Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Bimmercode Essentials for G20
      02-23-2020, 12:07 AM   #1
hamzag20
hamzag20's Avatar
556
Drives: BMW G20 330i, BMW G30 540i
Hey guys so I recently coded using Bimmercode on my G30 540xi and was pretty impressed with how it all turned out. (I'll attach pics below) However, with the limited options with the G20, what do you guys recommend? Also, I think that us G20 owners need to contact Bimmercode to ensure that we have some ambient lighting coding coming through because I am very very impressed with the contour ambient lighting on my G30. But yeah, what do you guys think is essential to code on a G20?
      02-23-2020, 12:17 AM   #2
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
What is colour contour ambient lighting?
My favourites are:
1. Being able to code my car to start in sport individual mode.
2. A.S.S off.
3. Coded (added) lane change indicator to 5 blinks from 3.
4. Mirror tilt (in reverse gear) angle to 60% from 100%.
What I’d love to code -
1. Auto high beam
2. Gear display even in D (shows which gear the car is in even in D and not just in M/S).
3. A coding that reduces the ummmmm...sensitivity/intensity(?) of steering intervention when using lane keep assistant, thereby making it useful (not many people use it in the G20).
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      02-23-2020, 12:47 AM   #3
hamzag20
hamzag20's Avatar
556
My favourites are:
2. A.S.S off.
What I'd love to code -
1. Auto high beam
Oh also regarding your question with color contour ambient lighting, it is like how I have two colors on my dash. So on top, I have a pinkish color and on bottom I have magenta. I can't rlly do tht on my G20 because we only have a LED bar that displays one color.
      02-23-2020, 12:54 AM   #4
VipinLJ
Petrolhead
VipinLJ's Avatar
Ah gotcha. That makes sense. I did notice the two different colours but I wasn’t sure that was what you were referring to.
I don’t like A.S.S. because my car turns off before it comes to a complete stop. I hate it because it’s the same in the Audis too (except my A4 which had perfect A.S.S and I left it on in that). Makes it feel jerky especially when you’re coming to a stop at low speeds.
And the mirror tilt issue for me was that it tilted way too much at 100%. At 60%, it’s much better but I might code it to 50% to make it better for me.
Current:
      02-23-2020, 07:32 AM   #5
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Add to my Wish List:
• Easy entry. Slides driver's seat back when door opened & slides seat back when turning ignition on.
• Driver's seat Heat Adjust. Using iDrive, adjust heat of seat cushion & back
I coded the 1st on my F30 & could only code temp changes, but not make it easily adjustable
Here's hoping!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      02-23-2020, 07:36 AM   #6
RedKloud
RedKloud's Avatar
735
Drives: BMW i4 M50
My wishlist:
- Automatic high beam
- Gear display in D and on HUD
- Scandinavian DRLs
      02-23-2020, 08:47 AM   #7
Burrcold
Drives: 2024 BMW M3 Comp xDrive
Are you able to code the side mirror to not auto dim at night?
      02-23-2020, 11:09 AM   #8
VipinLJ
Petrolhead
VipinLJ's Avatar
Using bimmercode? I don’t think so.
Current:
      02-23-2020, 02:44 PM   #9
Burrcold
Darn I wish I could find a way.
      02-25-2020, 11:33 AM   #10
CyclingBroStyle
CyclingBroStyle's Avatar
Drives: '19 330i xDrive M Sport
Has anyone used an enet cable with an Ethernet to lightning adapter for coding from iPhone?
Current: MY2019 330i xDrive M-Sport w/Lasers - Portimao Blue
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey
BMW CCA #522637 use me as a referral for BMW CCA
      02-25-2020, 12:29 PM   #11
mrkrad
Old Geezer!
Drives: 2020 m340i PB MPE
Yup works great and is fast
      02-25-2020, 03:20 PM   #12
hamzag20
hamzag20's Avatar
556
Yup works great and fast too... however be careful with the adapter from the Ethernet to iPhone as it's very flimsy and can bend or break very easily.
      02-25-2020, 04:18 PM   #13
TTG
TTG's Avatar
Drives: M340
Besides whats mentioned above, I would love to:
-Activate Rear Fog Lights
-Have rear turn signals act like they do in Europe
-Code the lasers (Anti-Dazzle)
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
VipinLJ1936.50
      02-25-2020, 10:34 PM   #14
hamzag20
hamzag20's Avatar
556
How do the rear signals act in Europe?
      02-25-2020, 10:43 PM   #15
VipinLJ
Petrolhead
VipinLJ's Avatar
I wish there was a way to make the rear turn signals dynamic, like in the Audi A4. It gives the car a classy look.
Current:
      02-25-2020, 10:53 PM   #16
VipinLJ
Petrolhead
VipinLJ's Avatar
https://g20.bimmerpost.com/forums/sh...2&postcount=27
Current:
hamzag20556.00
TTG931.50
      02-26-2020, 02:31 PM   #17
RSnic
RSnic's Avatar
Hi,
European turn signals are amber & have a separate bulb. We don't have that in US because federal rules dictate size of rear lights & to have both (with the LED light strings we have), the tail light won't be wide enough
Even if you were to string in an amber LED, you'd have to reassign pins and the like -- a real pain
Sorry
Al
Retired: 2014 328i
BMW CCA
      02-26-2020, 06:33 PM   #18
rlmesq
1039
Drives: 2018 440i M Sport
When I'm going to be using valet parking, I use Bimmercode to make the car start in Eco Pro mode. Makes them less likely to get aggressive with it.
      03-11-2020, 06:50 PM   #19
TTG
TTG's Avatar
Drives: M340
Originally Posted by RSnic View Post
Hi,
Sorry
Once the coding is figured out, I would be happy to go get a set of ECE tails like I have done with all of my past BMWs. (amber indicators)
Further, our turn signals would just blink red after the coding is done. We already have 2 strips of brake lights as is but DOT threw in what would be the turn signal into the mix as well. Drives me crazy!
Audis function the same way too and they are super easy to code vs BMW.
      03-12-2020, 07:43 PM   #20
Donia330i
Donia330i's Avatar
Drives: 19 330i BSM
My favourites are:
2. A.S.S off.
1. Auto high beam
Under what section is the code to start in sport? Can you pick which mode?
      03-12-2020, 09:17 PM   #21
VipinLJ
Petrolhead
VipinLJ's Avatar
Body domain controller -> Default driving mode (under the driving mode susbsection)
You can choose between the original modes the car comes with (you cannot choose sport plus or comfort plus since we code that into the car)
Current:
      03-13-2020, 04:56 PM   #22
Jbrock22
Jbrock22's Avatar
222
Drives: 2pw
BMW   [0.00]
Yes, works much faster than wireless.
g20
