Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Help Installing Dashcam
      03-14-2020, 08:16 PM   #1
murderedg20
murderedg20's Avatar
89
Drives: 2019 330i M Sport
Excuse my ignorance... This is my first time installing a dashcam. From other forums I have found that I should install my dashcam into Fuse F59. I only want it running when the car is on. The dahscam I have is https://www.amazon.com/BlackVue-DR59...NsaWNrPXRydWU= It's only a one channel dashcam so I am not running any wires to the trunk.
I have the dashcam mounted and the wires all tucked in going to under the passenger seat. My dashcam came with a 12v plug so I am going to have to change that to a fuse. Now to my real question - there is already a fuse in F59 so how would I go about adding the fuse for the dashcam - a splitter or just replace the current fuse? Attached is a photo of my fuses and circled is F59.
Any help is greatly appreciated. Thank you in advance!
      03-14-2020, 08:39 PM   #2
murderedg20
89
Nevermind. I ended up just hiding the wires and plugging it into the rear 12v port. Can't tell there is any wiring from the dashcam or the plug.
      03-15-2020, 07:20 AM   #3
MurrayB
Drives: 2020 BMW M340ix
Please post pictures of your Installation. Where you mounted the camera and how you ran the wiring would be very helpful. Thanks!
      03-15-2020, 07:26 AM   #4
murderedg20
89
Not sure how helpful these pics are. I didn't have to take any panels off or remove the weather stripping I just pushed it in. The white line is the wiring. It basically goes up in the headliner and then down the pillar and the front passenger seat footwell to the rear console.
      03-16-2020, 03:12 AM   #5
sd_dracula
141
Drives: 2020 G20 330e
I have a socket in the trunk (on the right wall above the battery), it will be nicer if you install it there.
      03-16-2020, 05:18 PM   #6
2020g20
Drives: 2020 330i
Splicing it into the rear view mirror cluster wiring is so much easier and cleaner. I used less than 12" of wire total.
G20 Hardwire dashcam https://g20.bimmerpost.com/forums/sh....php?t=1654274
g20
