08-10-2019, 09:20 PM | #1 |
Rep 29
A/C Smell...
Hello all, I have had my 2019 X5 40i since late October last year, and have only recently in the last few months noticed an odd musty smell for the first few minutes that the A/C runs.
I did a little research and found that this may be typical of an older BMW where mold or mildew forms on the evaporator core, and found several videos of folks showing how to address this on there 5-8 year old BMW. I was not expecting this to happen so soon for mine. I notice the smell when the a/c first starts, and also after it has been on for a while and the system seems to cycle or meet its "auto" temperature. The smell is not terrible, but I make a face everytime and fear that it may be getting worse. Anyone else have a smell in their G05? Any suggestions or recommendations? |
08-10-2019, 09:26 PM | #2 |
Rep 236
I haven’t had my G05 long enough (only couple weeks) and I’m very happy with my AC but I’d deal with this issue under warranty. None of my many previous cars from few to 10 + years old of various brands had any AC smell. Neither of them were BMW-s though I just know it’s not normal.
08-10-2019, 09:28 PM | #3 |
Rep 250
I have started to notice this on my G05. I had the same issue on my F10 but was never able to fix it even after multiple visits to the dealership. They claim to have done a full cleaning as well as replace the carbon filters.
08-10-2019, 09:41 PM | #5 |
Rep 5,500
Drives: 23 X7 40i; 23 M3; 24 cooper s
I don't think it's a model specific issue. I have this exact same issue on my infiniti and have never been able to fix it permanently. I'll spray the vents which fixes it temporarily, but it always comes back. The dealer hasn't been much help either. Not sure why some cars have this happen.
08-11-2019, 08:57 AM | #7 | |
Rep 4,477
Have you verified that your compressor is not turning off on when you notice the smell. I know you said you notice it when it first starts up, I just wonder if the compressor turns on just long enough to make the lines/evap cold and then shuts off without any indication. Have you gone into your iDrive settings and verified that you have the A/C set for max cooling? I don't believe its set that way by default. |
08-11-2019, 09:10 AM | #8 |
Rep 7,586
This is easy to prevent if the smell (bacteria & mold) hasn't started yet...or if you kill it and use a feature BMW includes (or used to include) in the HVAC system.
If you're BMW has the parked-ventilation feature...if you use it when you've parked your BMW after running the AC on a very hot/humid day and you've parked the vehicle in a location that is dark and doesn't have air circulation (like your garage). When you park in a dark location with no or limited air circulation, this is a prime environment for the growth of bacteria and mold on the condenser and your AC system that is still wet with condensate. Thus once the bacteria and mold starts to grow...you'll get that funky AC smell upon start up. This is NOT just a BMW thing...but any car were the same environment is prime for the growth of bacteria and mold. I have used this feature on every BMW that I've owned that had it (my e32/e34/e38/e39/e53/f06)...and it does help dry things out when I pull into the garage after driving around with the AC running. I even programmed one of the eight preset buttons on my f06's CIC iDrive to take me directly to the CLIMATE page in so that it is easy to activate it once I pull into the garage. If anyone is unfamiliar with this feature...it will run the HVAC blower for up to 30 minutes (with the engine NOT running). You can also program up to two different "timed" parked-ventilation...like if you want to reduce the heat build up when you get off work. You can set a timed event to turn on the HVAC blower prior to your leaving work. It doesn't turn on the AC, but it will circulate ambient air into the cabin which is cooler than the built up air temp from the car sitting in the sun. So instead of the car's interior being 120° F...the blower will turn on and blow ambient air (what ever that is) into the cabin...it would be like rolling the windows down prior to you coming back to the car.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-11-2019 at 09:22 AM.. |
08-11-2019, 09:50 AM | #10 | |
Rep 7,586
EDIT: I just googled for a G05 owners manual (PDF) and it appears the G05 X5 does have this feature (instructions started on page 278 of the PDF version). But it is now accessible multiple ways. You can access the set-up for this feature using the:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-11-2019 at 10:09 AM.. |
08-11-2019, 11:22 AM | #11 | |
Rep 29
08-14-2023, 11:09 AM | #12 | |
Rep 61
I am also having the same issue in charlotte for the past 2yrs.. lately noticed the same issue with our one year old X5 which lives in kansas city.. i guess some thing wrong with AC unit..in g05 BMW x5s.. of course read the same with some ford and toyotas as well.. but we didn't see this odor in our 2 yr old X3 (dallas).. |
08-14-2023, 12:10 PM | #14 |
Rep 8,887
Drives: eVeRyOnE mAD!
08-14-2023, 01:52 PM | #16 | |
Rep 895
Drives: BMW Z4 M40i, BMW X5x40i
From the manual:
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch |
08-14-2023, 10:03 PM | #17 |
Rep 6,946
The evaporator coil is in the dark, damp, and after you shut the engine off, warms up which is ideal for mold growth. There's a lot of air that moves through the system, and the filter catches most of it, but there will be some organic dust that makes it through (failing to replace the filter when recommended can make this worse, or using a low quality aftermarket one). So, to eliminate the mildew and accumulated crud, there are cleaning materials that can be used that should help. I don't know how easy it is to access the coils, but that is the ultimate fix to clean them.
If the drain gets clogged, that can make it worse. |
08-15-2023, 09:53 AM | #18 | ||
Rep 7,586
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-15-2023 at 10:20 AM.. |
08-23-2023, 03:45 PM | #19 |
Rep 101
i been dealing with this on and off for over 6 months now on my 2019. Did all the following and still eventually came back after a couple of days. Did not have it for first 3 years of ownership.
Tried BMW bombs where it sprays in recirculate for high heat for 20 mins Tried Spraying foam cleaner in air intake under hood and where the cabin filters usually sit with filter removed. Also tried Lysol spray in same area. Tried replacing cabin filter Tried AC Vent Pro INTO all vents Tried spraying foam cleaners into vent Ive owned Acuras MB Infinitis and E92 and never had this problem. I'm now considering to get rid of vehicle. |
08-23-2023, 04:30 PM | #20 |
Rep 1,367
My buddy has a 2012 Mercedes SLK300 convertible and while he says he smells nothing, every time I get in that car the strong mildew smell hits me like a brick.... UGH! Breathing that in can't be good for a person!
Rob |
