BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > FULL SWS-8 sub and amp install, 34 pictures, step by step
      08-14-2008, 03:40 PM   #1
azwillnj
318
Drives: 2023 M340i xDrive
I gathered a ton of information from this site about how to upgrade the stock subwoofers and amplifier. From this information I have created a full, step by step tutorial that will guide you through the entire process. It is 27 pages long and has 34 pictures included....
Check out the PDF below the pictures for the tutorial.
Here are some teaser pictures.
PDF
https://www.dropbox.com/s/4md1oz9pvt...20PDF.pdf?dl=0
Let me know what you think or if you have any questions....
Note to mods: The place I have it hosted is pretty reliable, but... I wanted to upload this to the forums so the PDF would always be available, but the upload kept failing. If you could somehow get it on to your servers that would be great, thanks.
EDIT: if your having trouble viewing the PDF right click the link and go to save as.
EDIT2: as several have suggested I have moved the fuse to the other side of the car, right after the battery, I updated the PDF to show its new location...
EDIT3: 2017/02/07 - Fixed download link.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive
WE ARE!
Last edited by azwillnj; 02-07-2018 at 05:38 PM.. Reason: Updated PDF for new fuse location.
      08-14-2008, 03:45 PM   #2
D0wn4itt
Drives: E92 335i
This is awesome! Thank you for taking the time to do this!!
6MT/TR MT1 18"s/SPEARCO/CUSTOM-BORLA/AFE/BILSTEIN-PSS9/CF EVERYTHING/BMS JB3/AA-SSK/[400whp/410WTQ]
      08-14-2008, 04:48 PM   #3
iatacs19
iatacs19's Avatar
Drives: 2016 SO M4
Holy shit!
Good write up man, let's get the mods to put this in the DIY section.
      08-14-2008, 04:54 PM   #4
azwillnj
318
Damn, I didn't even think of the DIY section.. oops.
WE ARE!
      08-14-2008, 05:27 PM   #5
im spencer
Back in the f80
im spencer's Avatar
Drives: 2016 F80
2007 328i  [0.00]
you sir are the man! I've been waiting for something comprehensive like this for a long time!! thanks for the informative pdf
2003 SS S2000
2016 MW F80
2018 BMW X3 X-Drive
      08-14-2008, 06:08 PM   #6
Technic
Technic's Avatar
2283
Drives: 2021 i3S, 2024 i4 M50
Excellent contribution...
      08-14-2008, 07:50 PM   #7
emarkd
Drives: '08 335i
Excellent write-up and nice PDF. You clearly took a lot of time to prepare that. Overall, you did a very clean, nice job, but I wanted to make one comment. It looks like you put your main power fuse across the car from the battery, near the amp. Please consider moving it to the side with the battery. That fuse is not to protect the amp, it's to protect the wire and should be as close to the battery terminal as possible. If that wire were to rub through where you ran it through the metal channel, you would have a huge, 10-gauge short with no fuse in it that could easily start a fire in your car.
Again, overall I think you did an excellent job and thanks for contributing.
      08-14-2008, 08:36 PM   #8
Nypeder
Nypeder's Avatar
238
Drives: E92 M3/E90 335i
Great write up. Subscribed so that I have this when I install my subs. Thanks
      08-14-2008, 09:38 PM   #9
azwillnj
318
That's a good point, I think it will be fine though, the insulation on that wire is about 1/8 inch thick. It was difficult to cut it with a razor blade.
WE ARE!
      08-14-2008, 10:16 PM   #10
BigDog
Drives: YMB F80
from one penn stater (alum) to another.... thanks!
oh snap i just noticed you're a central jersey'r!
you're even better in my book now!
so from one central nj stater to another... thanks!
      08-14-2008, 11:55 PM   #11
GAM3OVR85
GAM3OVR85's Avatar
Kuwait
313
Drives: E92 M3
2008 BMW M3  [0.00]
2010 Sea-Doo RXT-X 260  [9.00]
2007 E92 328i  [10.00]
Awesome!!
08 E92 M3/Melbourne Red/6MT/Exec Pack/MDrive/EDC/PDC/19" 220M
Mods: VRS Front Lip, HID Angels, KW V3, Stoptech BBK, SS lines, 18" TE37SL, Bastuck Exhaust, MS Air Filter, OEM Aluminum Padels, LED Interior Light
07 E92 328i/Jet Black/Cream Beige Leather/Premium/Step/Heated Seats...check garage!
      08-15-2008, 02:42 AM   #12
X1 Trojan
Go Dodgers?
X1 Trojan's Avatar
93
Drives: '13 BSM X1 xdrive35i Msport
Can you give us a write up on how it sounds compared to stock?
      08-15-2008, 06:40 AM   #13
LaYzEe
LaYzEe's Avatar
102
Drives: AW E92 335i
holy crap! pdf FTW!!!! this definitely needs to be in the diy section! good job!!
