03-13-2020, 10:39 AM | #1 |
Rep 252
Drives: 2017 Model S P100D
HK rear speaker deck rattle?
Hi all,
I've noticed the speakers on the rear deck rattle quite a bit while playing mid-high volume music. I've spent time tuning the sound through the idrive and also turned off EQ through apple music so that it's neutral and controlled by the vehicle. I have a buddy with a 340i (also with the HK system) and his does the same. Does anyone know the cause or potential fix? Cheaper vehicles I've owned in the past allowed much easier access to the rear speakers but our vehicles have a multitude of cladding both above and below the deck. Thanks! |
03-13-2020, 03:03 PM | #2 | |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
03-13-2020, 03:27 PM | #3 |
8256
Rep 16,101
Finding rattles is easy with the right tool, in this case a sine wave generator, which you can download to PCs and as apps for iPad/android. You need to get your device playing through the system via Bluetooth or the auxiliary input, then use the iDrive radio controls to pan to the rear speakers only. Sweep up through the frequencies starting at 100Hz. When you get to a frequency that's causing a sympathetic vibration it should be easy to feel where it's coming from. Testing for what's rattling in response to a sub you'd start at 100Hz and sweep down.
03-13-2020, 03:51 PM | #4 | |
Rep 252
