01-31-2020, 12:01 PM | #1 |
97
Rep 35
BMW M5 Competition exterior mods
Front and rear reflector deletes
RKP front splitter and rear diffuser BMW M performance side skirts and pro spoiler 12mm spacers front and rear BMW M5 comp wheels powder coated black |
01-31-2020, 06:49 PM | #2 |
Rep 5,233
Looks nice! Love the Comp wheels in black.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
jmsdub96.50 |
02-01-2020, 10:32 PM | #6 | |
12968
Rep 18,713
Most important part, do it while your car still new. The older the car, the harder it is. Since the old double sided tape will most likely break in pieces and will take a lot of time to clean them out. I have done plenty of them where it takes me 30 minutes for both side.
jmsdub96.50 |
02-03-2020, 10:57 AM | #7 |
97
Rep 35
02-03-2020, 10:58 AM | #8 | |
97
Rep 35
02-03-2020, 11:00 AM | #9 | ||
97
Rep 35
02-12-2020, 07:55 AM | #11 |
Rep 62
Looks great. I’m debating 5mm or 12mm in the rear. I’ve been told anything in between might be an issue with the hub. From your pics it looks like the rear tire is past the top of the fender? Do you have a pic showing how far out the rear tire protrudes? Thanks!
02-12-2020, 11:33 AM | #12 | |
1716
Rep 1,909
Drives: 2023 M5C
IG @windtendo_m5
02-12-2020, 12:40 PM | #13 |
Rep 62
Two data points made me reconsider 10mm. Future Classic doesn't offer 10mm due to the hub size and lack of proper support for the wheel - per IND. And, this from Turner: "10mm Fitment Note: You must be very careful when fitting 10mm spacers to any BMW. Since the depth of the hubcentric lip will vary, you risk bottoming out of the spacer before it sits flush with the hub. This will leave a gap between the spacer and the hub, seriously compromising the strength of the spacer. The lip on the car may need to be shaved down so the 10mm spacer will fit flush on the rotor hat."
02-12-2020, 12:46 PM | #14 | ||
97
Rep 35
My car is leased..as long as car looks good the dealer usually doesn't care. In fact the dealers here offer to do that as option. |
02-12-2020, 12:50 PM | #15 | |||
97
Rep 35
It does not overhang the top of the wheel well |
IND-Distribution9586.50 |
02-12-2020, 12:51 PM | #16 | ||||
97
Rep 35
02-12-2020, 02:03 PM | #17 | |
1716
Rep 1,909
Drives: 2023 M5C
Here is the BMS 10mm spacer I originally bought from n54tuning.com: https://www.n54tuning.com/g-chassis-...s-by-bms.html# Here is the Future Classic 5mm and 12mm spacer recently bought from IND: https://ind-distribution.com/collect...eel-spacer-kit I'll keep you guys posted once I attempt to install them Friday
IG @windtendo_m5
jmsdub96.50 |
02-12-2020, 04:53 PM | #18 |
Rep 62
https://www.n54tuning.com/g-chassis-...s-by-bms.html# Here is the Future Classic 5mm and 12mm spacer recently bought from IND: https://ind-distribution.com/collect...eel-spacer-kit I'll keep you guys posted once I attempt to install them Friday [/QUOTE] We're both on a mission! |
jmsdub96.50 |
02-15-2020, 11:57 AM | #20 | |
Rep 137
whats so special about G body versus other BMWs other than 5x112 vs 5x120? |
02-15-2020, 03:35 PM | #21 |
1716
Rep 1,909
Drives: 2023 M5C
Just got around to replacing the front (originally 10mm) with a 12mm, and put 5mm (no spacer originally) on the rears... PERFECTION.
Stance is not too aggressive, and it pushes the wheels out just enough to not wonder if the tires are sticking out too far at certain angles. |
02-15-2020, 04:02 PM | #22 | |
Rep 62
