10-29-2019, 10:02 PM | #1 |
![]() 120
Rep 214
Thinking about getting a spare set of rims and tires off eBay. Will the tire pressure monitoring system in the car work with any tire pressure sensor? How does it work? Is it basically like pairing your phone to the car? If so how do I pair it?
10-30-2019, 08:09 AM | #2 | |
![]() ![]() ![]() ![]() 50
Rep 420
Find the reset process and then you start driving, while in motion your vehicle communicates with the TPMS sensors. I believe the sensors must be 433Mhz, and note that they run on batteries and can fail. I had a set of wheels that we recently put on my wife's car after some time in storage but the batteries failed so the sensors will be replaced. Hope, that helps. |
10-30-2019, 11:09 AM | #3 | ||
![]() 120
Rep 214
10-30-2019, 01:31 PM | #4 | |
![]() ![]() ![]() 5408
Rep 8,703
Then shop online using the 11 digit BMW part nbr (ie type BMW xx xx x xxx xxx {where x=the actual number) into a google search box or ebay or amazon.com. There are aftermarket sensors that will work but may need to be "awakened" with a tool that many tire places have. Or if you order online, they may ask for your model/model year and send you the correct oe or oem sensors ready to work.
![]() Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. ![]() Last edited by Qsilver7; 10-30-2019 at 01:42 PM.. |
10-30-2019, 02:43 PM | #5 | ||
![]() 120
Rep 214
