      10-15-2019, 02:38 PM   #1
mnewnam
270
Drives: '21 Mineral White X5MC
Exhaust smell at cold start
So, if I get in the car ('19 X5 40i) and start it when cold there's a whiff of exhaust while the engine warms up. If I run around to a few different stores I won't smell it at each of those starts from warm. However, the next cold start will do the same thing. It's the same smell you get if standing behind the vehicle when it starts. At first I thought maybe I was starting it before I closed my door but even with making sure it's closed before starting I still get it. If I remote start and wait, the smell has mostly dissipated by the time I get in.
I reached out to my SA to bring it in, but wondered if anyone else has experienced something like this. Thank you!
      07-14-2020, 04:32 AM   #2
Ninefourteener
Ninefourteener's Avatar
1340
Drives: 2020 X5 M50i, 2020 Alfa 4C
It's normal when cold-starting to run an extremely rich fuel mixture. That helps the car warm up to operating temperature. Similar to using a choke back in carburetor days. It's not uncommon to have a fuel smell OUTSIDE the car when cold starting.
inside the car however.... you should not smell it. If you do, it's possible you may have an exhaust leak.
If you have an exhaust leak that you can smell inside the car during cold start.... then you still have an exhaust leak inside the car that you CANNOT smell during normal operations. Fuel has a smell.... Carbon Monoxide does not. If it's leaking into your car when you start it..... it's still leaking into your car under normal operation.... you just can't smell it as much.
Take it to the dealer and have them thoroughly check for exhaust leaks. They can be dangerous, and even cause you to pass out while driving if left running for too long. If nothing else, you're likely to get headaches that you can't explain.
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342
      08-22-2020, 02:36 AM   #3
jsmonet
Drives: 2020 x7 m50i
if you're smelling it inside the car with everything closed, you may have a leak somewhere. smelling this outside is perfectly normal because your catalytic converters don't really work efficiently until they're hot, so when cold they won't catch and burn/react off everything.
2020 bmw xHippo, v8tt edition
