      12-04-2019, 01:55 PM   #1
Thumbs
Drives: '01 X5 3.0 5-spd, '10 X6 i35,
G05 Aftermarket Wheels
Depending on the website you visit there are either lots of choices or very few choices for the G05 X5. Adding to the confusion, some sites don't even list the current generation X5 as an option for "What Fits My Vehicle".
Here is one example: https://www.carid.com/hre-wheels/ff0...878603807.html
They list a LOT of wheel choices including this wheel by HRE. Unfortunately the wheel is NOT approved by HRE to fit our vehicle. Here is an email response I received directly from HRE:
"Thank you for sharing that link to that size. That size only fits Audi vehicles, while I understand that the width, diameter, offset, bolt pattern and hub bores do technically work for the X5, this goes back to your original statement about load rating. You’re correct in that these wheels are not SUV weight rated; hence, only available for the Audi sedans/coupes."
Note that the CarID site lists that wheel as a "Guaranteed Fitment".
Here is a running list of wheels which are actually suitable for the fully loaded, towing max capacity, G05 X5. Please feel free to add verified wheels.
BBS: "I would suggest the SX0604 which is a 20x9 +30 ET. Those should work just fine on your X5. Warm regards,Kenneth Kitching Inside Sales" This wheel is the exact same mold, etc. as the BBS SX0603 which is tested and approved for the Audi Q7. The SX0604 has not been through the testing process and is therefore not load certified and Tire Rack will not sell it to you for the X5. They will sell the SX0603 and you can buy the Audi ball lug bolts to fit, M14x1.25 29mm.
Enkei: As of the 2020 catalog nothing in their truck/SUV line fits.
ONX: At least one member has used the ONX because it is available in 20x8.5 ET35 but it is not weight rated for X5/X6. "The ONX is an exciting addition to Enkei’s SUV/Crossover lineup. Using the design language of the popular Enkei CUV, we’ve created a sporty new option for owners of crossovers and small SUVs."
XM-6: 20x8.5 ET40
HRE: Choices in their S- and P- Series, ~$2000+/wheel. See next post in this thread.
Vossen: HF-1 in 20"+ works w/ M-Sport brakes. VFS1 larger than 20" may work- verify. The VFS1 may work in 20' without M-Sport brakes- verify.
      12-04-2019, 03:02 PM   #2
Thumbs
From the fine folks at HRE:
"Thanks for sharing this with me. To clarify, the FF04 wheels CAN BE load rated for certain heavy/SUV applications. This specific fitment for the FF04 is not load rated for the X5, just in case people think that it’s not load rated across all fitments with the FF04.
Here’s a complete list of styles that we can do for you that are SUV rated for your X5:
3-piece:
Series S1 - https://www.hrewheels.com/wheels/series-s1/s101
Series S2 - https://www.hrewheels.com/wheels/series-s2/s200
Series S2H - https://www.hrewheels.com/wheels/series-s2h/s200h
540 (in 21” & 22”) - https://www.hrewheels.com/wheels/540-series/540
Series RS3 (in 21” & 22”) - https://www.hrewheels.com/wheels/series-rs3/rs300
1-piece:
Series P1SC - https://www.hrewheels.com/wheels/series-p1sc/p101sc
Series P1 - https://www.hrewheels.com/wheels/series-p1/p101
Series P2 - https://www.hrewheels.com/wheels/series-p2/p200
Series RS2M - https://www.hrewheels.com/wheels/series-rs2m/rs200m
Series RS3M - https://www.hrewheels.com/wheels/series-rs3m/rs300m
Series TR1 - https://www.hrewheels.com/wheels/series-tr1/tr105
Please let me know if you have any questions.
Thank you,
Jon Kohl
Sales"
      12-05-2019, 08:13 PM   #3
Thumbs
And from the excellent rep at BBS:
"When Germany does load and stress testing for wheels, it is almost always for a specific application (ex. BMW X5 only). They test the wheels’ load based solely on that application, which is required by TUV. We have asked them to test the wheel and rate it for its full load capacity but they still do as they have done. In Europe, for high load applications, the vehicle must re-use factory hardware and be hub-centric. This is why we made the SX0603 – Made for Audi Q7. The SX0604 was more of a generic aftermarket wheel made for Audi A5, A7, and Q5. Both the SX0603 and SX0604 use the exact same casting mold. The only difference is the hub diameter (SX0603 milled to Audi exact – SX0604 milled to 82mm for multiple applications with use of PFS kit) and the lug holes (ball seat SX0603 vs. conical seat SX0604). So ultimately they technically have the same load but Germany didn’t “test” the SX0604 for as high as they tested the SX0603.
Now, after some further investigation, you can use the SX0603 on the X5 (load rated and hub-centric) but with the use of 14x1.25 ball seat lug bolts. We do not offer them, but I have found a few vendors online that offer them."
From Tucker at Tire Rack: "We don't carry the bolt required, but they tracked down one from a company called Bimecc (www.bimeccusa.com) that you can get. Their part number is S17F29R14."
From me: That is an M14x1.25 29mm ball seat lug bolt. Note that the audi standard appears to be M14x1.5 NOT 1.25
      12-07-2019, 06:14 AM   #4
dubsesd
#dubspec
dubsesd's Avatar
6332
Drives: G05 X5/ 2016 F80 M3 INDVL
Off the shelf cast wheels will be hit or miss. It's difficult to find a set that has a staggered setup with appropriate offsets and it's strong enough for a full size SUV. Just do a custom forged wheel and get exactly the size and finish you want with the highest level of strength. I went with BC forged in 22" and they are about half the weight of the OEM wheels and extremely strong. They also balanced very nicely
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow
instagram: @ dubsesd
Appreciate 6
Thumbs27.50
r33_RGSport12966.00
Shawzy44158.00
      12-09-2019, 07:26 AM   #5
Thumbs
Nice choice!!!
