Bimmerpost
4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Is the small inner element of the Adaptive LED headlights actually functional?
      06-02-2019, 05:25 PM   #1
Cobra86
United Kingdom
50
Drives: BMW G20 330i M Sport
Sorry if its silly question. Is this light functional ? I just noticed today and watched some videos and all showing the same thing !
      06-02-2019, 05:39 PM   #2
jlin101
107
Drives: 2018 X3 M40i, 2016 750i
That's either just a dummy lens or the high beam (try switching the HB on). In cars with Laserlight, the upper two elements are low-beam and the lower two are high-beam.
      06-02-2019, 09:26 PM   #3
unc879wins
Drives: 2015 Lexus RC350 FSport
If it's not, that grill could get bigger
      06-02-2019, 10:56 PM   #4
DomiGijzen
DomiGijzen's Avatar
Netherlands
70
Drives: BMW iX3 MSport High Exec (G08)
In this case a dummy light. On cars with laser light, that would be a high beam but they look different.
Grz D.!
      06-22-2019, 10:16 AM   #5
tsumatrix
tsumatrix's Avatar
Drives: 2011 e93
On low speed, depending on turning left or right; the inner lights will phase on and turn off when the turn is completed. Part of led active cornering.
      06-22-2019, 01:26 PM   #6
DomiGijzen
DomiGijzen's Avatar
Netherlands
70
Don't think so. Def not on the adaptive led. But there is a side facing led in that headlights and that does indeed do as you say.
Grz D.!
      06-24-2019, 10:12 AM   #7
tsumatrix
tsumatrix's Avatar
Drives: 2011 e93
You are correct. drove it out last night and was testing it. The inner square projector light did not come on while I was turning. Only one of the small LED dot lit up while I was turning. I was following behind a truck while I was turning. Reflection.
g20
