01-12-2020, 05:17 PM | #1 |
Rep 6,031
First Defect
Two years in, I have now had the first issue requiring repair. My passenger seat will not power forward or rearward. The switch has no effect for fore/aft, but up/down and recline still work. Has anyone experienced this and learned if this is a switch issue/replacement, or is this a larger problem, such as having to dig out the seat motor?
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
01-13-2020, 08:12 PM | #2 | |
Retired Curmudgeon
2985
Rep 4,047
Sorry, no help other than since the rest of the power seat functions work, I doubt its a fuse or a connector having come apart (though wires could have been dislodged). You can check voltage at the motor while you operate the switch.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
01-13-2020, 08:22 PM | #3 | |
Rep 6,031
I can hear the solenoid/relay clicking when I activate the switch. The motor just doesn't activate. I have a dealer appointment for Friday. He said it's not a common problem, so not sure of the downtime...parts ordering, etc.
01-13-2020, 10:39 PM | #5 |
Rep 6,031
01-13-2020, 10:57 PM | #6 | |
5886
Rep 10,256
The electric motor might be the root cause. This is a common part. |
01-14-2020, 06:06 AM | #7 |
Rep 5,210
you are lucky as it failed under warranty. My seat pump that adjusts the width of the seat failed and it would have cost me dear to replace if it wasn't under warranty.
01-14-2020, 07:09 AM | #8 |
Rep 279
Drives: 2014 328Xi GT, 2020 X3 MC
Did someone vacuum under the seat lately. Might of disconnected a wire.
01-14-2020, 07:35 AM | #9 |
Rep 6,031
I've been looking under there with a flashlight. Everything look intact. If I put my fingertips on the yellow module, I can feel the solenoid clicking when the fore/aft switch is operated....just nothing happens with the motor (or, is it Motaur? Sorry....TV ad joke!). Tracks look clean, although seat is full rear, so can't see in track behind it. With rear legroom like our cars have, this was a good position in which to fail.....if it had to.
01-14-2020, 11:52 AM | #10 |
Rep 279
I doubt there is a seperate fuse just for motor power but, maybe? Those crafty Germans.
01-14-2020, 07:02 PM | #11 | |
Retired Curmudgeon
2985
Rep 4,047
Glad to hear that’s it’s under warranty.
01-16-2020, 10:55 PM | #12 |
Rep 6,031
After not working for a week, the power fore/aft mysteriously started working again today. I've been trying it daily since it first failed. Called the dealer and he said to bring it in anyway for its appointment, happens to be tomorrow morning, to see if any fault codes were stored. All quite odd! More to come...
01-17-2020, 07:21 AM | #15 | |
Rep 6,031
KiwiFlavor0.00 |
01-17-2020, 07:59 AM | #17 |
Rep 6,031
That makes sense, but the operation went from faulty to operational with a stationary vehicle. With no motion in a parked car, I would wonder how it was reestablished. I have the appointment in an hour and a half...they're going to check for fault codes before deciding to keep the car or send me on my way until it fails again. At least they said they have the loaner ready to go, if needed!
01-17-2020, 12:04 PM | #18 |
Rep 6,031
YOU WIN!
You get the Spot-On Armchair Diagnosis Award today! Turns out the full rear position movement somehow snagged some wiring, not pulling it completely out, but loosening the connection. Wiring harness was "repositioned/repaired" and new bolts installed when seat was reinstalled in the vehicle. If this happens to anyone else after a full rear travel, you have the leading suspect identified!
