Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Coding Alpina/M cluster on live cockpit
      11-24-2019, 03:47 PM   #1
B58SP
Drives: 2017 M240i SOLD
Here is a picture of the alpina cluster (on a base x3) that I was able to code. The M version (that in the M8) is also available
      11-27-2019, 03:11 PM   #2
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3452
Drives: 2020 M340i
2020 BMW M340i  [0.00]
In the M version, the map area is smaller and does not display driving modes.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com
Top M Client Advisor in New England.
      11-27-2019, 04:11 PM   #3
siegester
siegester's Avatar
345
Drives: '20 M340i
correct. here is the M version. there is almost unnoticeable changes between driving modes
https://g20.bimmerpost.com/forums/at...1&d=1574812276
      03-01-2020, 12:47 AM   #4
hamzag20
hamzag20's Avatar
557
Drives: BMW G20 330i, BMW G30 540i
Does the Alpina cluster show the Alpina logo? On my G30 with the Alpina cluster, the Alpina logo isn't shown. If the Alpina logo is shown, is there anyway to get rid of it?
      03-01-2020, 07:47 AM   #5
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
No idea. I tried searching for it but couldn’t find an answer. I don’t want the alpina logo either which is why I haven’t coded it yet. I could have test coded it but I hate that the Bluetooth dongle is so slow and I don’t have much patience to code and then uncode it
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      03-01-2020, 10:32 AM   #6
hamzag20
hamzag20's Avatar
557
Hoping one of these guys responds but I think it doesn't show it, bc someone else w a g20 also coded it and didn't have the logo.
      03-01-2020, 10:41 AM   #7
VipinLJ
Petrolhead
VipinLJ's Avatar
Yup. As per the post below, there’s no alpina logo. I’ll try it out in a few hours and see if the logo is present.
Originally Posted by Master0wn3r View Post
After updating my e-sys I tried to code the alpina display on my new 330i.
This works both for G20 and G21
Had to code 2 values (one enabled the alpina option, and the other lets you choose between default, M or Alpina). If people are interested I will go back and check the parameters, and list them below but forgot to write them down :-(.
anyway the photos:
default (for reference)
Comfort mode:
Sport mode:
Did not take a picture of eco pro mode... who the hell uses eco pro?!
Current:
hamzag20557.00
      03-01-2020, 11:04 AM   #8
hamzag20
hamzag20's Avatar
557
anyway the photos:
Comfort mode:
Sport mode:
Problem is I like the Alpina cluster in comfort but I don't prefer it in sport. I'd rather go w the stock cluster in sport tbh.
      03-01-2020, 11:51 AM   #9
pneumodoc
pneumodoc's Avatar
233
Drives: G20, G01
You can also go into iDrive and change whether the instrument cluster changes based on drive mode.
      03-01-2020, 11:54 AM   #10
hamzag20
hamzag20's Avatar
557
Well in sport I just want the stock sport cluster not the comfort Alpina cluster lol. I just think the stock sport cluster is better than Alpina. I'll probs stick to stock.
      03-01-2020, 12:13 PM   #11
VipinLJ
Petrolhead
VipinLJ's Avatar
Yea no. Coded alpina, took the photo and coded back to stock. Though there probably is an option to remove the alpina lettering if you go into expert mode. I tried but couldn't understand a thing in there.
Current:
hamzag20557.00
      03-01-2020, 05:41 PM   #12
902
138
Drives: 2020 M340i xDrive
Go to expert, search for GLOBAL_LAYOUT_VARIANTE and set it to alpina
Then search for LOGO_SCHRIFTZUG and set that to kein_logo
You're welcome.
Appreciate 3
VipinLJ1941.50
mathys202.50
      03-01-2020, 08:34 PM   #13
VipinLJ
Petrolhead
VipinLJ's Avatar
You're welcome.
Are those under one of those options below? Those are the only options I can see under instrument cluster in the expert mode!
Thank you irrespective. Probably mine is different because I'm on android? Or checking under the wrong module?
Current:
      03-01-2020, 08:43 PM   #14
902
138
You're welcome.
It should be under 3000 and 3001
VipinLJ1941.50
      03-01-2020, 08:48 PM   #15
VipinLJ
Petrolhead
VipinLJ's Avatar
Thank you very much! I’ll check it out tomorrow and post back
Current:
      03-02-2020, 03:03 PM   #16
VipinLJ
Petrolhead
VipinLJ's Avatar
I did what @902 mentioned and it worked. No more alpina logo except when the cluster turns on or off.
I'll be running it for a few days in this mode and see if i like it before going back to stock, if i do go back to stock.
Current:
      03-02-2020, 06:16 PM   #17
g20beam
g20beam's Avatar
475
Drives: G20 330i M Sport
2019 BMW  [0.00]
Anyone have any idea how or if it is possible to code the M8's track cluster into the G20? Is there any coding to do that with Esys or Bimmercode? If anyone is confused to what I am talking about, it's this layout attached below:
      03-02-2020, 06:30 PM   #18
VipinLJ
Petrolhead
VipinLJ's Avatar
The global layout option had three choices - BMW, M and Alpina. I assume the M is the M from the M5. There is also an option for custom value. They probably might add the M8 cluster in the future there?
Current:
iduk1.00
      03-02-2020, 10:51 PM   #19
pneumodoc
pneumodoc's Avatar
233
Drives: G20, G01
I tried same thing. Didn't like the alpina gauges, to be honest. I really like the M gauges, if only it showed what driving mode you were in in the bottom right corner like the others.
Jbrock22221.50
VipinLJ1941.50
      03-02-2020, 11:02 PM   #20
Beam330
Beam330's Avatar
29
Drives: 2019 BMW 330i xDrive M Sport
I like comfort mode cluster but the green in sport mode looks real odd
      03-03-2020, 12:44 AM   #21
902
138
This is not just a different layout, this is part of the M Track Mode. And no, you can't enable it as far as I know, at least not yet.
      03-03-2020, 09:09 AM   #22
VipinLJ
Petrolhead
VipinLJ's Avatar
Same here. Right now I’m on the fence. Wife likes it but I’m meh about it. The green and blue and orange in the car all doesn’t seem to gel well. The green is what is killing it (in a bad way) for me atm. I thought I’d run it like this for a few days and then, if I can’t stand it, back to stock.
If the M cluster showed the modes, I’d have gone for that. I might try code the M cluster and see how I like it without the modes visible. If I can stand it, I’ll keep that.
I agree. The green is the deal breaker for me too. Only blue would’ve been fine. Or maybe red instead of green?
That makes sense. Hopefully someone finds a way to code the M track mode gauge in. I really like it.
Current:
g20
