2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum HVAC Hum
      12-18-2019, 04:20 PM   #1
FrannieMoral2017
FrannieMoral2017's Avatar
Drives: 2010 BMW 550i GT
HVAC Hum
Hey guys as the title suggests I'm noticing a hum or grumble from my blower vents. Could it possible be the motor? I seen a post somewhere on here with the same problem. Can't find it so figured I'd make a new one! I posted a link to my video below!
      12-18-2019, 07:11 PM   #2
socale39
Drives: 04 545i SMG
Debris in the fan basket. Simple fix if you have some time. Pull out the filters in the cabin and make sure to clear everything out there. Secondly you’ll need to access the blower motor from the engine compartment and remove any collected debris. I removed the entire unit to clean everything but I’ve heard some people just using a vacuum.
      12-18-2019, 07:13 PM   #3
FrannieMoral2017
Hard getting to all that??
      12-30-2019, 02:46 PM   #4
HizEternal
Drives: Jet Black F10 535XI
It’s pretty straight forward but please disconnect the battery so you don’t accidentally touch the fuse junction cables to anything metal. Also lubricate the fan center when your there sometimes it rusts. Mine rusted till it couldn’t move and I had to replace it.
Also you can hot glue a plastic mesh to the blower box to replace the foam that deteriorated.
5post
