      11-03-2019, 12:05 PM   #1
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
Coding Engine Sound on G05
I was pocking around HU_MGU module to see if I could find anything about Active Sound Design (ASD) and while I didn't yet see anything about ASD, I did come across two interesting FDL parameters:
DISPLAY_MENU_CONFIGURATION_ENGINE_SOUND
​​currently = disabled [00]
​​try = enabled [01]
​​DISPLAY_CONFIGURABILITY_ENGINE_SOUND
​​currently = nicht_aktiv [00]
​​try = aktiv [01]
​​also exists = aktiv_no_sport [02]
I set enable and aktive respectively for both and now have the ENGINE SOUND menu in Car/Settings/General per pics. But ... the menu items are not selectable, so it's not going to be that easy.
Any ideas on where to look for next steps?
marcosg24.50
buze132.00
      11-05-2019, 03:57 AM   #2
buze
Owner
United Kingdom
132
Drives: G05 30d M-Sport
Looks like a great option to have! Please continue digging :-)
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
      11-05-2019, 09:17 AM   #3
micmitch
Drives: 2019 X5, 2018 Accord
I expect that's the internal cabin engine sound coming through the audio equipment
      11-06-2019, 08:01 PM   #4
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
I've just learned on another thread that M50i has that menu active from factory. So, anyone out there with an M50i (and that menu functioning) that's into coding willing to supply your FA, SVT, and, most importantly, full set of NCD files for differential analysis?
marcosg24.50
      11-08-2019, 09:46 PM   #5
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Weekends are a great time to help out a fellow coder. Anyone with an M50i want to send me your full set of .NCD files? Please DM.
      11-08-2019, 11:21 PM   #6
FreddyBMW
FreddyBMW's Avatar
95
Drives: 2019 X7 40i iSTEP 07/2020.54
Great. Please PM/DM me too when you get it. Thank you!!
      11-09-2019, 08:03 PM   #7
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Ok, there might be another way. I believe there is a way to reproduce the stock NCD files from a VIN. So alternately to NCD files, please consider privately and with assured confidentiality sharing your M50i VIN and I'll try to try produce the files myself from that.
      11-09-2019, 08:54 PM   #8
homerrr
homerrr's Avatar
Drives: BMW G05
Maybe find a dealer website and pull the vin from their inventory? Like this 2020 BMW X5 M50i : 5UXJU4C08LLE45523
      11-09-2019, 09:03 PM   #9
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Nice! Let me work with that ...
homerrr133.50
      11-12-2019, 12:41 PM   #10
bichoo
bichoo's Avatar
281
Drives: BMW X5 40i M-Sport
Thanks for your work on this, I hope you can crack it!
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold)
2012 BMW X3 28i (sold)
      11-12-2019, 03:46 PM   #11
spike5150
Drives: 2020 X5 M50i
I can share mine, but it might be a week or two before I can pull all the files. Is there a more streamlined way to read all the coding data than 1 at a time?
      11-12-2019, 07:06 PM   #12
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Awesome. Yes, there is a simple way to grab all .NCD files. In ESys Coding, Read FA and Read (ECU) SVT as usual. Then right click the SVT[VIN] at the top level and choose Read Coding Data. When done, Save FA, Save SVT and send me those. Then also send all the .NCD files in Data/CAF directory — those are files from each ECU read by Read Coding Data above.
Please send me a DM for email address.
Thanks!
buze132.00
      11-29-2019, 07:42 AM   #13
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
Bimmercode can turn on active sound now (it doesn't seem to add these menu items though, so may try to turn on the menu items now that I have active sound turned on. Bimmercode turns it on in an ECU called RAM if that helps.
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      11-29-2019, 11:48 AM   #14
KrisV
KrisV's Avatar
Drives: 2023 BMW X5 M Competition
did you find out how to code the menu items on yet?
      11-29-2019, 03:43 PM   #15
roadkillrob
Seems no as no expert mode on that ECU, so you would need an esys setup to do it.
2008 E93 335i FBO
      11-30-2019, 08:07 PM   #16
Mieleo
Drives: 2019 x5
Hi
Is your car xline or with M package?
      11-30-2019, 08:39 PM   #17
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
I am not convinced these engine sounds menu items are directly related to ASD — ASD FDL parameters are structurally and localized very different from these engine sound parameters in the coding.
For these engine sound settings, I haven't made much progress. I had done a few comparisons against synthetically generated coding files from M50i VINs and nothing jumped out. I would really prefer to compare directly against a known working M50i FDL FA, SVT, and full NCD set. Anyone?
I played with ASD in my car, noted in another thread, and decided to leave ASD turned on:
https://www.bimmerpost.com/forums/sh...php?p=25495306
      12-01-2019, 07:00 AM   #18
roadkillrob
Originally Posted by Mieleo View Post
Hi
I have an M sport.
2008 E93 335i FBO
      12-01-2019, 02:05 PM   #19
Mieleo
Drives: 2019 x5
Hi
I have an M sport.
I'm wonder Will xline car able to code active sound?
      12-18-2019, 01:52 PM   #20
bohdan__l
Drives: BMW X5 G05 40i
I`m also very interested in this! I have Xline and tried to turn on ASD with the Bimmercode app but nothing happens.
Do some of you know how to solve this? I`d really love to have this feature in my car!
      12-18-2019, 08:42 PM   #21
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Have a look at this summary: https://www.bimmerpost.com/forums/sh...php?p=25495306
You can try in Bimmercode. If it doesn't show there (which could be the case if hardware is not present or coded out by VO coding from factory), I will look up the FDL parameters for ESys coding it when I get a chance.
      12-19-2019, 07:24 AM   #22
bohdan__l
Thank you!
