03-04-2020, 12:09 PM | #1 |
Rep 1,201
Rear BBK upgrade
The rear brakes I would argue, are the most disappointing thing about the new X5, and unfortunately, this has been consistent for the past sevetal years, on several different platforms.
Rear BBK upgrades have been made available, but the complexity associated with the electronic parking brake (EPB) has meant that rear BBKs are not available for the G05 platform. .... until now. I've found 3 different companies that offer 4 pot BBK upgrades compatible with the rear EPB on the G05 platform. None of them are what I'd refer to as "industry leaders" though (XYZ Racing, Ksport, etc). But, I imagine that Brembo, Stoptech, Rotora, etc will be soon to follow, once they've done the appropriate R&D that people trust goes along with their products. With all that said, I'm already planning, but not having done a brake job yet (I have all 4 sets of pads, just waiting on a good sunny day).... I'm unfamiliar with how the rear EPB works. In short... how does the rear EPB work? Is it mechanical or hydrolic? What is the difference between the actions associated with depressing the brake pedal, vs activating the parking brake. Is there even a difference? How would the EPB complicate a typical caliper swap, and the associated bleeding procedures?
12+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019 690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813 6-Piston X5M Big Brake Kit:https://g05.bimmerpost.com/forums/sh....php?t=1779038 |
03-10-2020, 11:08 PM | #2 |
Rep 163
I think the M performance brake kits is available. I see it on getbmwparts.com and also i used to ask for the the price from my dealer. The price on getbmwparts is around 3200$ and the labor for set up the set from my dealer is $660 with red calipers. Not sure if that is what you want.
03-13-2020, 02:49 AM | #3 | |
Rep 1,201
Yea... the rotors are drilled..... so, you get that I guess. But basically you are paying $5000 for red paint. Besides, I want to upgrade the rear single-piston floating setup to a monobloc 4-pot setup. This has been the case across many models. I bought the red MPerformance BBK for my '14 328i, and then took it off when I traded the car in. When I bought my '16 340i, it came with the blue sport brakes.... which were the EXACT same dimensions as the red MPerformance brakes. I know this, because the diameter of my rear parking brake was larger on the 340 that it was on the 328.... so the rear (drilled) rotor wouldn't fit. So... I installed the RED mperformance brakes... right on my OEM 340i rotors. They weren't drilled, but they were red. Then I sold the stock blue sport calipers, along with the Mperformance rotors, as a "kit". With M performance.... you are paying thousands of dollars for them to drill holes in the rotors, and paint the calipers red.... that's it.
03-13-2020, 10:19 AM | #4 | |
Rep 163
So it’s like paying for cosmetic upgrade only.. I see... thank you for the knowledge. |
03-13-2020, 06:16 PM | #5 |
#dubspec
6317
Rep 5,200
My msport brakes work just fine. Very good braking. Only complaint is the look of the rear caliper being cast. I'm so used to the beautiful look of my carbon ceramics on my m3, the X5 does leave a bit to be desired
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
03-14-2020, 06:02 AM | #7 | |
Rep 1,201
They aren't bigger, thicker, or better.... the mperformance brakes are just red, with drilled rotors..... thats it. I like the look of the red, admittedly..... but I could have them powdercoated for a few hundred dollars and accomplish the EXACT same thing. Mperformance brakes (on a G05 at least) are a complete waste of money. |
matthew_hull65.50 alienstudio30.00 |
