      11-09-2019, 02:25 PM   #1
Kief
Kief's Avatar
4436
Drives: '24 iX50; '23 i4 M50
17mm Lug Bolts, Correct?
I can still use my 17mm socket for the G05? The lug bolts look different than my F80 M3. I thought I read somewhere that the G chassis not only changed bolt pattern but lug bolts? However, according to wheel-size.com, both the G05 and F80 have the same M14 x 1.25
arciga18??
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired
      11-12-2019, 10:33 PM   #2
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
arciga18??
Yes, same lug bolts. Just newer design where it have washer for the cone seat.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
Kief4435.50
      01-03-2020, 12:56 PM   #3
arciga18
arciga18's Avatar
1729
Drives: LeMans/ Chestnut E90, RWD
Will the h and r extended bolts seat correctly or do we need to purchase new extended bolts
      01-03-2020, 01:05 PM   #4
r33_RGSport
Yes, it will sit correctly.
They are the same cone shape and degree.
arciga181728.50
      01-03-2020, 01:13 PM   #5
arciga18
arciga18's Avatar
1729
Here are some crude before and after.
15mm h and r from our good friend r33_RGSport
r33_RGSport12967.50
      01-03-2020, 01:26 PM   #6
arciga18
arciga18's Avatar
1729
To clarify 15mm on all four corners .
Here is the rear .
r33_RGSport12967.50
      01-03-2020, 01:55 PM   #7
arciga18
arciga18's Avatar
1729
@Kief What's the torque spec ?
      01-03-2020, 03:05 PM   #8
r33_RGSport
I put 110lbs-ft when using spacers.
      01-03-2020, 03:18 PM   #9
arciga18
arciga18's Avatar
1729
thanks
r33_RGSport12967.50
