05-22-2019, 01:23 PM | #1 |
![]() 89
Rep 108
Home Link Garage Door Opener Programming Issues
Since I received my X5 3 weeks ago I've been trying to program the Home Link garage door opener. I was convinced the Home Link in my vehicle was not working as I couldn't for the life of me get it programmed.
Then today I was trying again (after listening to a pre-recorded how-to via the BMW Genius hotline) and was somehow able to program 1 of my 2 garage door openers successfully. I then tried to program my 2nd garage door opener but now again not having any luck (both of my garage door openers are exactly the same brand/model). Has anyone else experienced difficulties getting Home Link programmed? Any tips from successful programming appreciated... |
05-22-2019, 09:23 PM | #2 | |
456bhp for breakfast
![]() 434
Rep 913
Are you seeing the flashing LEDs as per the description in the manual at each step and importantly do you see the green rapid flashing sequence to signify successful coding? |
05-22-2019, 10:28 PM | #3 |
![]() ![]() 126
Rep 183
Yeah, it's a pain. Took me three tries to get both my doors to program (with the manual open in my lap) and I also had to go hit the sync button on my openers to get it to work.
Once I got it working I really didn't look at the led in the mirror again until a couple of days ago, I happened to notice that the LED flashes a bunch of times (and rapidly) upon activation. Is that correct behavior? |
05-29-2019, 12:58 PM | #4 | |
![]() 89
Rep 108
When I try to program button #2 or #3, I get the slow flashing orange LED, but it never changes to a fast flash (this is the same issue I had with button #1 multiple times, but somehow it eventually programmed successfully). I'm going to keep trying to program my 2nd garage door opener but it's been a very frustrating experience so far...nothing like the other 2 BMWs I've had (both I was able to program the same garage door openers with no issues). |
12-03-2019, 11:26 PM | #5 |
![]() 0
Rep 6
Which ones did you manage to program? Can you name the model? I'm building my garage and planning to buy one of these door openers, if that's possible, I'd like to program it with 1 key.
12-04-2019, 12:18 AM | #6 | |
![]() ![]() ![]() ![]() 593
Rep 598
Sommer is a GREAT garage door but utilizes something called a Bomber signal. a PAIN to program to a homelink. Genie can be a bit aggravating because their clickers just suck to send the signal to the homelink device. Good ol' liftmaster is my personnel favorite. Easy to program and very reliable. |
volodp204.00 |
12-07-2019, 09:40 AM | #7 |
![]() ![]() 6476
Rep 4,892
Drives: 2022 iX xDrive50, DGM
I've found the programming instructions from car manufacturers to almost never be correct. The best resource is probably the online site for the door manufacturer.
12-30-2019, 04:55 PM | #8 |
Rep 8
I'm also having a hard time with the garage door programming. I have a rolling code style system- followed the directions in the manual and a few youtube videos which basically are the same drill of clearing the codes and putting my opener in learn mode then hitting one of the mirror buttons three times. No luck at all and for whatever reason everytime I try it my garage door remotes are getting wiped and I have to reprogram them. What gives? I did the same method on my now long gone MDX and it worked fine.
12-30-2019, 05:44 PM | #9 |
![]() ![]() 4429
Rep 4,246
I have this thread saved from 3 years ago and the Homelink steps outlined has worked on all my BMWs including the new G05:
https://www.bimmerpost.com/forums/sh...php?p=20680959
wjmb6.00 Hydrocarbon30.00 |
12-31-2019, 01:38 AM | #10 | |
![]() 33
Rep 112
For rolling code system, hold the button on the remote, close to the mirror then hold the button you want to be programmed. when the light blinks, run to the garbage opener and press learn, then run back to your car and just hold the button you wanted to program again for 5 seconds then release, then hold again, until it's working, and you'll know it's work, usually the second "hold" will set up the link. It'll take you literately 1 min or less to do this, hopefully this will work for you |
01-01-2020, 02:39 PM | #11 | ||
Rep 8
This forum is good stuff... |
01-01-2020, 05:19 PM | #12 |
![]() 33
Rep 112
01-07-2020, 08:01 PM | #13 | |
![]() 334
Rep 1,477
![]() 2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
01-08-2020, 05:45 AM | #14 | |
![]() 33
Rep 112
That model should operate exactly the same, did you try to program it as in my description? Here is a video in case I wasn't clear enough: |
01-08-2020, 08:25 AM | #15 |
![]() 334
Rep 1,477
Thanks, X6M50i The video + Genie manual gave me a straight line to follow.
04-14-2020, 01:07 PM | #16 |
Rep 4
I had trouble too. I don't know exactly what I did, but I know it wasn't what the owners manual said. When I stopped looking at the manual I got it to program the first time.
04-14-2020, 03:15 PM | #17 |
![]() ![]() ![]() ![]() 223
Rep 482
I'm also having trouble with the G05 and my Novoport/novoferm garage door opener. I've done the procedure many times and now it opens sometimes. I have to keep pressing the button on the mirror for about 5 to 10 seconds until it opens/closes.
05-29-2020, 04:39 PM | #18 | ||
![]() ![]() 196
Rep 121
2019 M850i Coupe
06-02-2020, 11:04 AM | #19 |
ghey
![]() 503
Rep 2,042
If this is of any help, here is my approach to programming homelink in the car. Could be out of date at this point.
-Older openers that have physical DIP switches to change the code. You hold the remote within a few inches from the mirror and click the button on the opener remote a few times until it syncs. -Newer openers that operate on rolling codes. Two-step process. I first sync up the remote & homelink button using the same process as the DIP switch remote. Once complete, you then press the Learn button on your opener, and proceed with pressing the previously trained button on your mirror to get the two in sync. My understanding is that with a rolling code opener, you first have to tell it *how* to talk to your opener (hence the remote pairing), then you establish the trust between your homelink mirror and the opener itself (via the learn button). Could be wrong, but it's worked pretty well for me in my cars.
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
06-18-2020, 01:19 AM | #20 |
![]() 832
Rep 1,805
Also of note is that Homelink requires a separate box for some older cars like my 2008 Toyota Avalon. I have a new Garage Door Opener and it refused to pair with my Avalon but worked fine with the BMW. I had to purchase a HomeLink Compatibility Bridge Kit and hook it up to the opener in order to get it to work with Avalon. http://www.homelinkestore.com/Produc...ridge-Kit.html
06-18-2020, 11:32 AM | #21 |
![]() ![]() ![]() 92
Rep 306
I just program a brand new chamberlain garage door opener with security+ 2.0 last month. It was so simple. First I press and hold the button I want to program until light start flashing then press open on the remote.
06-20-2020, 05:30 AM | #22 |
![]() 33
Rep 112
