02-08-2020, 01:37 AM | #1 |
Rep 84
What does the red P in the square mean?
Hello,
I was forwarding into my office car space today. I turned on the parking cameras so I didn't hit the column or the wall. There was a chime and a red P appeared as per the attached image, bottom right corner of the screen beside "settings". What does it mean and what is it for? |
02-08-2020, 01:53 AM | #2 |
Rep 632
It’s a parking space (which it may or may not be in my experience!) that the parking assistant has identified. You tap the red square and the car will auto-park in that spot.
You can turn the feature off if you don’t want to make use of it... |
randybobandy304.50 |
02-08-2020, 06:59 AM | #4 |
Rep 3,307
You saying it has identified spaces that didn't really exist? That would be hard to auto park in!
02-08-2020, 07:24 AM | #5 |
Rep 4,515
Drives: 2022 iX xDrive50, DGM
02-08-2020, 07:26 AM | #6 |
Rep 3,307
02-08-2020, 07:29 AM | #7 |
Rep 4,515
02-08-2020, 07:55 AM | #8 |
Rick James
305
Rep 784
I am assume you were in "Drive"? What is behind you? In my short experience using that feature for shits and giggles, it means that is a potential space for the vehicle to back into.
02-08-2020, 03:59 PM | #9 |
Rep 116
The P oriented that way means it thinks there is a perpendicular spot on the right side for the car to back into. If it was oriented vertically it would indicate a parallel parking space. The auto parking actually works quite well, surprisingly so, and I use it pretty often. It’s usually best if the space is in between two cars. Also once you’re parked when you get back into the car it will display an arrow which if you click the car will do the work of getting you set up to exit the space. This came in very handy when my wife was driving out of a very tight and steeply inclined spot that the valet had left the car in - it took around 6 forwards and backwards reversals but eventually it got pointed out.
matthew_hull65.50 |
02-09-2020, 09:37 PM | #10 | |
Rep 272
Next time when looking for parking just press the camera button next to shifter knob and car will detect parking spot, once detected, stop your car completely and press on P rectangle and car will park automatically. |
02-09-2020, 11:55 PM | #11 | |
Rep 84
I'll give that a go. My dealer in Sydney is hopeless with support and training on the car. I'm really relying on this forum. Cheers N. |
02-10-2020, 12:15 AM | #12 |
Rep 272
02-10-2020, 12:36 AM | #13 | |
Rep 467
Current BMWs - '21 M550i Bernina Grey/Black Nappa, '20 X5 sDrive40i xLine Alpine White/Coffee Extended Merino
Past BMWs - '20 740i, '20 X3M, '19 540i M-Sport, '19 440i GC M-Sport, '18 M3 Comp., '18 X5 sDrive35i, '18 340i, '17 X3 sDrive28i, '15 335i xDrive Sport Line, '14 428i Coupe |
02-10-2020, 10:03 PM | #14 |
Rep 84
Nope .... the mob near Belmore. Mine was a demo ... they didn't detail it properly. They double booked my appointment with the BMW genius and the other guy got there first ... so I missed out. I walked out of the dealership absolutely furious ... no one ever called to follow up.
Yes, dealers are all the same ... once they take your money they couldn't give a .... |
