BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis 2018 540 D xDrive Resonating sound at speed.
      05-01-2019, 10:38 AM   #1
THEX5BEAST
Drives: 2017 X5D X Drive/ 2018 540D M
This is a new garage queen for us. Sits next to the X5. I've noticed a resonant sound (humming like a ghost might) mainly at speeds over 70. It came with Goodyears on 19" Msport rims. The car has every option BMW offers, DHP included if it matters. Dealership can't isolate it but does recognize the problem and has documented it with corporate. Doesn't feel its wheel bearings. I lean towards these Goodyear ROF's as the culprit. A Michelin guy myself. Anyone else with a G30 having this problem? It has 3,500 miles on it. Love the car otherwise.
      05-01-2019, 10:03 PM   #2
aadum
aadum's Avatar
Croatia
80
Drives: 330xd e92 ,520d f10, 540i G30
try mounting other wheels from dealership or if you have someone with similar car and test it....
      05-02-2019, 03:30 PM   #3
THEX5BEAST
Thanks for the suggestion. The dealership did just that (so they claim) with three different cars with three different tire brands. The foreman did say the michelins did reduce the sound slightly. Not sure I'm ready to trash brand new Goodyears to give it a try yet......Took it for another long country drive without any destination in mind today. Such a pleasure to drive (even with the odd humming). This is my 12th BMW and by far the best.
      05-14-2020, 08:00 AM   #4
THEX5BEAST
Problem still exists. Have about 8,000 miles on her now. Swapped out the Goodyear ROF's for Michelin PS4's NRF. Problem still exists. Complaint was sent to corporate w/o a response in about a year. Poor service considering that this is my 11th BMW. Car rides much better on the PS4's but the sound is ever present at the same speed range. Drove a 530 loaner today. Smooth and quiet. Wonder if its in the x Drive? diff fluid low? had 3 alignments preformed just to rule it out. Absolutely love the car other than........ any suggestions?
      05-18-2020, 04:09 AM   #5
harjbns
Drives: BMW G30 540i xdrive, F30 330i
I can second you with his, I have the same sound issue on my 540i xdrive, while driving over 60mph. I have a 20inch setup with extreme contact dws06, and have ran it with goodyears before. Dealer cannot isolate the problem as well.
      05-19-2020, 09:56 AM   #6
ski1972
Drives: M5 finally
Does the noise change with the RPM under the load ( transmission engaged ) ?
Mine does that and is 100 % fuel pump ,
I also reed someone have noise from oil pump .
      01-24-2021, 06:40 PM   #7
SC300T
Drives: 13 E92 M3, 540xi, 535ix GT
Anyone have any updates on this? I've just bought a 2017 540i xdrive with 19" Goodyear Eagle Sport AS Runflats, and I've got a howl between 78mph and 84mph. Sounds like a tire or wheel bearing.
      01-27-2021, 02:46 PM   #8
SC300T
Mine does not change at all. If you downshift into 5th or 6th it still does it, and also does it going up hill or coasting downhill. On mine the peak sound is centered around 80mph and you can just barely hear it at 75 and 85. It basically screws up any travel where the speed limit is 70 or 75 because the flow of traffic is centered on 80.
I'd describe it as a higher pitched howl or a lower pitched whine.
      04-11-2021, 12:10 PM   #9
THEX5BEAST
Resonating/howling sound
Still have the sound. More noticeable at higher speeds but once identified its pretty much all speeds. Have a little less that 10k on her now. Replaced the GY RF's with PS4's. Still there. Dealership claims its the diesel whine. I've owned 4 diesels and three with Xdrive. None of the others had/have this issue. I've had her aligned 3 times to different specs as well. No difference. 540d x drive m sport with 19"' square setup OE rims. Loving the car other than.........
      06-13-2021, 01:25 PM   #10
GRLNE
Drives: BMW 540i Touring xDrive
Has anyone had any luck getting a resolution?
I have the same booming/droning resonance noise on a 2021 G31 540i on 19" non-runflats. It's very noticeable from 25mph, but this low frequency resonance increases and becomes physically unpleasant at motorway speeds.
I've owned several 5 series from new, always M suspension, some with runflats and some not - so I'm very familiar with how they ride and sound, but they've been practically silent in comparison to this. It's such a shame because in every other respect the car is fabulous.
I noticed that there's a thread with what sounds like the exact same problem as mine on X5s and they now have tuned 'vibration absorbers' fitted to the front suspension to resolve it. There's a video here and pictures of the parts fitted to dampen the noise (long thread, but worth reading if you have this issue): https://g05.bimmerpost.com/forums/sh....php?t=1698738
I just wondered if anyone has managed to get a satisfactory solution or outcome on G30/G31?
Thanks
      01-17-2023, 05:33 AM   #11
KAramis
KAramis's Avatar
United Kingdom
Drives: BMW G30
I have some humming noise in range from 20-25 mph, running 19 ROF Goodyear.
Guessing that sound can be from 3mm thread left on them and uneven wear maybe. Going for new tyres next week in hope that will fix it.
      01-17-2023, 08:17 AM   #12
TEF
109
Drives: 16 X3 28d/18 540d xdrive
2018 540d xdrive  [0.00]
2016 X3 28d  [0.00]
If this noise issue seems a mystery to US dealers, I would think that BMW would have ample data on this considering the huge number of vehicles sold outside of North America where diesels are the norm rather than the exception.
      01-23-2023, 04:11 AM   #13
bau33
Drives: G30
Based on my experience with a previous vehicle - i would point to one of the wheel bearing. I had a similar situation which took months to figure it out. At the end was one of the wheel bearings - with a strange behavior - no play, no grinding noise- only a resonating sound at above 70-80 mph - impossible to find it on the stationary vehicle. I found the issue only on test drives with 3 mechanics in the car - trying to find from which part of the car the sound was coming. Try this and let us know the results
      02-05-2023, 08:50 AM   #14
pclijsters
Drives: BMW 530e xDrive (G31)
Same issues in Europe... I have a brand new G31, 530e xDrive. As it is a plugin hybrid I can test it without the gas engine running. I can report that in my case it is not the engine. Both running the engine and in full electric mode the noise starts at about 100kmh (60mph) and peaks at 120kmh (75mph). I have Michelin Spot Pilot 4.
Sales advisor told me to book a test ride with the head mechanic. According to him small chance it is the tires. We had some snow couple of weeks ago. He says it could be part of the undercarriage that got loose due to build up of snow. That part is now vibrating because of wind at higher speeds.
Hope they find it soon and we are not of on some wild goose chase. I you guys make any progress, please share. Can help with pointing these mechanics in the right direction :-) Thx
      04-30-2023, 12:51 AM   #15
bau33
Drives: G30
Any news on the topic- i have same issue...i have changed the tires - same humming noise...
5post
