11-25-2019, 12:40 AM | #1 |
Rep 51
Bimmercode is now working with G29 in case you want to turn off ASD, and other things
Just got an adapter and gave it a try. Turned off ASD so it didn't mess with the audio (just upgraded the sound system and found that the ASD sound also gets amplified). Pretty stunned at how quiet the drive is without it, and how much it adds...
You can see a full list of features enabled at the moment for the G series cars, and they keep adding things to each beta version, so soon it will support as much as it did for the F series. You can also sign up for the beta version on the app store (scroll down towards the bottom of the description, so you can get access to all features ( I had to get the beta to access ASD functionality) It works on both Android and iOS. I had an android tablet, so went that route as the adapter is cheaper for android devices. https://www.bimmercode.app/cars/g29/ If anyone is in or near LA, you're welcome to use my adapter and app if you want to change a few things. Last edited by auditorycanvas; 11-25-2019 at 01:38 AM.. |
03-28-2020, 05:50 PM | #3 |
Rep 2,807
Drives: F33 430 and F39 M35i
Turning off ASD was the sole reason for me getting an adapter and bimmercode. I like quiet cars. Then I started coding everything else that I liked. Hoping my adapter works on G cars since that's what I'm looking at next.
03-28-2020, 08:42 PM | #4 |
Rep 408
I got the MHD wifi ODB connector. Works great. Coded video in motion, start screen warning off and volume pop up off. Thought i could tune my car using MHD tune app but no maps available for M40i USA version. MHD website not clear on that.
Garage
2014 Z4 35is RIP /2016 Z4 28i RIP 2015 335i RIP 2016 Audi A7 RIP / 19 Genesis G80 RIP 2020 Z4 M40i / 2022 X3 |
03-29-2020, 03:02 PM | #5 | |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
I can vouch that BM3 does indeed work on US Spec Z4 M40i. I have their stage 2 map (version2.1 currently) flashed. Only issue I have is my remote start no longer works.
Project Car: DF Goblin
-Built LSJ-T 2021 C8 Corvette 1LT 2021 Model Y Performance |
03-29-2020, 04:20 PM | #6 |
156
Rep 349
It doesn't look like flashing brake force display is available?
Has anyone coded anti-dazzle?
2017 340i - ZMT, ZTR, Z11, Z08
03-29-2020, 05:47 PM | #7 |
Rep 408
I'm happy with the MHD ODB connector. Very fast works with bimmercode, so all is not wasted. Just wish MHD maps for USA were available. Yes website says supported but thats for EU only.Complained about it but no correction. They say logging is supported but big deal!They mentioned something about beta, but i'm not going to be a guinea pig. Not on a lease. I ordered a JB+ in the meantime. I will check out Bm3 . What are gains stage 1
Garage
03-29-2020, 05:52 PM | #8 |
Rep 408
Turning off asd. Share your experience. Does the sound system sound better?
Garage
03-29-2020, 06:12 PM | #9 | |
Rep 1,303
03-29-2020, 06:23 PM | #10 |
Rep 408
Went on website. Little info on power gains. Did you tune it yourself? I assume you have a downpipe? No warranty for you then
Garage
03-29-2020, 06:47 PM | #11 |
Rep 1,303
Yes I tuned it myself. OBD cable and a laptop and done in 5 minutes. Have a catless downpipe. However, DP alone doesn’t void warranty. It’s the flash tune that will void the warranty. MHD would do the same thing. Any ECU flash will void your warranty.
Their website doesn’t specify expected HP gains as a figure because each engine will perform differently due to operating environment. Instead, they specify expected percentage change over stock because of how BMW programs their ECUs based on power output thresholds instead of set parameters. Meaning if the output threshold is 15% and based on the operating environment it can reach that with less boost/more timing (or visa versa), then it will do so. Because of this, they can’t say “expect +40hp on stage 1” because it may be +30hp for one engine, and +50hp for another. For example, an engine operating near sea level has normal air pressure/density to work with. Therefore, it may produce 380hp at the crank under these conditions. If the threshold is Increased by 15%, it only needs to work a little harder to reach that goal, netting a +57hp increase. However, that same engine operating at 5,000 feet may produce 345hp, but with the increased threshold set to 15% still, it has to work harder to reach that threshold, but ultimately does netting an increase of +52hp. |
Northzed449.50 |
03-29-2020, 08:32 PM | #12 |
Rep 408
I"m sure the downpipe would not interfere with your oil change or other warranty work. But any engine trouble its a dead give away. Had engine problems with MHD and dealer never saw the software. I erased it before dealer visit. (previous Z4).I was under the understanding Mhd can be completely uninstalled. I could be wrong. Why no remote start after tune?
Garage
03-29-2020, 08:33 PM | #13 |
Rep 408
Also supra is getting almost 500hp on there tunes
Garage
03-29-2020, 08:35 PM | #14 |
Rep 408
Bmw really fighting tune according to MHD engineer i spoke with.
Garage
03-29-2020, 11:03 PM | #15 |
Rep 1,303
Had a turbo replaced under warranty on my last bmw with an aftermarket downpipe. Didn’t void the warranty at all. And Bmw can detect a flash tune if they really wanted to. Flashing back to stock doesn’t negate the shadow counter for the number of ECU flashes performed that they can match against their records. They may not have dug into the ECU during your engine trouble because it wasn’t worth it. If you needed an engine replacement I’m sure it would’ve been looked at. BMW has been trying to fight flash tunes for quite some time with enhanced encryption. As soon as the ECU is cracked, BMW looks at the exploit and then patches it and puts out a service bulletin for an ECU flash. It’s a never ending cycle.
And yes, the Supra is getting over 500hp at the crank estimated. Different engine than the one in the z4 M40i (until the 2021 model year Supra). And it’s not on straight 93 octane fuel. They’re running e30 or even e85 and they’re custom tunes, not OTS tunes. I’m positive my stage 2 93 Octane OTS tune is 450+ crank hp because I’m pulling c6 and c7 corvettes that weigh less and are rated at 450 crank hp. Just haven’t had time to swing by the dyno to get numbers yet. |
Northzed449.50 |
03-30-2020, 08:58 AM | #16 |
Rep 514
Drives: BMW Z4 M40i
Does it able to activate song album cover art? Somehow in Hong Kong, this was disabled!
03-30-2020, 10:23 AM | #17 |
Rep 1,303
03-30-2020, 01:10 PM | #18 | ||
17489
Rep 25,116
- Full ASD - Dependant on driving mode - Reduced Great to see this out of the box and my point is I think all future models will have that and maybe even a S/W update on the G29. If you wanted to see this in the states, have a little look around the new F44 2 Series GC (dont be rude ) as I know you don't have the 1er there. OS7 feature is 'Engine Sound' I still really want a Z4 but work doesn't allow it just yet. Pah!
My car made front page of Bimmerpost
03-31-2020, 07:15 AM | #19 |
Rep 514
Drives: BMW Z4 M40i
Thanks.
But anyway, no one will ship the OBD adapter now due to COVID19. Everyone take care.
03-31-2020, 07:37 PM | #20 |
Rep 408
Maybe your not tagging your music correctly. Use Mp3 tag . Free software PC
Garage
04-06-2020, 01:30 AM | #22 | |
Rep 514
Drives: BMW Z4 M40i
That not just me in Hong Kong. Seems all ID7 in Hong Kong did not activate the album cover of the MP3 music. My same music files have album cover display in my Mercedes Benz!
