Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > ? on removing A-pillar trim for e93
      08-08-2008, 03:29 PM   #1
kpblade
Drives: 540i e39, 335i e93, M550i G30
I want to hardwire my Valentine 1 to my e93 by running the wires for power and the concealed display down to the fuse box. Does anyone know how to remove the A-pillar trim from an e93. It does not have the SRS-airbag like the e90/92, so there are no visible screws to remove to free up the trim. I assume it pulls off somehow, but not sure which way. Thanks.
      09-07-2008, 06:14 PM   #2
Wittmann
Germany
Drives: 3er
You do it the very same way, like in the E90. The only difference is, that you have nothing to unscrew. Just grab the upper edge of the A-pillar trim with a firm grip, and pull it sideways into the direction of the other A-pillar. It's held by two plastic clips.
It's also a good idea to order clips (stock no: 51 43 0 141 024) before doing any work on the pillars, since they have to be exchanged when damaged.
