      01-27-2020, 06:47 AM   #1
sward
sward's Avatar
Sweden
632
Drives: i7 xDrive60
2023 BMW i7  [0.00]
G05 Wheels on X5M?
Will wheels from a X5 G05 fit the new X5M?
/Fredrik
i7 xDrive60 -23 Sold: iX -22, X5MC -20 (F95), X5M50d -19 (G05), X5M50d -17 (F15), X5M50d -14 (F15), 116d -13 (F20), X5 3.0D -10 (E70), M3 -10 (E93), 320DX -10 (E91), 320D -08 (E91), X3 30D -07 (E83), 335 -07 (E92), 325 -05 (E90), 320 -02 (E46), 318 -00 (E46), 320 -93 (E36), 318 -89 (E30)
      01-28-2020, 05:24 PM   #2
hybrid_eg
hybrid_eg's Avatar
Drives: 90 S13, 22 MSP, 23 JLUR 4xe
i'm curious to know too..
      01-28-2020, 07:51 PM   #3
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
Is the "new X5M" on the G-platform? If so, then very likely yes will fit and just needs overall diameter verification. If not, then no, will not fit.
G-platform changed all hub and wheel specs completely from previous bimmers. Lug bolt pattern, offsets, etc.
      01-28-2020, 09:32 PM   #4
scotchy
210
Drives: 2020 X5 M50i
Yeah but for whatever reason, on the previous gen BMW put a different size hub on the M models vs the others so you couldn't just swap. It'll be interesting to see if they do something like this again.
      01-30-2020, 06:41 PM   #5
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3452
Drives: 2020 M340i
2020 BMW M340i  [0.00]
You may need spacers for them to fit properly
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com
Top M Client Advisor in New England.
      01-31-2020, 02:04 PM   #6
hybrid_eg
hybrid_eg's Avatar
i wonder when we are going to find out x5m wheel offsets..
      02-01-2020, 05:49 PM   #7
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Keeping an eye on my parts catalog.
Will inform and do the research when it is published.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
sward631.50
      02-28-2020, 11:27 AM   #8
JayPichardo
BMW Client Advisor
3452
Drives: 2020 M340i
Just because they mount does not mean they "fit"
      02-29-2020, 05:58 PM   #9
BMW-ALPINA
Freude am Fahren
BMW-ALPINA's Avatar
474
Drives: G26 i4 M50, F11 M550d, E70 X5
All new BMWs (the newest generation) have 66,6mm and 5x112 either its a F-, G- or I-generation.
F4x 1-series FWD
F4x 2-series FWDs
F9x X5/X6 M (wich is basically an G05/G06)
All G-series
All I-series
OEM+ customization is the way to go!
LexxM31698.50
      12-20-2020, 08:53 AM   #10
Ilyam5
Drives: 06 M3
Is there an update to this question? Makes no sense they don’t fit. I know offset is different but many offsets work on cars.
20 inch rims should clear the front brake. Why no winter fitments in 20?
r33_RGSport12966.00
      12-20-2020, 07:59 PM   #11
r33_RGSport
It will fit, just width and offset will be different.
      12-29-2020, 07:16 PM   #12
TF_F10-520d
TF_F10-520d's Avatar
Norway
Drives: 2021 BMW X5 Xdrive45e Msport
G05 X5M wheels
Found the specs at Alloywheelsdirect.net
21+22" BMW 809M Wheels
Wheel Specifications
Genuine BMW Wheels
Finish: Bicolour: Jet Black with Burnished Face (Bright Turned/Diamond Cut)
2 Year BMW Warranty
Caps: centre caps not included. Choose from the accessories section below
Available for delivery (Worldwide)
Front Wheels: 10.5Jx21 ET31 (p/n 36118090796)
Rear Wheels: 11.5Jx22 ET43 (p/n 36118090717)
Thinking about buying these for mye 2021 X5 Xdrive45e
After what i can measure they will stick out 19mm out compared to the stock 741M wheels in the front + 10mm more with 295 tires.
And 13mm more in the rear same tire width as stock.
BMW G05 X5 Xdrive45e M-sport - Air Suspension - Sport automatic - 741M 21" wheels | 275/40-R21 | 315/35-R21 | Nokian Hakkapelliita 9 | Sapphire Black | B&W Diamond Surround Sound | Comfort Seats | Merino Leather | Extended Shadow Line
      09-17-2021, 01:41 PM   #13
Adblue
Ireland
35
Drives: G05 X5 M50D
Don't know if this has been answered, but will the X5M F95 wheels fit on the X5 G05 without any modifications ?
      09-17-2021, 01:43 PM   #14
Alan l.
Alan l.'s Avatar
5437
Drives: 2020 F95 X5M Competition
F95 wheels will fit the G05 no problem
G05 wheels may or may not fit the F95 (depending on wheel style) because the M has bigger brakes.
Alan
Adblue35.00
      09-17-2021, 02:03 PM   #15
Adblue
Ireland
35
Drives: G05 X5 M50D
Alan
Will they stick out a lot compared to standard X5 wheels ? Meaning - will the look stupid without some kind of wheel arch modding ?
      09-17-2021, 04:14 PM   #16
Alan l.
Alan l.'s Avatar
5437
I know the X5M fender flares are a tiny bit wider but its minuscule. Also the stock X5M wheels are pretty conservative with folks running big spacers so I am thinking it would be ok on a regular G05 without spacers.
Adblue35.00
      09-17-2021, 05:24 PM   #17
Chas8283
Chas8283's Avatar
Drives: BMW X5M
Definitely right. iconoclast did this and it looks incredible: https://g05.bimmerpost.com/forums/sh...4#post27896804. Best looking M50i I've seen.
      09-27-2021, 03:09 PM   #18
Adblue
Ireland
35
Drives: G05 X5 M50D
So it's 100% fit of the X5M 809/818 wheels on the X5 - without any modifications? - I'm about to spend good few thousands on the set, wouldn't want to get it wrong
      09-27-2021, 09:03 PM   #19
Chas8283
Chas8283's Avatar
Drives: BMW X5M
Suggest you reach out to iconoclast. I’m sure others have done it but he’s the only one I remember. Good luck and let us know!
      09-29-2021, 12:04 PM   #20
Adblue
Ireland
35
Drives: G05 X5 M50D
I reached out to iconoclast but so far didn't hear back.
However I was talking to parts guy over at BMW garage and was told that if there was a problem with the driving of the car that could be related to the F95 wheels on the G05 I might not be covered by the warranty.
