9 +36 which will clear no problem being i can clear with a wider wheel and lower offset. Tires are important as well. fatter tires may not tuck as my setup did so keep that in mind. My setup is literally on the line for flush and low without rubbing; Ill take some pictures and report back as well. Hope it helps! Last edited by Flyguyin23; 04-18-2019 at 09:46 AM.. |
04-18-2019, 10:09 AM | #3 |
Rep 13
thx for the reply !
so if i'm reading your stuff here i should be able to go 8.5J ET 20 (they won't go lower then 20) on front ? won't that stick out ? maybe take ET 25 ? 10J ET 30 would be good then ? since yours rubs a little ? or should i go for 10J ET 25 ? |
04-18-2019, 10:28 AM | #4 | |
Rep 64
Im able to go +30 due to the German motorsport shop i go to installed and aligned my setup then drove it and made small adjustments. +35 would be less of a headache imo. If you have a shop you actually trust than the +30 look is SOOOOOO dope. its super flush with a teeny tiny bit of poke (thats how i like it beacouse im on coils and not bags) it also limits to how far you can slam it to the ground. Ill send you photos first thing; stay posted. Ps. Modded F10's are SUPER rare beacouse the young kids resonate to 3 and 4 series while the dads and suits drive 5 and 7 series. When a F10 is done right it brings about alot of attention and turns heads. So i really hope you get the look you want! |
04-18-2019, 01:00 PM | #5 |
9167
Rep 14,521
Flyguyin23 is familiar with my setup but I wanted to share my custom setup as well to give you a little more insight on my offsets as well as a F10 sitting on KWV1 coilovers. I was able to perfectly get the offsets needed for my aggressive stance
21x9.5 30mm and 21x11 38mm rears on 255\30r21 and 295\25r21 do a little more research before pulling the trigger on your wheels
04-18-2019, 01:43 PM | #6 | |
Rep 64
lsturbointeg9166.50 |
04-18-2019, 03:11 PM | #7 |
Rep 13
dude those rims
thx both of you for the info so far... i've looked up alot of the topics here, but most seem to drive an 9 and 10.5 wich gives different offsets ok so if i get you ... 8.5J ET 20 should be ok for flush ? maybe even spacer ? 10J ET30 should also be verry good for flush ? how do you like the strech on my tires ? 225 and 255 ? to little strech to much ? |
04-18-2019, 05:34 PM | #8 | |
Rep 64
I had a bad experience with stretched tires so I dont run that route any more. 255 on a 10 wide is a hard stretch. To be safe 265-275 would be best in the back. As far as front 225-235 is where you wanna be. Last edited by Flyguyin23; 04-18-2019 at 06:04 PM.. |
04-18-2019, 06:40 PM | #9 | |
9167
Rep 14,521
With the specs you're giving hopefully remmib will chime in to say yes or nay
04-18-2019, 06:43 PM | #10 | |
9167
Rep 14,521
BTW Sylfer, do you have a picture of those wheels?
04-19-2019, 04:13 AM | #11 |
Rep 13
so i should keep the ET 30 front and rear like the shop suggests ? and use spacers ?
or should i change it maybe just a little like Front ET 25 and then use smaller spacers ? or go for front Et 20 and work with smaller spacers ? aren't spacers like bad for your car ? or only in big sizes ? the rear i'll leave at ET 30. Last edited by Sylfer; 04-19-2019 at 04:23 AM.. |
04-19-2019, 08:20 AM | #14 |
Rep 64
More than likely this won't be a one shot move. Its gonna take some experimenting. I was fender to tire at first bit rubbed on hard change of the road. It was fender to lip but it gave me no room for my suspension to absorb some hits. So now In the back I am exactly one finger high and in the front its fender to tire. I don't rub at all and and lock the front wheels either way without rubbing
ezaircon4jc4549.00 |
04-19-2019, 11:01 AM | #15 |
Rep 13
nice looking rims there
thx for the pictures i'll probly just keep it then and add some spacers in the front so 8.5J ET 30 and some spacers... and 10J ET 30 should be a flush or near flush !!! when it's all mounted i'll post some picture's with info and sizes ! |
04-19-2019, 02:04 PM | #16 |
9167
Rep 14,521
Definitely post some pictures
04-19-2019, 03:10 PM | #17 |
1571
Rep 29,202
I assume you will lower the car quite a bit since you're getting kwv1. That mean the fronts camber in a far bit. So with 8.5" front and only 225 tires a rather go et20 than et30.
04-20-2019, 08:07 AM | #19 |
Rep 64
04-20-2019, 08:27 AM | #20 |
Rep 55
Welcome friend I'm running Vertini RF1.3
F20x9 + 32 on 255/35/20 R20x10.5 + 42 on 285/30/20 Sitting on H&R lowering springs might do bc coilovers or kw or I might bag it next year. Flush front and rear and no rubbing. |
04-20-2019, 09:30 AM | #21 |
Rep 13
ok starting to get there
so i should take 8.5J et 20 and 225/35 R20 for minor strech look(maybe spacer for flush ?) or go for ET 25 and use spacer to get the look i want ? 10J ET 30 and 265/30 R20 for same strech look(maybe spacer aswell if it's realy inwards) ot go for 35ET and use a spacer to make sure there is no rubbing ? and get the look i want ? or keep the 255/30 R20 ? going for same strech fornt and rear... tires are nankang ns2 for strech ? this will be a better fit ? Last edited by Sylfer; 04-20-2019 at 05:57 PM.. |
04-22-2019, 05:38 AM | #22 |
Rep 13
guy's any last tips ?
should i got for front: 8.5J ET 20 ? will this maybe need a small spacer ? for flush setup ? and set it to my own prefrence 8.5J ET 25 ? and use spacer to set it what i like back 10J ET 30 ? will this give change on rubbing when my car is loaded 10 ET 35 and use a small spacer to set it whatever i like ? i definitely don't want rubbing or use BIG spacers |
