      12-01-2019, 10:23 AM   #1
randybobandy
Rick James
randybobandy's Avatar
287
Drives: 2020 BMW M340i xDrive
Optimum No Rinse Wash
Is anyone using the Optimum No Rinse Wash to get a quick clean in the winter? I am looking for something to get the street crud off between washes. I prefer the good old hose and bucket, but need a compromise for the colder days.
      12-01-2019, 12:37 PM   #2
ElectroGeek
Drives: X5 G05 50i
Feynlabs Rinseless Wash is what I use. I haven't had any issues. I put it in a pressurised sprayer, spray let drip then wipe. works great.
      12-01-2019, 03:34 PM   #3
randybobandy
Rick James
287
Awesome, I will check it out. I was worried I would cause swirl marks using Optimum.
      12-03-2019, 04:54 PM   #4
DNGRTOM
Drives: F90, G05 M50i, 991.1 TTS
I use ONR as a QD or cleaner (automotive or household)
I've been using Blackfire's WW in the winter. I just got a liter of Carpro ECH20 (another waterless wash) and I'm looking forward to trying it.
I've heard good things about Wolfgang's WW as well
      12-03-2019, 09:25 PM   #5
randybobandy
Rick James
287
Iíll have to check it out. I might look at the foam cannon route for winter as well. At least for the heavy salt and grime stuff. Let me know about the new stuff, as I prefer using something someone can recommend thatís used a few products. Hate this time of the year. Thanks again!
      12-04-2019, 08:46 AM   #6
DNGRTOM
Foam cannon on a pressure washer is great (and fun). you can find a decent one on amazon (I think I use an older version MTM) what makes ease of use is no lance on the pressure gun. So if you can do pressure gun->foam cannon, its way easier to use than gun->lance->foam cannon. You'll have to mess with fittings to get everything to attach but worth it IMO
But - that's a warm weather wash.
When its crappy/cold I use waterless wash 3 out of 4 washes.
if you go this route get a pump sprayer, you don't need fancy, I use this guy ($11 vs $30): https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You'll need a stack of MF towels too, you go thru 1-3 per panel.
      12-04-2019, 11:37 AM   #7
randybobandy
Rick James
287
Thank you for the detailed response. I like the idea of the waterless wash, and know it is CRUCIAL to have a stack of good MF towels. Do you do this even if there is a good layer of the salt and grime along the sides and rear? My plan was to use the pressure washer with the foam cannon to knock the crap off and then go use the waterless wash. I've come to the conclusion that BMW paint, as nice as it may be, does not hold up like some of the other manufacturers. Not sure why, but I've seen some people mention they use thinner paint for "eco reasons".
To me, the idea of WW is crazy at face value, but after researching and talking to people...they swear by it, and the results are stunning.
      12-04-2019, 05:23 PM   #8
DNGRTOM
Yeah - the science behind the waterless wash is pretty wild.
I do use it to remove salts/mag-chloride/etc.
      12-05-2019, 10:36 AM   #9
randybobandy
Rick James
287
thanks. I am going to try WW as a general clean up, but use the foam cannon to get the salt and grime off. thanks again for the tips!
      12-05-2019, 08:05 PM   #10
stbm5
Drives: 2018 M5 DG
I've used optimum, works well. i do a quick power wash then spray and wipe with the no rinse wash...
      12-29-2019, 04:30 PM   #11
RVAGuy
RVAGuy's Avatar
Drives: ‘20 X5/M50i (ordered); &
2014 BMW / 650  [0.00]
The use of 1-3 MF towels infers your removing a lot of grime and dirt from each panel. I would be concerned about marring the paint. Has this been an issue? BTW, I get cheap MF towels at BJís for jobs like this. Get very dirty and I toss.
      12-30-2019, 10:10 AM   #12
DNGRTOM
depending on your definition of a panel, how dirty the car is and how concerned you are about marring...
there's a lot of trash talk about big box mf towels vs $$$ detailer towels. sure the nice ones are nice, and the cheap ones *can* be cheap. I have a set from HD that are on the sucky end and a pack from costco that are pretty awesome; its a gamble.
      12-30-2019, 12:13 PM   #13
RVAGuy
RVAGuy's Avatar
My problem with the MF towels is washing them. I donít like to mix with other laundry when soiled with waxes or cleaners and they canít be dried with softener agents which my wife uses. With two black cars I try to wash every few weeks and do a good interior cleaning every two or three washes. As a result I go through a lot of towels.
      02-10-2020, 01:11 AM   #14
araje
Drives: BMW, Audi
There was a good thread about Ammo NYC water less wash. It also had a video in there.
Does anyone have any experience using this product. ??
By the way, I am planning to use it in horrible AZ summers when temps are 110F-115F outside. The panels heat up so bad that it is really impossible to clean as the shampoo dries off on the panels too quickly. Hence this waterless wash so that I can do it in garage, and oh with a cooler running.
      02-10-2020, 09:19 PM   #15
DSTJ99
Drives: '20 X7 40i - Tanzanite/Coffee
I've been using optimum for years with two buckets with good results. I try not to use it when the car is dirty with a lot of salt or road grime without a good rinse or power wash first. Super easy to use in the garage during the winter.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
