      05-04-2019, 02:30 PM   #1
mghmghmghusa
MG
Drives: 2019 BMW X5 40i
Trailer brake controller wiring
My 2019 X5 has the factory-installed towing option, which includes an under-dash connector (pictured) for plugging in a 4-wire trailer brake controller. (I use a Tekonsha Prodigy P2, identical to the BMW dealer-installed controllers sold for earlier X5's.)
Problem: no one, including BMW, sells the plug that fits into this connector. The BMW dealership guy is knowledgeable, super-helpful, and has called and emailed various departments, but the bottom line is that BMW doesn't sell a plug or brake controller for 2019 X5's.
So (like the old song) I'm all dressed up with no place to go. I've checked with Pollak (maker of the factory-installed trailer wiring receiver on my X5), eTrailer, and others -- none has a plug for this connector. So (as a last resort before I cut it off the connector and start splicing wires) I'm checking in to see if anyone has any other viable suggestions.
Tenac4537.00
      05-04-2019, 02:41 PM   #2
LexxM3
LexxM3's Avatar
1698
Drives: E46M3, G05X5
2019 X5  [0.00]
Another WTF. Following ...
Wild Blue3682.50
      05-04-2019, 08:18 PM   #3
russelldav
456bhp for breakfast
russelldav's Avatar
425
Drives: 2019 X5 50i
I assume eventually someone will start to make a Connector for this and sell a adapter / harness. Can't believe it isn't available yet.
      09-19-2019, 06:45 PM   #4
sptucker
Drives: 2012 BMW E92 M3 2019 X3 M40i
Any update on this?
I identified the under-dash connector as BMW 1378134-01. I was able to find a duplicate on a French Amazon site, but no male version of the connector. I can find no other information on the connector.
I can confirm that the connector has +12V, GND and stoplight/brake pedal wires. I'm assuming the 4th wire goes to the trailer brakes.
Has anyone used this connector or cut it off and used the wires for their trailer brake controller?
      09-19-2019, 07:22 PM   #5
Kotkot
Drives: M4
I use trailer with surge brakes, but curious to know if solutions is found.
      09-19-2019, 07:37 PM   #6
smovva
Drives: G05 2019 X5
This seems a common connector used by BMW for many years on its brake lights (find old ones on ebay etc with BMW part number 61131378134). But what you need is the mating connector. There should be an AMP part number on the one on your car just above the BMW number (see attached pics). Thats the Amphenol part number and once you have that, you should be able to search for the mate on the Amphenol web site. I wish I could help more but the pictures are too blurry for my eyes to make out the Amphenol part number! Good luck!
Update: Amphenol P/N is AMP 1-828 819-1; its a restricted part so Amp doesn't sell it or its mate or a datasheet to general public. The male portion *seems* to be same as that used on the blower motor resistor in old BMWs but seems to be intended for a PCB board mount. Perhaps you can buy a used/broken blower resistor and take it off? https://www.google.com/search?q=64118372775
TSMC55126.50
      10-16-2019, 05:02 PM   #7
sandcruiser
Drives: X5
Want to bump up. I am picking up a 14 ft tandem trailer. The dealer can install an integrated brake controller for the electric brakes. Anyone have an update for the the correct plug or should I have the dealer install a new harness?
Wild Blue3682.50
      10-17-2019, 08:49 AM   #8
rparnel1
21
Drives: 2014 328d
I also have the tow package, but no way to connect a standard brake controller. Ended up using a wireless brake controller. Not cheap, but does work. BMW sells one and so does Curt and Tekonsha. I like the Tekonsha Prodigy wireless ($280), which is believe is what the BMW actually is
      10-17-2019, 08:59 AM   #9
Tenac
Tenac's Avatar
4537
Drives: All
Awesome find, I just started shopping for trailers and didn't remember to check this !!!!! I will have to look into this as well.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0
2019 718 Cayman Base
2015 M235 Manual
On the list for the M2 CS
      11-10-2019, 08:16 PM   #10
Indy Jim
Drives: BMW X5
Has anyone just cut the wires and made a hardwired connection?
jeff.m3700.00
      11-11-2019, 05:28 AM   #11
homerrr
homerrr's Avatar
Drives: BMW G05
I have the towpackage and used this wireless controller. Worked ok as far as electrical controllers go.
CURT 51180 Echo Mobile Electric Trailer Brake Controller with Bluetooth-Enabled Smartphone Connection, Proportional https://www.amazon.com/dp/B07JQ99SDD..._YuuYDbV5B40N0
I asked the sales person and service department several times and no one ever indicated there was a connector already for a controller under dash. I would very likely have used the wires instead. I'm also very curious to know if it worked for anyone.
      11-11-2019, 08:14 AM   #12
gofast182
Drives: 2020 M340i xDrive
I also use the Tekonsha Prodigy Wireless and wouldn't have it any other way. No wires, no splicing. Basically plug-and-play.
      01-23-2020, 05:23 PM   #13
russelldav
russelldav's Avatar
425
Drives: 2019 X5 50i
gofast182 where does the prodigy wireless controller you have plug in to the car?
mghmghmghusa did you ever identify an adapter?
