SiriusXM and Combox Help
10-26-2019, 04:58 PM | #1 |
Rep 715
Drives: 2021 X3 M40i
I've been having some wiring done to my car and it got me thinking about SiriusXM again, so I decided to go out and pull the radio to check it out. And...
I do have the pink connector on the back and the top label does show SiriusXM. So now comes the questions... I have the BimmerGeeks Pro Tool on a Tablet. Can I use that to activate my SiriusXM, or do I HAVE to go to the Stealership to have it activated? Which leads to my second question: I've been reading that I need an FSC Code to activate the radio. Can I get it from somewhere else (like Dracon) or ONLY at the Stealership? And on the Combox side, why does the label show Combox if I don't have it? Or do I have it and I just need to activate it with the Pro Tool? I've provided pics for reference in case anyone is interested in what the pink connector and label look like.
10-26-2019, 06:07 PM | #2 |
1917
Rep 13,109
You would have to enable it with coding add and antenna and you might get
away with just calling Serius to get a subscription and enabling. The other route is to call up Bimmertech to do the programming and enable the subscription. Also these are mostly coding board/sub forum questions |
hybrid90246.50 |
10-26-2019, 06:20 PM | #3 | |
Rep 715
I'll give the coding a try first, and if that doesn't do anything, I'll contact Bimmertech to see what they can do. Thank you so much!!