      08-15-2008, 07:53 AM   #14
emarkd
Drives: '08 335i
It's easy to say that, but consider the vibration of a moving car for the next few years. A slight burr in the metal could easily wear through that insulation. It would only take a few minutes to move it...
Not trying to push and you do whatever you're comfortable with. I just don't want to see anybody lose their car when it could be prevented. I worked in mobile electronics for quite a few years when I was younger, even owned my own shop for a while. I've seen way too many burned up cars because of a shorted power cable.
      08-15-2008, 10:33 AM   #15
scooby9
scooby9's Avatar
61
Drives: 2007 E90 BMW 335xi
Great work on the PDF! I really like your ideas on sealing up the small opening in the OEM sub box. I was going to use MDF but the clear look is really nice.
On a side note, I've installed a few systems too and ideally you want to keep the fuse literally a few inches from the positive battery terminal. I know it's extremely unlikely that there will ever be an issue but knocking on wood as I write this, if there were ever a vehicle impact or something that could damage that power line, there would be 4-5 feet of live power wire that could cause a major fire or with a prolonged short circuit cause the battery to explode.
2007 BMW 335xi 6MT TiAg
      08-15-2008, 10:38 AM   #16
azwillnj
318
The difference is night and day, the system hits much harder, and sounds much much cleaner. When I first started out doing this and looking into all the information about it I knew that there would be more bass and that it would hit harder in the low frequencies. But I never imagined how much of a huge difference this upgrade could make in the overall sound quality of the system. My music seems to be alive now, between feeling the bass and hearing all that extra bass spectrum that the stock subs just couldn't produce. In the stock system it was very easy to bottom out the stock subs with a slightly loud track from Disturbed, now you can crank the volume and the subs will just hit harder.
Another thing I have noticed after the install is how sloppy and loose the stock subs were, it seems now that they were just making noise in the general frequency. These SWS's hit hard and are very very crisp. The car does not at all sound like a riced out civic, it sounds like a rich silky smooth BMW sound system should, it puts a smile on my face.. really. I would actually venture to say that this is now the best sounding system I have ever encountered in a car, and I've been in alot of cars...
Note: Just to clear this up, I am not an employee of earthquake, I am just blown away by the quality of their products and outcome of this install and wanted to share the wealth with the rest of e90post.... enjoy!
You've talked me into it, I don't want my e90 to be on fire.. I will move my fuse and update the PDF sometime soon.
Alex.
WE ARE!
      08-15-2008, 11:50 AM   #17
badfish
badfish's Avatar
100
Drives: E92 AW M3
2008 M3  [0.00]
Great job with the writeup. I was going to respond with the same thing. It's such a good writeup that others will likely follow it so maybe update it with a best practice to fuse at the battery.
Those subs will seriously get overpowered by that amplifier so be careful. The subs are excellent but you don't want exceed their rated specs. Tom Nousaine discovered that when he reviewed the subs. 150 watts RMS each is all they need. Your amp is capable of pushing over 3x that power to each sub so be careful.
      08-15-2008, 02:17 PM   #18
emarkd
Drives: '08 335i
I didn't even think of that, but I've witnessed this one before. I had a friend who worked for the local fire department and he brought me pictures of a car fire he worked. It had been in a pretty minor fender bender, but when the front fender crunched in, it pinched through an amp power wire with no fuse in it. The car burned badly before they got there. A minor fender bender turns into a complete loss.
Good. I'm glad to hear it.
      08-15-2008, 03:55 PM   #19
azwillnj
318
Yeah I know its too big, but I have the level on the amp turned way down, and I figured I would get the big one so if I ever wanted to add another sub in the ski pass through I could. I also wanted one that could handle the 2ohm subs, and I wanted a digital one with a bass boost adjustment (which is cranked to max). All in all I'm very happy with the setup.
I moved the fuse and updated the PDF, have a look...
WE ARE!
      08-15-2008, 04:02 PM   #20
badfish
badfish's Avatar
100
Drives: E92 AW M3
2008 M3  [0.00]
      08-18-2008, 06:39 PM   #21
kaigoss69
kaigoss69's Avatar
Drives: '08 335i
Awesome writeup OP, thanks very much for the contribution!
Does anybody know if there are other subs that fit in the stock location. I know there is a Morel but it is hellishly expensive.
Another question revolves around the vented enclosure specifications of the OEM enclosure. What is the volume of the box and what length and diameter is the port? Is the Earthquake well suited for this particular enclosure?
What about sealing the enclusure off and turning it into a sealed box?
      08-18-2008, 09:50 PM   #22
simp0man
Not looking 2 SPEED, just looking GOOD
simp0man's Avatar
Cambodia
45
Drives: 07 328i
2007 328i  [0.00]
Damn that is alot of work. I think I'd rather have someone do it. But surely this is an excellent source of information you have made for the bimmer community. You have trully earned your keep!
