      02-22-2020, 06:22 AM   #1
barrowdad
Drives: BMW X5 30D M Sport (G05)
Post Dual Camera Dashcam Install in 2019 G05 X5
I've recently installed a Thinkware F770 dual camera Dashcam in my 2019 X5 30D M Sport (RHD) and this video may help others intending to do something similar (especially useful for running the rear camera onto the the tailgate).
Appreciate 6
      03-04-2020, 09:40 AM   #2
VTENGR
699
Drives: 2020 X5 M50i
I want to remove the D-pillar trim because I think it's the source of a rattle when music is playing. I have some trim removal tools, but I'm chicken when it comes to removing trim because I don't want to break any clips, etc. and make matters worse. Any tips to removing this trim?
      03-04-2020, 10:56 AM   #3
barrowdad
D Pillar removal tips
When I popped mine I just inserted a wide bladed trim tool in the middle top and gently applied leverage. It came away quite easily. Have faith!
VTENGR699.00
      03-04-2020, 01:16 PM   #4
VTENGR
699
You've given me confidence! Thanks!
      03-08-2020, 07:21 PM   #5
VTENGR
699
Thanks to you I was able to have the confidence to pop those D-pillar trim pieces off. Was able to add dynamat to those pieces and how have zero rattles. Thanks so much for that!
      04-03-2020, 09:39 AM   #6
barrowdad
You are welcome. Glad to have helped.
      04-10-2020, 06:30 AM   #7
007bandido
Switzerland
Drives: 2019 G05 30D M
Hello,
Thanks for the video.
I took exactly the same way last year to install my Blackvue double channel in my G05. Otherwise, I prefered to took 12V in the trunk fuse box, much more easy to change the input power between car and external battery. It means just an additional cable between trunk and glove box where I installed a Multisafer to cut the power when the car battery reachs 12.1V.
https://www.ebay.fr/itm/MS-MultiSafe...53.m2749.l2649
      04-10-2020, 07:06 AM   #8
barrowdad
Thanks for your comments. As I explained in the intro to the video the rear fuse box was going to be my preferred option because (as you pointed out) access is easier than the front fuse box. In my case my Dashcam has a built-in power monitor and cut-off so I didn't need a separate battery voltage cut-off device but other readers may find your link useful if they need one so thanks again.
      06-27-2020, 03:52 PM   #9
cygnusecks
cygnusecks's Avatar
Drives: X5 (G05)
A HUGE thank you to barrowdad - based on your excellent video and commentary I felt confident to do the job myself! I installed a thinkware f800 pro. It went very smooth and I routed the wires identically to yours. I had your video queued and played over and over in the garage while installing. Front camera and power took about an hour. Rear about 2. Much like you I was dreading the rear wire routing but it wasn't too bad, hopefully my grommet doesn't leak in the back. And I avoided problems thanks to you!
Have you gotten any "battery low" messages due to the 10 minute delay of the ACC power after engine shutoff?
      06-27-2020, 04:00 PM   #10
cygnusecks
cygnusecks's Avatar
Drives: X5 (G05)
One mistake I DID make was in widening the wrong hole in the rear panel when routing the rear camera wire toward the rubber grommet hole. I accidentally widened the hole into which the panel clip inserts. Haven't driven her at speed yet to see if it rattles but I hope not!
      01-06-2021, 10:59 AM   #11
hiki08
Drives: G05
Happened to come across your YouTube video a little earlier (before seeing this thread). Appreciate the post up!
It’s typical for the cams to be ‘professionally’ installed on this side of the globe, but they essentially ran the same line and equally complained about how hard it is to get the cables from the rear (D?) pillar into the tube that connects to the boot lid for this G05.
Edit: sorry only realised afterwards this was a June thread...
      01-06-2021, 11:24 AM   #12
barrowdad
Hi, Thanks for the the comment. Also for some reason I missed the comment from cygnusecks and can't see how to reply directly to him but in case this reply is helpful to you and others I can confirm that on my previous X5 I did get 'Shutting Down Due To Low Battery' message from the dashcam but after nearly 12 months with it fitted to my GO5 I haven't had any such messages. I think this may be due to the fact that the GO5 versions have another battery fitted in addition to the main one.
Tags
dashcam, g05, thinkware
Copyright ©2000 - 2021, vBulletin Solutions Inc.
