Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Fog light retrofit kit
      11-19-2019, 10:45 PM   #1
BEK46
BEK46's Avatar
Drives: 2019 BMW 330 x-drive
Has anyone, anywhere, found a factory fog light retrofit kit for G20 non M-sport 330s? Fog lights are available as a stand alone option on non M-sport 330s in Canada and many other markets but not US. My dealer has looked into this but only within the US. Thanks.
      11-20-2019, 10:54 AM   #2
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
I’m interested in this as well but then I assume the headlight control switch panel has to be changed too? Or can u just add a fog lamp switch in the dummy slot? Plus it might end up being very expensive.
      11-20-2019, 09:21 PM   #3
BEK46
BEK46's Avatar
My understanding is that the switch is all that is needed for the dash. The primary question is: is the harness preinstalled from the dash to the light modules? If not, this will probably be prohibitively expensive. This is a $250 single add on option in Canada so the parts cannot be all that much, but according to a very helpful Canadian dealer, when you actually part them out, it is over $900😱.
g20
