The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > Removal of Wheel Roundels
      08-10-2008, 07:39 PM   #1
Storto
Drives: 2008 328i E92
I checked the DIY for an easy way to remove Wheel roundels but couldn't find one. So I Took some pictures while I removed mine.
ToolsPIC #1)
Small Jewelers screwdriver
Thin Cardboard (should be thinner than a dime)
Scissors
Step 1. Cut a small piece of cardboard in a square. Ensure you have a good corner.
Step 2. Put the cardboard in-between the Roundel and the wheel. (this will protect your wheel better than a cloth)
Step 3. CAREFULLY wedge the screwdriver in-between the cardboard and the roundel. If you push it in too far you may scratch the inside of your wheel. (Circled on picture)
Step 4. Gently pry the roundel away from the rim. THIS WILL DENT THE INSIDE PLASTIC OF THE ROUNDEL.
Step. 5 Pull the roundel off and replace with your stock ones.
Lessons learned: Remove the roundels from the wheel before you put them on. This will save you about 10 minutes per wheel, and the risk of scratching your new ones.
FYI's these are 19" Breyton Race CS on 328i E92 stock height/suspension
2008 328i E92 6AT / Titanium / Gray / Gray Trim / Premium / Sports / Sports Steering Wheel with Paddle Shifters /Comfort Access / Navigation / iPod / Park Distance Control / Ordered: 02.16.08 / Delivered: Soon
      08-11-2008, 02:38 PM   #2
Nonsuch
Drives: 2007 M6
Next time, use Duct Tape
Apply Duct Tape (or any strong sticky tape) to the wheel roundel, then pull the roundel off the wheel.
      08-12-2008, 01:53 AM   #3
Amir87
Gruppe Titan
Amir87's Avatar
Pakistan
262
Drives: 08 E92 SG/Coral
2008 E92 335i  [10.00]
Another method is to use a suction cup and pull it off with it.
Thanks for the DIY!
      08-12-2008, 02:18 AM   #4
kuvesh
kuvesh's Avatar
Singapore
26
Drives: e92 335i juiced
i'm always afraid of chipping the rim so normally just take the tyre off and pop it from the back...
      08-12-2008, 11:56 AM   #5
tintivilus
tintivilus's Avatar
Drives: E92 335i
2007 E92 335i  [0.00]
2003 325i  [0.00]
+1. Quick tap from behind with just about anything (I usually use a screwdriver handle) and they pop right off. Why risk scratching up your wheel paint?
      08-27-2008, 05:10 PM   #6
JoeyFiasco
JoeyFiasco's Avatar
22
Drives: '09 Coupe
like a little plunger? haha
Thanks for the DIY!
      08-27-2008, 05:11 PM   #7
e92phreak
e92phreak's Avatar
Drives: E92 335i TiAg/E46 323i TiAg
2007 E92 335i  [9.50]
2000 E46 323i  [0.00]
My preferred method.
07 E92 335i | TiAg | Step | Padl | Cmft | Alum Trm | PDC | Nav | Assist | Sat | Lthr | Prem | Sprt | Rear Splr | RDSport Quads | iPod | V1 | LT Refl | VS Clear Bra | OEM Lip | KWV2 | Mtec Sides | BBS LM-R
00 E46 323i | TiAg | 5sp | Sport | Roof | RDSport Cams | RDSport tune | RDSport Shift | Volk LE37 | M3 spoiler | PSS9 | SuperSprint | Brembo
      09-16-2008, 05:04 PM   #8
1clean335i
Perf BMW mag issue 147, 159
1clean335i's Avatar
Vietnam
414
Drives: Project Estoril
Thanks for the DIY!
Thats what I use also Takes 2 seconds to pull off
heres a pic of that I use-
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril
      01-12-2013, 09:18 AM   #9
vasisht
Drives: 2009 335ix
Thanks! Bought a $3 suction cup at Harbor Freight and took 5 minutes to swap out the roundels on my winter rims for BMW roundels...
