Login
12-03-2019, 09:05 AM | #1 |
Rick James
287
Rep 773
Foam Cannon Recommendations
Does anyone have a good recommendation for a foam cannon? I am using a 2800 psi 2.3 gpm Gas Craftsman Pressure Washer. I am not a fan of overpriced Chemical Guys stuff, but want something that will last more than 5 washes. Thanks!
12-03-2019, 10:19 AM | #2 |
![]() 698
Rep 1,645
randybobandy287.00 |
12-16-2019, 04:16 PM | #3 |
![]() ![]() ![]() 322
Rep 438
I use MTM Hydro, I got it in a bundle with a gun and hose, quality stuff from those guys.
12-16-2019, 09:56 PM | #4 |
![]() 12
Rep 60
i have had good luck with cheap ones from amazon. Lasted longer than the Chemical Guys one I had
12-17-2019, 06:09 AM | #5 |
Rick James
287
Rep 773
I picked up a cheap one from Lowes to see how I would like the concept before dropping $100+...it is surprisingly good. I just need to figure out the water to soap ratio. The bottle is only 700ml, so I might look for something larger on amazon. They're probably all from china, so I just need to find one that works and doesn't leak.
12-22-2019, 09:50 AM | #6 |
Rick James
287
Rep 773
I wanted to give a quick update on my foam cannon. I purchased that surfacemaxx one from lowes. The bottle is only 700ml, which sucks...also, the connections on my pressure washer were not the quick release.
Well a few amazon purchases later, and it's definitely a good buy. I ended up getting a quick release for my pressure washer gun, so I can attach closer to the handle. I still am able to put the extension on and quick change as well. I did buy the MATCC 33oz bottle with straw on amazon. It connected perfectly, so now I have my 1L bottle. Not sure if this helps anyone, but all in all...I am still under $40 with a good, sturdy cannon, connections, and bottle. Happy Winter Washing! |
LexxM31281.00 |
12-29-2019, 02:37 PM | #7 |
![]() ![]() ![]() ![]() 152
Rep 412
Drives: ‘20 X5/M50i (ordered); &
I wouldn’t recommend getting most expensive. They all do about the same getting soap on vehicle. Plan on replacing every few years. Spend money on quality waxes/ towels/ cleaners/ etc. For car interior cleaning, I find wife typically has product and tools for stubborn stains. She knows never to throw away kitchen brushes as I can use.
12-29-2019, 03:27 PM | #8 | |
Rep 412
01-01-2020, 12:03 PM | #9 |
Rick James
287
Rep 773
Thanks for the tip. I’ve been messing around with different steps. I’ll try this...I need to get a funnel, since the soap can be a bitch to get in the container.
01-01-2020, 12:14 PM | #10 | |
Rep 412
BTW, detail purist probably have problem with use of warm water for risk of containments. Hasn't been problem for me. |
