BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    1200 Mile Service
      05-26-2019, 12:59 PM   #1
GaGolfer
17
Drives: 2019 M5 - Singapore Gray
1200 Mile Service
Can anyone post the specifics of the 1200 mile service?
Waiting for my ED re-delivery...
Thanks
      05-26-2019, 10:55 PM   #2
bradleyjs
Drives: 2019 F90 M5B, 2006 E60 550i
+1 - I’d sure like to know this information as well. Thanks.
      05-27-2019, 01:27 AM   #3
boredM
Drives: Ford F-350 & Nardo F90
Change engine oil and oil in both diffs
Once over the car
      05-27-2019, 08:06 AM   #4
bradleyjs
Roger that - thanks!
      05-27-2019, 11:12 AM   #5
imahobo
Drives: F85 X5M, 991TT
Also scope the engine and perform the coolant recall if required.
      05-27-2019, 11:28 AM   #6
wesleyan92
wesleyan92's Avatar
1372
Drives: M8 GC || M5 Comp || X7 40i
2021 BMW X740i  [0.00]
2021 BMW M5  [0.00]
Here you go; do a search - tons of good info but posting my service readout. The big education for me was the correct differential oils for the front and the back.
2024 M8 GC Black/Black || 2021 M5 Carbon Black/Midrand beige || 2021 X7 40i Amertin metallic with Ivory white merino
2019 M5 F90 || 2018 X5 s35i || 2017 M5 F10 with Arkapovic Exhaust || 2016 535 || 2012 535 hated it after the E60 || 2010 535 E60 - my fav || 2008 528 E60 my first
      05-27-2019, 12:11 PM   #7
Taheemr
United Kingdom
280
Drives: M6 GC
in the UK activate launch control also
      05-30-2019, 12:29 AM   #8
GaGolfer
17
Thanks!
Still 4-5 more weeks of waiting...ugh!
Mike
      06-18-2019, 12:22 PM   #9
masmole
Drives: blue, gray, brown cars
Got the 1200 mile service done on my M5C today.
Looks like it was done by the book
2021 A6 Allroad, 2020 SQ7, 2019 M5 Comp, 2011 GT3
past: A4, S4, X5 4.8is, SLK55, E60 M5, RS4, ML63, E92 M3, Q5, Touareg TDI, Escalade, SQ5, RS7, Velar FE, Q7
      06-26-2019, 08:58 PM   #10
bradleyjs
So, is the 1200 mile break-in service check free as shown above in masmole’s receipt?
      07-01-2019, 02:25 PM   #11
GaGolfer
17
Yes.
      07-01-2019, 04:21 PM   #12
bradleyjs
Excellent - thanks GaGolfer!
      07-11-2019, 09:49 AM   #13
GaGolfer
17
FWIW, I'm told my 1,200 mile service was performed at the VPC in Brunswick (after my ED).
Picking it up tomorrow at Spartanburg (PCD)!
FYI
      07-27-2019, 04:48 PM   #14
bradleyjs
FYI
How many miles did you have when they did the 1200 mls inspection at the VPC?
      08-12-2019, 03:14 PM   #15
GaGolfer
17
About 1,030
FYI
      08-16-2019, 12:12 PM   #16
bradleyjs
About 1,030
FYI
That’s close enough.
I took mine in (which only had 219 miles at that time) to get the ceramic coating treatment that I paid for during purchase and the SA insisted (no demanded!) that the 1200 mile inspection was to be completed solely because it was scheduled in the computer system. I told them it’s premature but they did it anyway.
After picking up the car the next day, the receipt showed that they only changed the oil and filter (and “topped off” the windshield fluid - that I never used BTW). So, I complained that it was insufficient service and and after weeks of bitching they final called me yesterday to schedule an appointment to finish the the remaining inspection items. I’m currently just below 500 miles (Imperial) and I took a September 3rd date so that I have some time to rack up more miles and still have an appointment date that’s not too far off.
Bottom Line: Be like my Wife and never stop bitching until you get your way! It works 90%, 100% of time.
      08-16-2019, 04:08 PM   #17
GaGolfer
17
Wow!
Make sure they do everything required!
Mike
      08-17-2019, 02:33 PM   #18
bradleyjs
I will keep you guys posted!
      09-16-2019, 08:47 PM   #19
bradleyjs
And here’s my follow up:
I finally got the ”proper” 1200 mile inspection done a few days ago. They wouldn’t (although i was politely persistent) change the engine oil again. That was done back at the 219 miles “1200 inspection” and they said its already been done. So, I just let it be at that... Both differential’s fluid was changed and an overall inspection at that point (1152 miles); all was fine.
I was slightly concerned that they would disconnect the MirrorTap wires from the interior rear view mirror that powers my Radenso Pro M radar detector. I had issues years ago when I used to take my 550i in for service and they kept disconnecting the wires I had powering my Valentine 1 radar locator. After several times of them doing it, I gave up and just stopped using it. I really didn’t need it anyway because I job was only 6 miles away and I didn’t have to travel a couple hundred miles every other weekend to get/return my 2 sons.
They didn’t even touch it, thankfully. I really wasn’t in the mood to fight with anyway.
Otherwise, all is good and in perfect working order!
m5post
