03-26-2020, 11:10 AM | #1 |
Rep 1,113
added wireless charging tray and coding for phone reminder
This was a relatively easy install. The hardest part was unplugging the USB and 12V socket connectors to remove the cupholder. It works just as advertised and even reminds you (with some coding) if you've left the phone in the cradle.
Total cost: $120 Shipped from EU
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive Last edited by greekcs; 03-26-2020 at 11:21 AM.. |
03-26-2020, 11:25 AM | #2 | |
Rep 1,222
03-26-2020, 11:30 AM | #3 |
Rep 1,113
Part number: 84109434000
Installation instructions: https://www.newtis.info/tisv2/a/en/g...one/1Vndu0qEK0 To add the phone reminder, add 6NW to FA and code MGU and KOMBI. I believe this option also adds enhanced BT.
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive Last edited by greekcs; 03-26-2020 at 11:38 AM.. |
9
possible335i2008165.50 pneumodoc233.00 VipinLJ1941.50 hamera441.50 37b86.00 Bmwguy199424.00 BCD-53551.50 excep7ion49.50 E__F6.00 |
03-26-2020, 01:06 PM | #4 | |
Rep 424
03-26-2020, 06:25 PM | #6 |
Rep 1,113
I purchased second hand from a salvage vehicle.
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive |
jcrosa12.50 |
03-31-2020, 12:36 PM | #7 |
Rep 11
Sorry folks I'm a total rookie at this stuff.
If I have the NFC mat in my 330 and want to swap to the wireless charging mat, is the new mat the only part I need to purchase? Then just follow the steps greekcs outlined above? Thanks for the info. |
04-02-2020, 09:13 AM | #8 | |
Rep 243
04-02-2020, 12:34 PM | #9 |
Rep 1,113
No tapping required. The wiring is already in place. You just unplug the NFC pad and replace it with the Wireless Charger.
Bmwguy199424.00 |
04-02-2020, 03:10 PM | #10 |
Rep 424
04-03-2020, 05:16 AM | #11 | |
Rep 243
Is it sort of just tucked away nearby ready for the wireless charger pad? When I look at a second hand tray on ebay it looks like there is a connector and an aerial socket. Does that make sense? |
04-03-2020, 09:45 AM | #12 |
Rep 11
Do you have an iPhone? I'm wondering if the wireless charging tray still has the issue the NFC tray has where it's constantly triggering the wallet app.
04-05-2020, 04:54 PM | #13 |
46
Rep 44
Thanks for figuring this out!!! Can you add a little color to the coding process once swapped out? Can it be done in bimmercode? Thanks for your help!
04-08-2020, 10:08 AM | #14 |
46
Rep 44
Bueller! Bueller!! I will play around in bimmercode and if I can figure out what is needed apart from what Greeks provided once this is installed I will share. Thanks again for testing this, I just ordered one!
04-08-2020, 10:32 AM | #15 |
Rep 11
Where do you order from? Everywhere I find one it says it's discontinued and no longer available.
04-08-2020, 10:35 AM | #16 | |
46
Rep 44
Trouble your having is Greeks listed the incorrect part number. He listed the part for the wireless/lte system sku number. This specific part number is 84109437712
04-08-2020, 10:37 AM | #17 | |
46
Rep 44
https://www.ebay.com/itm/123980961861
NorrisContender1.50 |
04-08-2020, 11:59 AM | #18 | |
Rep 22
Drives: G20 330i xDrive Luxury Line
04-08-2020, 12:01 PM | #19 | ||
46
Rep 44
04-08-2020, 12:02 PM | #20 | ||
46
Rep 44
zanicwb12.00 |
04-08-2020, 12:23 PM | #21 |
Rep 1,113
I have the most up to date version according to bimmercat. But it shows up as being discontinued when I search.
