05-09-2019, 04:37 PM | #1 |
BimmerPost Supporting Vendor
24198
Rep 190,805
NEW Wagner Tuning S55 Radiator +89% Front Volume ** +94% Side Volume
Competition Radiator Kit for the BMW F80-82-83 M3/M4 The 3.0 Liter S55B30 turbo engine for BMW M3/M4 models is equipped with an indirect charge-air cooling circuit. So the cooling of the charged air is not realized by the ambient air as cooling medium (as usual), but made with its own cooling water circuit. A reduction of the temperature of the cooling water is directly equated with an improved cooling performance of the charged air. This is exactly where the advantages of the WAGNERTUNING upgrade water cooler comes into play. The new developed competition racing cores of the WAGNERTUNING high performance water coolers increase the radiator volume of the OEM water coolers by 89% for front mounted and 94% for side mounted. The calculated ratio between the inner and outer cooling surface generates a maximum heat transfer and allows at the same time enough air flow for the surrounding components (for example the engine water cooler) for its own heat exchange. The water coolers are equipped with a heat-conductive anti corrosion coating to ensure a lasting cooling effect. The plug & play installation of the system is simple and easy to perform (an installation instruction is included as well). Dimensions OEM front mounted radiator: 590 mm x 308 mm x 25 mm / 23,2Inch x 12,1Inch x 1,0Inch V = 4,5 Liter A = 1817 cm² / 280,7Inch² Dimensions WT front mounted radiator: 568 mm x 468,4 mm x 32 mm / 22,4Inch x 18,4Inch x 1,26Inch V = 8,5 Liter (+89%) A = 2660,5 cm² / 412,2Inch² (+46,4%) Dimensions OEM side mounted radiator: 250 mm x 165 mm x 40 mm / 9,8Inch x 6,5Inch x 1,6Inch V = 1,65 Liter A = 412,5 cm² / 63,7Inch² Dimensions WT side mounted radiator: 252 mm x 188 mm x 68 mm / 9,9Inch x 7,4Inch x 2,7Inch V = 3,2 Liter (+94%) A = 473,8 cm² / 73,3Inch² (+14,9%) Kit comes with: 1x front mounted radiator (low-temperature circuit) 1x side mounted radiator (low-temperature circuit) 1x carbon air shroud for side mounted radiator 1x mounting material 1x installation instruction
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 05-09-2019 at 04:48 PM.. |
05-10-2019, 10:28 AM | #5 |
132
Rep 42
Drives: BMW M2C LBB DCT
05-10-2019, 12:12 PM | #6 |
24198
Rep 190,805
It should be the same part number for both M2 Comp and M3
05-15-2019, 04:01 PM | #7 |
Rep 845
You live in the antelope valley?
Instagram: @Project_F87
05-19-2019, 01:20 PM | #8 |
333
Rep 390
12-22-2019, 11:20 AM | #10 |
24198
Rep 190,805
In stock
12-24-2019, 10:31 AM | #12 |
24198
Rep 190,805
Congrats
