10-05-2019, 11:01 AM | #1 |
Rep 72
Weird Underbody (maybe)/Rear Squeaking Noise?
Hi all, has anyone experienced a strange squeaking noise coming from the underbody? It sounds like (for lack of a better description) a rubber chicken squeak toy. I heard it on a few occasions over the last few months going over manholes/speed bumps at parking lot speed, and the noise was very brief. Took it to the dealer, they couldn't duplicate it (of course).
But today, the squeak lasted a good 4-5 seconds in the first mile or so of driving (then nothing after I was ready to record it); and the pitch changes a little as I was going down the road, which led me to think it may be suspension related (I don't have air suspension). In terms of driving conditions, temperature is the first much cooler day in my area (50-55F), I was going about 30-40mph, heard it with driver's window open. Thanks in advance for your thoughts and experiences.... Last edited by Pete7_li; 10-18-2019 at 09:17 AM.. |
10-13-2019, 06:05 AM | #2 | |
224
Rep 314
I had the same noise about a month ago for a couple hours... Wanted to show my wife and then it disappeared - ??? Hasn't returned! Good luck. |
Pete7_li46.50 |
10-15-2019, 10:29 AM | #3 |
Rep 72
Thank you! It's at the dealer now, hope they will find a cause...Here's an audio clip from last weekend if anyone has or may experience it.
10-17-2019, 01:58 PM | #4 |
Rep 7
Weird underbody (Maybe Suspension Related) Squeaking Noise?
Hi I have the same issue, I like to say it's like you blowing in a Kazoo for 1- 4 sec. definitely rear of the vehicle and cooler days. I have air suspension and rear steering.
Pete do you have rear steering(HSR) ? I have a good audio clip too that ill try to post. |
Pete7_li46.50 |
10-17-2019, 03:51 PM | #6 | ||
Rep 72
And for reference in case anyone is curious, my X5 is a March 2019 build (leased in April) and has just over 5,000 miles. Last edited by Pete7_li; 10-17-2019 at 04:01 PM.. |
10-17-2019, 04:07 PM | #7 | |
Rep 4,333
10-17-2019, 04:15 PM | #8 | |
Rep 72
Totalangle's description of a kazoo is pretty accurate, as well. |
10-17-2019, 04:21 PM | #9 | |
Rep 4,333
10-17-2019, 04:51 PM | #10 |
Rep 72
10-17-2019, 04:59 PM | #11 |
Rep 903
10-17-2019, 05:02 PM | #12 |
Rep 7
Hi there here is the link to youtube I just posted. speedy driving 30- 40, seam to happen "after" the vehicle was accelerated. but the noise usual happen on coast/decal/ or light steady throttle.
you might need to cut and paste the link, not sure how to embed the video right in the sight. |
WAHF80M377.00 |
10-17-2019, 05:10 PM | #13 | |
Rep 72
10-17-2019, 08:28 PM | #15 |
Rep 7
Pete fell free to share if you think it's the same noise. I like the go pro idea I might try that too. My audio clip was the I phone in the back set. It very interment but worse on cool morning for the first 1hr of driving. Never noticed on bumps just normal road and it seams outside the vehicle. It will happen in all 3 modes comfort/sport/eco. 30-80. Occasional it will do it after accelerating on to the highway. Very int. And hard make it happen. Ie at the dealer
10-17-2019, 09:59 PM | #16 |
Rep 90
I would like to confirm I have the EXACT same noise, tested with similar driving situation as Totalangle - mine was built in Sept 2019 - booked into the dealer next week - the sound Totalangle did will help a lot - if you have similar noise, please go to your local dealer and make a request to look into it with your and Totalangle’s recording - the more people who reports this the more and faster BMW will come up with a response/solution - hope this is not serious or another recall will be issued....
10-18-2019, 09:14 AM | #17 |
Rep 72
Here's a new video/sound clip I took this morning. Totalangle is right that it's coming from the rear as this was taken from the back seat with windows closed; between 40-65mph; temperature ~45-50F outside. It went on for a good 20 seconds, sent it to the dealer.
10-18-2019, 10:48 AM | #19 | |
Rep 4,333
Sorta sounds like when a bit of oxidation forms on rotors overnight or after washing the car and then when driving, the brake pads slowly grind it off. If so, its normal and easy to test. Once you take off and you are hearing it, you apply your brakes rather hard in both forward and reverse so as to grind it off both front and rear brakes. Its more common to hear it in the rear since the rear brakes don't see the pressure as much which is why you need to get up to a little speed in reverse and then hit the brakes. If you do this and it goes away, then I wouldn't worry. The other way to test it is to first just look at your rear rotors, are they oxidized? Not sure on the G05 but if its possible to put it in neutral and turn the car off, you can jack up the rears and spin the tire by hand and listen. One other thing to look for is the brake dust shield, possibly its a little out of whack (bent) and might be scraping against the rotor as it turns. Well, those are some thoughts off the top of my head, if you do get it solved, let us know. |
10-26-2019, 03:54 PM | #20 |
Rep 90
Wanna bring this back for update - dealer checked - of course they can NOT duplicate the noise - kept the car for 2 days - came back, weirdly noise disappeared for awhile but just came back today AGAIN for roughly 2 seconds.
Anyone else have updates from dealers in regards to this weird noise??? |
10-26-2019, 06:09 PM | #21 |
Rep 20
Finally others with the same issue!! I've been dealing with this for the last month. Also took to the dealer and they could not duplicate. Augist 19 build, 2020 model. Comes and goes. Can't duplicate if I tried. Annoying, but at least so far does not seem to have any other impact on the ride. Will keep others posted if we find a solution.
