      08-04-2019, 03:27 PM   #1
jasrboyd
Drives: 2021 330i Xdrive
How to send text messages
Is it possible to send text messages using idrive? I can receive but can’t figure out how to send. THANK YOU.
      08-04-2019, 03:40 PM   #2
Tenac
Tenac's Avatar
4891
Drives: All
IOS or android?
IOS: Apparently NO.
Adding video: Android follow this:
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0
2019 718 Cayman Base
2015 M235 Manual
On the list for the M2 CS
      08-04-2019, 03:55 PM   #3
jasrboyd
Oops iOS
Ok thank you for confirming it’s not possible yet. I’m trying to convince myself I don’t need car play.
      08-04-2019, 04:31 PM   #4
omaralt
Drives: 22 M3
Originally Posted by jasrboyd View Post
Oops iOS
Ok thank you for confirming it's not possible yet. I'm trying to convince myself I don't need car play.
They've pretty much forced you into CarPlay now.
2018 M3 6 spd
2017 M3 AW/SO 6spd
2014 435i M sport BSM/Coral 6spd (retired)
2013 550i M sport Alpine White/Cinnamon (retired)
      08-04-2019, 04:37 PM   #5
jasrboyd
I think you’re right.
      08-04-2019, 07:53 PM   #6
edtreo
Drives: 2019 X5 40i MSport
You can send message thru Siri.
      08-04-2019, 08:10 PM   #7
TurtleBoy
TurtleBoy's Avatar
24463
Drives: 2021 M340i,2023 X5 M50i
They are not going to restore Siri Eyes free so other than shouting to your phone you will not be able to do it.
jasrboyd133.00
      08-04-2019, 08:29 PM   #8
omaralt
Drives: 22 M3
I mean you can still activate Siri when using CarPlay
2018 M3 6 spd
2017 M3 AW/SO 6spd
      08-04-2019, 08:58 PM   #9
edtreo
Right. Assuming you can connect to it.
      08-04-2019, 08:59 PM   #10
TurtleBoy
TurtleBoy's Avatar
24463
Yes but you used to be able to do it using Siri without having to run CarPlay. I'm actually glad I had to switch to CarPlay as it is working well and am now using Podcasts and iHeart.
      08-05-2019, 10:10 AM   #11
jasrboyd
You can still use Siri without enabling CarPlay but it has its limitations. To me after fumbling around and settling on how to use idrive without CarPlay I’m convinced it’s me being nickel and dimed. This should all just work no matter what. It should be simple too not rocket science. Anyways thanks for the replies it helped me figure things out.
      08-05-2019, 10:36 AM   #12
archivedaccount
Guest
n/a
Drives:
I'd be happy with CP if it wasn't so damn buggy!
Sometimes it refuses to connect at all. Sometimes it connects but audio remains with the phone(?). In both scenarios I have a Wifi disable/enable shortcut/favourite to connect it which works but is a complete PITA doing that every 1 in 4 times.
I've gone weeks without issues thinking 'whats the problem with CP everyone goes on about?' and then boom, broken again. Probably an iOS update, or someone turned a microwave oven on next door, or something...
So, I've given up for now. iDrive only on the car, and back to a phone cradle near the dash. Every use-case rock solid.
Maybe some combination of IOS 13 and ISTA 4.18.x (1907) will improve matters but until then I'm done.
I wouldn't have a problem paying for it to 'keep it working', but it never has worked!
jasrboyd133.00
      08-05-2019, 12:00 PM   #13
TurtleBoy
TurtleBoy's Avatar
24463
No one else seems to be able to do that after the 03/2019.xx update. How are you doing it?
      08-05-2019, 01:30 PM   #14
jasrboyd
When I’m in the X5 I say hey Siri and she answers over the vehicle speaker then I tell her to send the text and it works however the steering wheel button doesn’t bring up Siri when CarPlay isn’t enabled.
My X5 has the 03/2019.37 software.
      08-05-2019, 01:54 PM   #15
TurtleBoy
TurtleBoy's Avatar
24463
I think that is because your phone is picking up your Hey Siri and not because iDrive is but that could have changed.
      08-05-2019, 02:43 PM   #16
samvora
The Dark Knight
samvora's Avatar
Drives: E36, E46, E90, G05 and MB W205
When you say it is working well now - what exactly do you mean? What was not working/broken in the past that is working well now?
My biggest issue with carplay is that it disables the wifi and I cannot use the Wifi hotspot of the car.
      08-05-2019, 03:14 PM   #17
jasrboyd
Siri is responding over the vehicle speaker too.
      08-05-2019, 04:44 PM   #18
TurtleBoy
TurtleBoy's Avatar
24463
Yes I know. What I'm saying is wha others have reported, that the Hey Siri is being initiated by the phone hearing the request and not iDrive hearing the request.
      08-05-2019, 04:46 PM   #19
TurtleBoy
TurtleBoy's Avatar
24463
What I'm referring to is that since updating to iOS 12.4, CarPlay no longer drops/misses connections. As far as the HotSpot goes, I have never had the problem you are describing but only used the HotSpot a few times.
