05-23-2019, 07:46 PM | #1 |
Rep 2,610
Multiple NFC Key Cards
Have we discussed whether it is possible to have have more than 1 key card? I don't mean more than one per profile, I mean more than one per car, like a his and hers. If not, possible? Thoughts, experiences?
05-23-2019, 09:44 PM | #2 |
456bhp for breakfast
426
Rep 913
Yes - the NFC key card and a smartphone are technically both separate devices so I believe it is possible to have multiple NFC cards. Each Digital Key has to be activated and registered with the vehicle and a driver profile.
05-23-2019, 09:52 PM | #3 | |
Rep 2,610
05-23-2019, 09:55 PM | #5 | ||
426
Rep 913
05-23-2019, 09:58 PM | #6 | |||
Rep 2,610
05-23-2019, 10:01 PM | #7 | |
13734
Rep 20,420
05-23-2019, 10:03 PM | #8 | |||
Rep 2,610
05-23-2019, 10:06 PM | #9 | ||||
426
Rep 913
05-23-2019, 10:21 PM | #10 | |
Rep 2,610
But nonetheless, I've sent a note to the dealer with your screen cap to see what their response will be. The best proof would be someone actually confirming two key cards registered and both operating on their car.
russelldav425.50 |
05-23-2019, 10:36 PM | #11 |
13734
Rep 20,420
I guess he could be wrong but he mentions ordering a second one.
https://g05.bimmerpost.com/forums/sh....php?t=1571295 Edit: Appears he was wrong. One member ordered two for his car and the order couldn't be fulfilled. "mbarrett635 - you were correct. CA just reached out to me and said they can only enable one keycard at a time... which is why they were having trouble with my order. Manual seems to contradict this but is unclear at the same time." https://g05.bimmerpost.com/forums/sh...0&postcount=40 Last edited by TurtleBoy; 05-23-2019 at 10:49 PM.. |
05-24-2019, 12:45 AM | #12 |
Rep 114
Drives: 2020 M340i xDrive
You can only activate one key card. Also a Digital Key is not the same as a Key Card. Digital Keys refers to using your phone as an NFC card.
I have two cars with key cards, and I was hoping I could activate both cards on both cars so that I would only have to carry on card that works on both cars. But it is not possible. Each car comes with one card specifically assigned to that car and cannot be changed or removed. You can only activate it or deactivate it. So no, you can only have one card per car. Also the car is very good at detecting who is in the driver's seat and who turns the engine on if each one of you has their key on them. Even if you get into the car and your wife's profile is active, as soon as you start the car, it will change to your profile automatically. |
TurtleBoy13734.00 |
05-24-2019, 10:47 PM | #13 |
Rep 176
Picked up my new X5 today and the dealer did not have the digital key card. Had to order it. Strange that they did not know this ahead of time.
Also disappointed to learn that my Apple iPhone is not compatible to use in place of a key. I guess I should’ve researched this item better before purchasing. evidently only an android phone can be used in place of the Key according to the dealer. That is disappointing. |
04-16-2020, 11:01 PM | #14 | |
Rep 125
I ordered a second key card today and when I activated it, it deactivated the first one with no way to reactivate it. Funny when I ordered the second one the dealer asked if I already had one when the car was delivered, which I confirmed and specifically said I wanted a second one for my wife. They were quick to take my money and likely slow to refund. 🤦🏻*♂️
LexxM31703.00 |
11-04-2020, 03:39 PM | #15 | ||
Rep 2,610
11-05-2020, 08:30 PM | #16 | |
21
Rep 45
01-24-2023, 06:46 PM | #17 |
Rep 13
Drives: BMW X7 LCI Dravit / Cognac
Searching all over the internet for this and this old thread popped up.
I have a 2023 LCI X7 and I bought a spare key card to have one for myself and one for the wife. It turns out its still not allowing two keys. Only one key card can be paired at a time. One will pair and the other one will not work and there is no way to add another. Has anyone found a solution or am I doing something wrong and people are able to add two key cards? |
01-24-2023, 06:49 PM | #18 | |
13734
Rep 20,420
04-06-2023, 10:28 AM | #20 |
Rep 129
Does anyone know if when replacing a lost key card, there is any programming required by the dealer for the new card to tie it to the car? Or would one follow the typical steps to activate the card and that’s the only step required to tie it to the VIN?
04-06-2023, 11:09 AM | #21 |
Rep 2,610
It’s been a while, but IIRC my old test of a replacement card, dealer has to order a replacement card specifically for your VIN and that’s the extent of “pre-activation”. The effect is that the card is tied to your car regardless of whether you enrolled it or not and you won’t be able to enroll that card in another car.
04-06-2023, 11:12 AM | #22 | |
Rep 129
They’d certainly be living up to the stealership name if that were the case. |
