03-26-2020, 03:32 PM | #1 |
Constantly Learning
66
Rep 200
Backup Assistant Auto Brake
Our Garage entries are a mere 8 feet wide (actually 92"). When the backup assistant is engaged, the car will stop early on and force manual takeover. Is there a way to adjust this? Yes, the X5 barely fits, but my wife truly needs that assistant...
03-26-2020, 04:39 PM | #2 |
Rep 5,328
Are you saying the vehicle self brakes when close to a object when backing up??
That was one feature the X5 didn’t have. If you were backing up and put a object behind you, the X5 would not auto brake. Lots of threads on this and angry owners. |
03-26-2020, 04:47 PM | #3 |
210
Rep 323
Drives: BMW X5 G05 30d/BMW M5 F90 Comp
It got added to our cars in a recent software update.
03-26-2020, 05:00 PM | #4 | |
Member
902
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
03-26-2020, 05:04 PM | #5 |
Rep 5,328
Does it auto brake just slowly backing out of the garage and a bike was in its path??? I am excited if we get this important safety feature activated. I will have to do some test with some couch cushions. Remember a member damaged his gate because this common safty feature was not activated in the new G05 X5. No way it can have a 5 star safety rating without it.
03-26-2020, 05:15 PM | #6 |
Rep 58
The M50i definitely has auto braking while reversing when it detects an obstruction. It has 2 options, detection from rear and side. I find it to be too sensitive and have disabled it. I haven't discovered any way to adjust it - unlike the driving intervention sensitivities.
As an aside (and potential recommendation), many topics now can vary in their answer/solution as the variations of software in the wild are numerous. I've included current versions (mine) in my signature to indicate the nature of my ability to comment. Edit: Here is the path in iDrive: Settings>Driver Assistance>Parking and maneuvering>Active PDC with braking interv
2024 G80 M3 CS, BSM
2023 G07 X7-40i, BG prev: '22 G80 M3Cx; '20 G05 X5-M50i; '19 G05 X5-40i Last edited by sk0rchi; 03-26-2020 at 10:08 PM.. |
03-26-2020, 05:20 PM | #7 | |
Member
902
Rep 2,032
03-26-2020, 05:54 PM | #9 |
Registered user
78
Rep 422
Drives: G05 3.0d MSport / F23
It came with 11/2019.40 for me
03-26-2020, 06:30 PM | #10 |
Member
902
Rep 2,032
It didn't stop for me. I hit the cardboard box
03-26-2020, 08:34 PM | #11 |
210
Rep 323
03-26-2020, 08:36 PM | #12 |
Member
902
Rep 2,032
I have the same but in my test it didn't work.
03-26-2020, 08:43 PM | #13 |
210
Rep 323
03-26-2020, 09:02 PM | #14 | |
Rep 4,515
Drives: 2022 iX xDrive50, DGM
03-26-2020, 10:34 PM | #15 |
805
Rep 1,790
My X7 on software version 07/2019.59 does it. I've had it slam on the brakes numerous times while backing out of my garage due to the close proximity of the garage door side wall. I've also had it prevent me from backing down a very steep driveway as it thinks I'm going to slam the rear end into the street at the end of said very steep driveway.
I've found that you can prevent it from slamming on the brakes if you back up very, very slowly while it's beeping at you like crazy. I just stop when it beeps with one continuous beep. Then slowly release the brake to start backing up again very slowly. If it beeps again with on continuous beep I just stop briefly and start the process again. This takes a bit longer but once I figured it out I can back out every time without it slamming on the brakes. |
03-26-2020, 10:56 PM | #16 |
Rep 430
Looks like its supported on 2020 US/CAN models and 2019 and up Europe/Aus models as I see the origin of the postings by the users. I might be wrong though.
03-27-2020, 09:36 PM | #18 |
Rep 430
Is yours a 2020 model?
2019 X7 40i Metallic Black
03-28-2020, 03:22 PM | #19 |
241
Rep 319
Drives: 2024 X5 M60i, 2020 RRS SE, 201
My M50i August build will occasionally brake when backing out of the garage. Just happened this week also when I was backing up the driveway and the Garbage/Recycling cans were there. Its a bit startling at first, but I guess it could be a godsend.
RADMJK
2024 BMW X5 M60i Brooklyn Gray Metallic 2020 Range Rover Sport SE White 2017 BMW 530i xDrive Black 2005 BMW Z4 2.5i Jet Black |
03-28-2020, 08:54 PM | #20 |
1037
Rep 1,527
Yes it does and is available in the new March update and the previous November update.
2021 M40i Phytonic Blue / Black Vernasca
2020 X5 xDrive 40i Tanzanite Blue / Coffee Vernasca 2011 328xi. Space Grey - Sold 188,925 great miles |
03-29-2020, 07:21 AM | #21 |
Member
902
Rep 2,032
I'm wondering if the braking only occurs in the Backup Assist mode rather than just putting it in reverse. I've yet to try the Backup Assist.
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport Last edited by X54TH; 03-29-2020 at 07:27 AM.. |
03-29-2020, 08:31 AM | #22 |
241
Rep 319
Occurs anytime I put the vehicle in reverse and there is something near the sensors.
RADMJK