      12-12-2019, 01:38 PM   #6
Ninefourteener
Ninefourteener's Avatar
1346
Drives: 2020 X5 M50i, 2020 Alfa 4C
What are the width and offset (ET) on those? What size tires are you using?
      12-13-2019, 04:39 PM   #7
ted920
Drives: 2019 BMW X5 40i, Lexus GS 300
Beautiful Wheels.
what color exactly are those wheels?
gloss black or something else?
      12-13-2019, 06:34 PM   #8
dubsesd
#dubspec
dubsesd's Avatar
6332
Originally Posted by ted920 View Post
Beautiful Wheels.
They are brushed aluminum with a dark black translucent powdercoat clear overtop
      12-29-2019, 01:20 AM   #9
Ken6096
Ken6096's Avatar
108
Drives: BMW X5M F95 2022
Nice mods. Our car almost the same except color and that “ Laser light” !! Lol. My rear OEM CF diffuser is just not look aggressive enough but i can live with that
BMW X1 F48 2017 sold
BMW X5 G05 50i 2019 sold
BMW X5M comp F95 2022
Mini clubman JCW F54 2019
LexxM31698.50
GuyOh1067.00
      01-13-2020, 07:29 PM   #10
scotchy
210
Looks great! I think I saw you say somewhere else they're 10" and 11" wide? Is there room to go wider? (I don't have the vehicle yet). Disappointed BMW has gone narrower for stock wheels on the G05 than the previous model. Would like a 12" in the rear if it's doable.
      01-14-2020, 08:01 AM   #11
x5_M50i_NC
51
Drives: 2022 X5MC / X740i on order
Awesome color combo! Where did you get the front lip?
      01-15-2020, 02:45 PM   #12
PDXBMW50I
Drives: BMW X5 M50i
I second this! It looks great
      01-28-2020, 10:30 PM   #13
roadsidegeek
Drives: 2013 BMW 3 Series 335i Sedan R
Stunning mod. I really like the overall appeal of it.
      02-19-2020, 01:45 PM   #14
jojo t
Drives: 2020 BMW X5
I just got these new wheels for my G05. They are called Beyern Ritz and are made for BMWs. The hub hole diameter is the same as the hub on the G05 which makes it "hub-centric" as opposed to most aftermarket wheels will be "lug-centric". Because of this, they do not need hub rings and fit the vehicle perfectly. Also, since they are made for BMWs they accept the oem BMW center caps. Rides as perfectly as the stock wheels but they are much lighter. I also went with black grill and installed it this am.
HomeIn2326.00
      02-19-2020, 01:51 PM   #15
jojo t
Drives: 2020 BMW X5
Dont know why those pics are misoriented
      02-19-2020, 02:12 PM   #16
Pro55
Drives: BMW X5 G05 30d
Most companies claim a fit of their wheels because they are using a larger hub size and then fitting hub centric rings to centralise the wheel. The Lug bolts take the weight. You need the correct hub size of 66.6mm to be hub centric so it is an OEM wheel. There are few brands out there but not a massive choice 66.6 mm hub as they are then limited what cars they can use them on And thus limiting their market. These are 20 inch aftermarket OEM with Grabber AT3 for winter use. Only £250 uk per wheel plus £160 per tyre.
      02-20-2020, 01:11 PM   #17
ted920
Very nice mods: Wheels and Grill look great!
I have the Black Grill and am waiting to install in the Spring and am currently researching / shopping for new 21" or 22" wheels in Black.
Nice choice on wheels.
I will consider Bayern as well as Rohana and Brixton Forged among anything else that looks good and is in my $2-$3,000 wheels budget. Tires are separate.
Anyone with any other choices that I should consider, please respond and let me know.
Thanks and Congrats!
      03-17-2020, 11:59 PM   #18
Skilly
Drives: 2020 BMW X5 M Sport
They look great, but the punchline is that BC forged, or any custom 21" or 22" wheel will set you back $8,000 to $12,000 a set; more if you don't intend on reusing the stock rubber. That said, it's the only way you will get a fitment like this.
The reference to HRE being 2K a wheel, that's more likely to be $2,500 to 3K per wheel with a 22" sizing. Custom forged wheels are just expensive...no way to get around it. The quality is over the top - you really do get what you pay for in these high end wheel options.
      04-16-2020, 01:41 AM   #19
Bandit-X
Drives: X5 M50i G05
perfect look. is that the JC Sportline front lip ?
      04-16-2020, 05:09 PM   #20
KrisV
KrisV's Avatar
Drives: 2023 BMW X5 M Competition
anyone have any thoughts on jumping to 24's with this vehicle? curious how it would look given the right style wheel...
      04-16-2020, 10:40 PM   #21
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
What's the point of tires on that, might as well just ride the 24" rim directly. Probably need air suspension to smooth out the "bumps"
Looks like 24" rims will leave 69mm = 2.7in of sidewall on there. Stock 22" is 96mm = 3.8in. So an inch less of rubber, which obviously makes sense (2" increase in rim diameter means needs 1" decrease in sidewall height to stay close to overall diameter).
      04-17-2020, 06:52 AM   #22
Bandit-X
Drives: X5 M50i G05
Beautiful Wheels.
So beautiful!
Tags
aftermarket, bbs, enkei, g05 wheel, hre, vossen
