EGR delete pipe vs capping oem EGR
02-04-2020, 11:45 PM | #1 |
Rep 137
I'm very close to deleting my egr and I'm trying to decide if I should just cap off the oem egr where the cooler clamps on or buy the race pipe assembly. Capping off the oem egr would be cheaper and all I'd have to do is remove the cooler instead of the entire system. I'd have to reinstall the egr from time to time during certain years *cough cough*. Any thoughts on this?
02-04-2020, 11:52 PM | #2 | |
Rep 1,442
02-05-2020, 07:47 AM | #3 |
Rep 1,054
I also vote for block off plates. It would be a pain to reinstall the coolant lines every single time.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
02-05-2020, 10:47 AM | #5 |
Rep 1,054
No. You don't need to fully remove the cooler to install block off plates. If you loosen everything you should be able to slide both block off plates where they need to go. First install the hot side egr block off plate then the cold side plate. Make sure you buy a ccv hose since it'll most likely be dry rotted when you remove the intake piping.
02-05-2020, 11:16 AM | #6 | |
Rep 137
02-05-2020, 11:30 AM | #7 |
Rep 1,054
I'm not sure what you mean by that. But the block off plates are essentially sandwiched in there when fully installed. You don't need to worry about any vibration or wearing of any kind because the plates shouldn't move once installed.
02-05-2020, 11:52 AM | #8 |
Rep 137
While doing more research I realized that the pic I attached is for both the hot and cold side of the cooler. The flat plate with gasket is for if you want to remove the cooler entirely. I thought you needed the plate as well if leaving the cooler on too.
BTW $75.00 for tiny little disc plates?? WTF??? https://www.tunemyeuro.com/bmw-335d-...ock-off-plate/ Last edited by e90Noobie; 02-05-2020 at 12:39 PM.. |
02-05-2020, 01:18 PM | #9 | |
Rep 1,054