      01-23-2020, 06:55 PM   #14
gofast182
There's one module you plug into the 'cigarette lighter' to set/vary the braking force to match the weight of your trailer. The actual controller just plugs into the 7 way connector on the back of the car. Once you set the force you don't actually need the module inside the car anymore but I like to keep in plugged in when I tow because it will confirm the controller is actively working.
      01-23-2020, 10:02 PM   #15
russelldav
russelldav's Avatar
425
Drives: 2019 X5 50i
When I used to have a pickup I connected my brake controller to a wiring harness in the truck, not the 7 pin connector on the hitch as that is what the trailer connects to. Maybe I'm being a bit slow but I don't follow what you mean.
Presumably the cigarette lighter is just for power, so how is the brake signal getting to the trailer with the setup you describe?
      01-24-2020, 07:07 AM   #16
James_G0540i
Australia
446
Drives: 2021 X5 G05 40i M Sport
I too am puzzled by this entire thread.
If you have a 7-pin connector, pin #5 manages the electronic braking system which your trailer has, so I am not sure what that 4-pin trailer brake controller is for? (must admit I'm not familiar with braking systems on trailers, as my trailer only has mechanical brakes).
Interestingly, my BMW OEM trailer connector on my X5/G05 is a 12-pin connector - see pic below.
The 12-pin adds 5 x larger pins for:
- A fridge ignition feed to power the fridge in your trailer home or trailer while you’re driving.
- A breakaway battery monitor. This allows the voltage of the battery on your breakaway unit to be displayed on the dash of your vehicle.
- ESC, which is Electronic Stability Control, if your trailer home has it.
- a heavy earth return.
      01-24-2020, 10:38 AM   #17
gofast182
It's wireless, hence Prodigy Wireless Brake Controller! One module, inside the car plugged into the 12v outlet, establishes the peak brake force which is wirelessly transmitted and stored on the controller module which will mount on your trailer and plug into the 7 way on the vehicle which is where it gets power. The 7 way from the trailer then plugs into the Prodigy controller module you just mounted on the trailer. The controller module (trailer) has an accelerometer that senses brake input and applies a proportionate amount of braking force up to the limit you established with the first module in the car. You can leave the module in the car connected to vary the peak force as you drive or you can disconnect it and the controller module (trailer) will remember your peak force value you previously set.
In-car module to set braking force
WIRELESS BETWEEN HERE AND HERE
Module on trailer which is the actual controller
"Old"
Controller in car (hardwired)--->7 way on car--->Trailer
"New"
Force module in car~~~> | 7 way on car--->Prodigy Controller on trailer--->Trailer
If it still doesn't make sense you can always google it, see the mfr site, etrailer, or Amazon.
2020 M340i xDrive, Portimao Blue
2019 X5 xDrive 40i, Mineral White
2006 S2000, Berlina Black (Track car)
LexxM31697.50
      01-24-2020, 12:37 PM   #18
russelldav
russelldav's Avatar
425
Drives: 2019 X5 50i
"Old"
"New"
That's awesome, thanks for the detailed explanation. I'm following you now.
      01-27-2020, 05:37 PM   #19
russelldav
russelldav's Avatar
425
Drives: 2019 X5 50i
For those interested I think I got hold of the trailer brake connector wiring diagram for the G05, pre-installed with the factory hitch. This is for a US/Canadian spec. vehicle. I have no idea if it changes in Europe/Asia. I plan to create my own wiring adapter so I can plug and play a brake controller for the couple of times a year when I tow a trailer.
The harness is hidden under the steering wheel, underneath the dashboard.
PIN 1: BLACK / Brake Switch
PIN 2: RED / +12V Power Supply
PIN 3: BLUE / Trailer Brake
PIN 4: BROWN / Ground
See image attached kindly supplied by my service dept.
I know a few people have already tried this on the X3 so I am interested in your feedback e.g. sptucker
LexxM31697.50
      02-10-2020, 10:46 PM   #20
russelldav
russelldav's Avatar
425
Drives: 2019 X5 50i
I *THINK* I tracked down the connector:
https://www.ecstuning.com/b-genuine-...l/61131378134/
Looks right from the thumbnail so I ordered one to try it. Will let you know!
      02-11-2020, 12:49 AM   #21
Multimodal
2890
Drives: 2019 X5 50i, 2018 911 T
Looks like we have a bunch of people here with towing experience. I have a couple questions that are preventing me from upgrading from an E70 to a G05 until I know more. I'm hoping you all can help:
• How are you towing substantial loads with the limited payload capacity (849-871 lbs) of the G05? (BMW rates the payload capacity much lower than the difference between GVWR and curb weight. I haven't figured out why yet.)
• In your experience is 2-able air suspension a must have for towing with the G05? The vehicles I'm considering now are all equipped with 2VF M Dynamic suspension, not air. My E70 with standard suspension does sag about 3-4" towing my boat.
• Factory installation of the hitch increases the rated towing capacity to 7200 lbs. It's not clear to me if other components are upgraded to support that or it it's just marketing to encourage people to get the factory hitch. Have you all noticed anything different?
Ben
      03-08-2020, 10:14 PM   #22
skoold2003
skoold2003's Avatar
Drives: 2014 X5 50i M Sport, M3(sold)
2014 X5 50i  [7.50]
What we need is the mate to this connector. Has anyone found a source for it yet? It seems that for those of us with OCD will be paying $220 for this connector when we buy the OEM brake controller/harness.
