01-24-2020, 08:27 AM | #1 |
Rep 8
ID 5/6 retrofit from ID4 f30
I recently bought 2016 lci f30 only downside I have to the car is no car play I want to do the the retrofit for id without the 2000 price tag I found all the actual hardware I need like the touch screen touch controller and headunit does anyone know where I can get the wiring like the harness blurry or and WiFi antenna?
01-24-2020, 10:38 AM | #2 | |
4490
Rep 10,473
The other difference is the GPS connection on some early models is to the HeadUnit as the NBT HU did and later NBT EVO HeadUnits need the connection at the rear ATM. If that connection is in your Dashboard you need an extension to run it to the rear ATM. But you need to determine if needed or not. And if you have the equipment, why do you not know if ID5 or ID6? |
