Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > Strut Bar DIY
      03-31-2006, 05:40 PM   #1
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Strut Bar DIY
Attached are detailed instructions on installing the BMW Strut Brace part number 51 71 0 406 937. The entire process takes approximately 10 minutes once you have collected the tools below and have unwrapped all of the parts.
Tools needed:
  • Ratchet for quick removal and initial tightening of nuts.
  • Torque wrench - 35 Nm (25.8 Ft-Lbs) & 52 Nm (38.4 Ft-Lbs)
  • 11, 13, and 14 mm sockets
Step by step instructions:
  1. Remove all packaging and parts and set them out for easy access.
  2. Remove the nuts holding the factory firewall brace from the left and right spring strut tower using the 11 mm socket and ratchet.
  3. Remove the frontmost nuts from the left and right spring strut tower using the 12 mm socket and ratchet.
  4. Place dome strut bracket on left spring strut tower and hand tighten in place with the provided 14 mm bolt and the 13 mm nuts.
  5. Repeat the process on the right spring strut tower.
  6. Place the strut brace in place, center and hand tighten 13 mm nuts using the ratchet.
  7. Torque 14mm nuts to 52 Nm and all 13 mm nuts to 35 Nm.
  8. Place protective caps on 13 mm nuts.
  9. Done!!
File Type: pdf E90 Strut Brace Installation Instructions.pdf (1.30 MB, 3309 views)
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      03-31-2006, 06:23 PM   #2
D.D.
Drives: 330 xi
Nice..........Really NICE!! :rocks: :rocks: :rocks: Do you see any effects to the handling of the car? Does it cut down on the roll??? I am very interested in this mod..........
      03-31-2006, 06:41 PM   #3
ksfrogman
ksfrogman's Avatar
Drives: E90 330i 6MT
2006 330i  [0.00]
2006 330i  [0.00]
Strut bars firm up the chassis. Sway bars reduce roll.
      03-31-2006, 06:50 PM   #4
HRC
MAUI BUILT
HRC's Avatar
Drives: 2006 330i MT
2002 E46 325i  [0.00]
2012 E70 35i  [0.00]
Nice Work!! I might get this later. Look out, some poeple here will attempt to rain on your parade and call this mod nothing but silly eye candy, but not me!
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
      03-31-2006, 07:00 PM   #5
zzinco79
zzinco79's Avatar
124
Drives: 2006 BMW 325i
Can you please give me a part number???
How much was it???
Can I get it from my dealership?? or e-bay???
      03-31-2006, 07:09 PM   #6
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
Dude, the part number is one of the first things he listed!! Read the post man! Also, if it's a BMW North America item, any dealer can order it, or any vender can order it, including ebay, booster, blut...
Danny
How much was it???
      03-31-2006, 07:44 PM   #7
tiga901
tiga901's Avatar
Drives: e90 330i, mt pp sp
Just got mine today.....thanks for the instructions. I was goint post pics but I cannot do anymore justice than what you have done. I will test drive tommorow. I know that the e90 already has a firm chassis but anything helps!
      03-31-2006, 08:18 PM   #8
zzinco79
zzinco79's Avatar
124
Danny
Don't yelling at me... Sorry
      03-31-2006, 08:31 PM   #9
zzinco79
zzinco79's Avatar
124
How much is it???
      03-31-2006, 08:37 PM   #10
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
Danny
      03-31-2006, 09:03 PM   #11
EVO_S4
EVO_S4's Avatar
117
Drives: 2016 M3
2016 BMW M3  [0.00]
2009 BMW  [8.24]
How much is it???
A liitle over $200shipped on ebay
2016 M3
2016 Audi Q5 3.0T
      03-31-2006, 09:27 PM   #12
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
administrator!
add to master DIY please!!!
"Teach the ignorant. Ignore the stupid."
      03-31-2006, 11:14 PM   #13
zzinco79
zzinco79's Avatar
124
Just got one from e-bay~
      04-02-2006, 06:00 PM   #14
bavarian19
bavarian19's Avatar
Drives: Car
How does it drive now? Is it a noticeable difference???
      04-02-2006, 11:33 PM   #15
tiga901
tiga901's Avatar
I did notice a much accurate turns especially sharp corners.....but maybe it's just me. I still think it's worth it!
      04-03-2006, 12:06 AM   #16
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
No, it's not you, it actually works! I want one!!
Danny
      04-03-2006, 12:39 PM   #17
zzinco79
zzinco79's Avatar
124
Danny
I prefer morristown~~
      04-03-2006, 02:01 PM   #18
zzinco79
zzinco79's Avatar
124
Originally Posted by mdemange
Tools needed:
35Nm?? 52Nm???
Please tell me what that is.....
looks like newton*meter...
      04-03-2006, 02:30 PM   #19
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
35Nm?? 52Nm???
It means ft. lbs. torque for us here...
Danny
      04-03-2006, 02:44 PM   #20
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Danny
Nope..those work well. Can be a good addition for those who enjoy spirited driving.
      04-03-2006, 07:01 PM   #21
zzinco79
zzinco79's Avatar
124
Danny
So... Just buy a torque wrench for easy way????
      04-03-2006, 07:07 PM   #22
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
You should have a torque wrench handy if you do any kind of wrenching on a car. Most bolts are torqued to a certain setting, number of pounds of force. If you over-tighten, bad things can happen, same with not tight enough.
Danny
