Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Enable Tail Lights with DRL on G20
      11-22-2019, 04:50 PM   #1
teapot
Drives: G20 330i
I'm looking for a way to make rear lights turn on automatically when DRLs are on. My understanding is that in Europe they are always on (like front day lights), but in US they are turning on with low beams when it's dark.
I asked Bimmercode support, they said they can't do it for G-series cars.
Has anybody done it? How?
Thanks!
      11-22-2019, 05:22 PM   #2
dejansokolovski
Drives: BMW 330e G20, BMW 520D F11
Thanks!
I would like that also!
The taillights are off in Sweden, Europe too when daylight outside.. only the drl in front are on in daylight. When button is on auto.
      11-28-2019, 08:00 AM   #3
ring0r
Germany
101
Drives: G20 330i
I've tried so much but unfortunately still not found the value in Esys ... very annoying
      11-28-2019, 01:49 PM   #4
themnmd
themnmd's Avatar
Drives: 23 X5MC
In USA I believe you just turn on park lights and you get both tail lights and drls
      12-05-2019, 02:30 PM   #5
teapot
Drives: G20 330i
Yes, but it disables automatic lights, so when it gets dark it's easy to forget to switch low beams on
themnmd1691.00
      03-10-2020, 09:55 PM   #6
margorga
Drives: BMW m340i
With esys,
HU_MGU/HMI_SPEECH/DAYDRIVING_LIGHT_REAR = aktiv
Poochie9104.50
RSnic657.50
      03-13-2020, 01:55 AM   #7
ring0r
Germany
101
Drives: G20 330i
Originally Posted by margorga View Post
With esys,
This code gives you the possibility to activate the rear light on the Daytime Running Light on your Display but it is not activated. I have already tried it and it dont works ...
      03-15-2020, 06:04 AM   #8
MF-Racing
United Kingdom
11
Drives: M340i
I'd like to be able to do this. I have eSys.
      04-25-2020, 07:47 PM   #9
ixxo
Czech_Republic
Drives: BMW M340i
Hi guys, any update on this? IŽd love to have the rear (tail) lights on as the DRL. I used to have it that way on all of my previous cars (Audi, VW) where it was quite simple. The only thing you had to do was code it (with VCDS) as a "Scandinavian mode" or something similar. I thought itŽs required in Scandinavia, but it seems from the post above thatŽs not the case at all...
      04-26-2020, 03:38 AM   #10
igorbutarev
igorbutarev's Avatar
Russia
26
Drives: F30 320i G20 320d
I set drl_s at DRL_MODUS in BDC. In F-series this works, but in my new G20 nothing change. May be there is other code in BDC or MGU that turn tail lights on. Still searching
      04-26-2020, 11:10 AM   #11
dergrenni
Drives: BMW G20
Try activating:
BDC / 3702LicFeatures / Feature_4
      04-26-2020, 10:53 PM   #12
phayze
Drives: BMW
For europe, is the tail lights always lighted when set to auto light whenever the engine is running?
      04-27-2020, 01:30 AM   #13
GeniusAdam
BMW Genius
Ukraine
116
Drives: BMW
You are able to switch on/off the rear DRL in the iDrive menu (ID7), under exterior lighting. Cars with the new software have this function.
Ex factory only the front DRL is on with auto lights.
      04-27-2020, 04:41 AM   #14
phayze
Drives: BMW
What version software does it have the rear light function?
      04-30-2020, 01:48 AM   #15
GeniusAdam
BMW Genius
Ukraine
116
Drives: BMW
Can not tell you the exact SW version
G20 I have available has the SW version 07/2019.55, but it does not have this funcion. For example with G05 it works with SW 07/2019.55, F44 11/2019.50.
      04-30-2020, 02:50 AM   #16
dergrenni
Drives: BMW G20
Just use BimmerCode in Expert Mode on BDC:
      04-30-2020, 06:58 AM   #17
phayze
Drives: BMW
What does this do?
      04-30-2020, 09:38 AM   #18
dergrenni
Drives: BMW G20
What does this do?
Enables Tail Lights with DRL
      04-30-2020, 07:26 PM   #19
phayze
Drives: BMW
Do you have any idea how to code the rear tail light DRL checkbox?
      05-01-2020, 06:51 AM   #20
dergrenni
Drives: BMW G20
There is one option in HU_MGU HMI_SPEECHES and the checkbox would be displayed. But it is without function. So if you want taillights in DRL you can switch it on permanently with the above mentioned settings in BDC.
      05-01-2020, 05:20 PM   #21
murderedg20
murderedg20's Avatar
89
Drives: 2019 330i M Sport
Just coded the always on taillights and it works. Not sure if I'm going to keep it on though.
      05-03-2020, 04:01 PM   #22
ixxo
Czech_Republic
Drives: BMW M340i
I'm on 03/2020... SW as the car was delivered in April but there is no check box for DRL at all. I'll wait for an OTA update but I'd expect the only way to have it enabled will be still the (custom) coding :/
g20
