BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Low Washer Fluid Warning
      05-15-2019, 06:51 PM   #1
gpinard
Drives: 2019 BMW M5 (F90)
A business colleague recommended RainX Washer Fluid additive as a simple way to improve the cleaning power of the washer fluid, particularly in the summer months to clean bugs off the windshield. Being a RainX product it also had the added benefit of beading the water during a rain storm and improving visibility. I have used the original RainX product for years and liked it so this sounded like something worth trying . . . 4 oz in a gallon of washer fluid, pretty simple!
Filled up my reservior as prescribed . . . about a week later I noticed a Low Washer Fluid Warning. I was surprised that I had gone through that much washer fluid so quickly and when I went to top it up it was virtually full.
Car was in for an oil change today and asked them to look at it. Mechanic asked if I used the RainX additive. Said there was BMW technical bulletin and it coats the sensor causing it to give a false warning. He emptied the reservoir and refilled with fresh washer fluid - warning is still on and he said it is likely to take a few flushes to clear it.
Thought I would share in case you were contemplating a washer fluid additive - not sure if they all impact the sensor but the RainX product certainly does.
      05-15-2019, 08:04 PM   #2
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Thanks for sharing.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
m5post
