Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions M340i Center Speaker Rattle Fix Instructions (with pics)
      09-12-2019, 12:40 PM   #1
gnr4all
Drives: 2020 M340i xDrive SB
First of all thank you to CyclingBroStyle for posting a solution to the speaker rattle problem. I just wanted to post instructions how i fixed it because the noise was driving me crazy and I hope this helps other people with this issue.
Step 1: I found that the cover wasn't easy to just lift up. The speaker cover has 6 clips as shown in the pic below. I used a card to wedge under the speaker cover and to push each clip in. I started with the bottom left clip (closest to steering wheel) I found that I had to push the card into the clip in order to release it and simultaneously lift the cover with a little force. Eventually one at a time, I released all 6 clips. It could be that you can just lift up the cover with pressure but it didn't feel to me as if it would work without breaking the cover
Step 2: Once I lifted the cover off I used felt tape to cover the plastic tab on the top of the speaker cover as shown in the picture below:
Step 3: I then covered those two plastic contact points by the speaker on the sides of where the plastic tab from the speaker cover connects to pictured below:
I then popped the speaker cover back in and now the rattle has gone away. I tested it in Sport+ mode under heavy acceleration and when raising the volume of the stereo under different frequencies.
This is a link to the felt tape I used:
https://www.amazon.com/gp/product/B01455QMX4
      09-12-2019, 03:53 PM   #2
Giggler
408
Drives: 20' M340i, 24' X5 40i
I was actually driving beside a truck with flow-master exhaust... the truck's exhaust frequency set off this rattle big time. I've got the tape on order and thanks for taking the time to detail the process.
gnr4all65.50
      09-12-2019, 03:59 PM   #3
hockeymen14
Drives: 2020 m340i
Oh man- I may be doing this tonight.
      09-13-2019, 10:04 AM   #4
gnr4all
Pleasure! I'm glad I could help.
      09-16-2019, 06:30 PM   #5
JSaid
JSaid's Avatar
Drives: 2022 BMW M340i xDrive
Just got mine back from the dealer and they said they couldn’t reproduce the issue (bullshit). Ordered the tape and I’m trying this as soon as it gets here. Thanks bmw, I swear this forum is more helpful
Appreciate 4
      09-16-2019, 08:40 PM   #6
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3452
Drives: 2020 M340i
2020 BMW M340i  [0.00]
Thanks!!
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com
Top M Client Advisor in New England.
      09-18-2019, 09:08 PM   #7
JSaid
JSaid's Avatar
Just got it done and the sound is gone. Thanks a bunch!
gnr4all65.50
      09-20-2019, 08:38 PM   #8
BinH
Drives: F10 M5
For those of us in a hurry for a fix, you can go to Walmart in the Crafts section and get the fix from Velcro. Velcro Sticky Back 5/8in circles (90971) work perfectly and cost about 3 dollars.
I placed them as gnr4all posted and the rattle is gone.
Thanks gnr4all!
gnr4all65.50
      09-21-2019, 03:05 PM   #9
CyclingBroStyle
CyclingBroStyle's Avatar
Drives: '19 330i xDrive M Sport
Thumbs up
You have my stamp of approval!!! Great write up! Thanks for the shoutout!
Current: MY2019 330i xDrive M-Sport w/Lasers - Portimao Blue
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey
BMW CCA #522637 use me as a referral for BMW CCA
gnr4all65.50
      09-21-2019, 09:06 PM   #10
kohlzor
Drives: 2017 M240xi
Awesome write up! I did end up taking mine to the dealer and they added felt and the rattle is gone.
      10-05-2019, 12:10 AM   #11
Don Mico
My First Bimmer
Don Mico's Avatar
Drives: 2020 M340i
Thanks. I’m sharing this with my service advisor at crevier BMW. The noise is driving me nuts.
      10-20-2019, 07:47 AM   #12
Don Mico
My First Bimmer
Don Mico's Avatar
Drives: 2020 M340i
Thank you gnr4all, Crevier BMW fixed it using the same solution.
gnr4all65.50
      10-24-2019, 10:58 AM   #13
NeverEnough007
Drives: 2020 M340i & 1991 Mtechnic E30
Thank you! I have only had mine for a few hundred miles and was trying to track down that rattle. I thought it was coming from the heads up display area. I will investigate tonight.
gnr4all65.50
      10-31-2019, 03:10 PM   #14
KrisJ
Drives: 330e G20
Anybody with a sunroof notice there are also quite a bit of squeaks coming so where from around the rail?
I removed the rubber bit that covers the mechanical parts of the rail but the issue persists. It's driving me nuts.
      11-03-2019, 08:33 AM   #15
jcrosa
Brazil
13
Drives: BMW X5 45e M Sport 2022
Many, many thanks for posting these instructions! this was driving me mad!
gnr4all65.50
      11-22-2019, 02:51 PM   #16
imported_nick
Drives:
This was the first thing I noticed on my new m340i... I was able to stop the rattle by pressing down on the center grille with my hand. I can't believe we have to resort to these kind of fixes on a 2020 BMW, this is something I expect from a 2008 Subaru. Thanks for the post.
      12-03-2019, 03:49 AM   #17
Mb73288
Drives: 2019 bmw 330i xdrive
Finally did this fix last night. That rattle was driving me nuts. I had a little trouble pushing those clips in and out but i have to say it fixed that rattle 100%. Great fix to an annoying problem
      12-25-2019, 02:51 PM   #18
DallasExec
Drives: 2020 M340i
+1 for this fix, just completed it in my M340i and the buzz is gone. I used the sticky velcro pads recommended earlier in the thread.
Thanks again for posting the fix.
      12-27-2019, 08:24 PM   #19
G2020VISION
G2020VISION's Avatar
Drives: 20 m340ix
2020 M340I X  [0.00]
Thanks for post.. eliminated that annoying speaker noise... now trying to find that intermitten sunroof noise... any suggestions
      12-28-2019, 08:32 AM   #20
Simsimma7
Simsimma7's Avatar
Drives: M340i XDrive
Amazing. Thank you so much!
      12-29-2019, 10:28 AM   #21
ercnclk
ercnclk's Avatar
Turkey
Drives: bmw G20 320i
thanks!
      01-01-2020, 01:18 AM   #22
pkancel
pkancel's Avatar
Drives: BMWs
Perfect fix, thank you so much. Oddly though, dont have the problem in our G20 330i, just the M but maybe the suspension, engine, etc in the M are all drivers of the issue as well.
Tags
speaker rattle fix
g20
